Phil Smith Posted June 24 Posted June 24 Fascinating subject and a favorite subject of mine as well. I look forward to this build! Dandiego 1
Dandiego Posted June 24 Author Posted June 24 Vertical tail added to fuselage. Dan dustiepal, Greg W, airacobra and 9 others 12
Dandiego Posted June 27 Author Posted June 27 Rear fuselage mated to central fuselage. Lots o glue and some hefty clamps. Dan Troy Molitor, Greg W, Hubert Boillot and 9 others 12
scvrobeson Posted June 28 Posted June 28 Goodness, that must be a gigantic arrow that you now have on your bench Dan. Matt Dandiego 1
Dandiego Posted June 28 Author Posted June 28 Cardboard wing, just to get a feel for the size...... Dan Jeff T, Polecadt, D.B. Andrus and 11 others 14
Oldbaldguy Posted June 28 Posted June 28 44 minutes ago, Dandiego said: Cardboard wing, just to get a feel for the size...... Dan That cardboard wing looks pretty good. Did you print it as well? Out2gtcha and Dandiego 1 1
Dandiego Posted June 29 Author Posted June 29 43 minutes ago, scvrobeson said: So 3ft by nearly 2ft Dan? Matt Yup........... scvrobeson 1
Hubert Boillot Posted June 29 Posted June 29 The sander on the bottom shelf of the workbench shows that Dan is not your regular-type modeller 😊 Hubert Rainer Hoffmann and Dandiego 1 1
RCPlym Posted June 29 Posted June 29 Those wings are going to soak up a bucket or two of resin! 😁🤣🤣🤣🤣 scvrobeson and Dandiego 2
Dandiego Posted June 29 Author Posted June 29 8 hours ago, Hubert Boillot said: The sander on the bottom shelf of the workbench shows that Dan is not your regular-type modeller 😊 Hubert Quite right Hubert. I use this sander on all of my larger 3d print models. It is a huge time saver. Dan Polecadt 1
Cicchino Posted June 30 Posted June 30 Dan, Makes me want to start cutting out my Tigger vac - nothing beats the B-58's shape! Keep it coming! Regards John Dandiego 1
Dandiego Posted June 30 Author Posted June 30 Front cockpit designed and printed. Modified F-108 seat as well. Still lots of details need to be added to the pit and the seat. Dan airacobra, patricksparks, Out2gtcha and 11 others 14
Rainer Hoffmann Posted July 1 Posted July 1 She'll be a beauty, that much is already evident. Great work, Dan. Cheers Rainer Dandiego 1
