Hoss FL Posted May 12 Posted May 12 (edited) Kit & Subject This build is the Zoukei-Mura 1/32 Focke-Wulf Fw 190A-4, finished as “White 3” of JG 54 on the Eastern Front during the winter of 1942–43 and flown by Oblt. Karl-Heinz Cordes. I was drawn to the subject because of its highly unusual winter camouflage and the challenge of balancing the complex scheme against the structure and form of the aircraft. This was my first Zoukei-Mura kit. The kit is clearly designed with open panels, dropped flaps, and exposed internal detail in mind, reflecting Zoukei-Mura’s emphasis on internal structure and engineering. For this project, however, my primary focus was the camouflage scheme, surface finish, and overall visual presentation of the aircraft rather than extensive super-detailing or opened access panels. As a result, the aircraft was built largely closed up. Surface detail is somewhat mixed. The recessed panel lines are restrained and scale-appropriate, but some areas of the airframe feel simplified, particularly around the gun cover hinges, armored ring ahead of the engine, and several larger exterior surfaces. I also chose not to add rivet detail for this build, as my initial impression was that the aircraft’s complex camouflage scheme would minimize the visual importance of rivet detail. After seeing the completed model in photographs, however, I think additional rivet detail may have added useful surface interest in some areas. Aftermarket additions included Zoukei-Mura metal gun barrels, instrument panel, and weighted wheels, along with Eduard seatbelts. Construction Construction generally proceeded smoothly, though careful planning and dry fitting were required around the wing roots, gun covers, and forward fuselage panels. The landing gear installation is sturdy and well engineered, though it must be installed relatively early in the build process. Surface preparation and cleanup around the fuselage spine and gun cover areas required some refinement to preserve smooth transitions and panel detail prior to painting. Painting & Camouflage All primary camouflage colors were sprayed using Mr. Color lacquers, while weathering and finishing incorporated Abteilung 502 oils, AMMO enamel filters, and Tamiya acrylics. The aircraft was painted using a layered approach intended to represent a winter field-applied camouflage sprayed over an earlier JG 54 summer scheme. After completing and masking the RLM 04 markings and RLM 76 undersurfaces, the upper camouflage was applied using RLM 79, RLM 62, and RLM 70 based on the kit instructions, which appear to align well with available references and period photographs. Particular attention was paid to the camouflage edges, which appear in photographs to be neither fully hard-edged nor broadly soft. To reproduce this effect, a combination of floating masks, selective Blue Tack masking, and limited freehand spraying was used depending on the geometry of each camouflage boundary. The winter white was then applied selectively over the completed camouflage. Rather than treating the white as heavily worn temporary distemper, I approached it as an opaque field-applied winter finish integrated into the overall scheme. The primary goal throughout painting was to maintain the balance between the disruptive camouflage pattern and the structural readability of the aircraft itself. Markings & Decals All primary markings were completed using the kit decals over a GX100 gloss coat. Stencil markings were intentionally kept restrained, with most stencil data applied only to the RLM 76 undersurfaces rather than across the heavily repainted upper surfaces. Weathering & Finishing Weathering was approached gradually and with restraint. Panel lines were treated with Abteilung 502 oil washes using subtly different tones depending on the surrounding camouflage color. A thin blue-gray enamel filter was then applied over the upper surfaces and yellow markings to cool and unify the overall finish. Localized oil rendering and acrylic grime were added selectively around wing roots, engine panels, landing gear, and maintenance areas to introduce subtle tonal variation and operational wear without overpowering the camouflage. Exhaust staining, gun residue, and restrained chipping were added last using translucent acrylic layers and weathering pencils. The overall goal was to portray an operational winter aircraft that had seen regular use in difficult field conditions while still maintaining the distinctive visual character associated with JG 54 aircraft of the period. Final Thoughts This was one of the more challenging camouflage and finishing projects I’ve undertaken in 1/32 scale because of the difficulty in balancing the complexity of the winter scheme against the structural clarity of the aircraft itself. In the end, I’m very pleased with how the camouflage integration, tonal control, and restrained operational weathering ultimately came together. Zoukei-Mura’s Fw 190A-4 is an impressive and highly detailed kit that rewards careful planning and methodical execution, particularly when tackling one of the more unusual JG 54 camouflage schemes. Thanks for looking. Here's the WIP link: Edited May 12 by Hoss FL Add link Castor, Hartmann52, Sasha As and 22 others 24 1
Out2gtcha Posted May 12 Posted May 12 Wow, that looks fantastic! The paint work is lovely Hoss FL and Martinnfb 2
Reuben L. Hernandez Posted May 13 Posted May 13 Beautifully executed of a complex winter scheme. Thanks for sharing. Hoss FL and Martinnfb 2
nmayhew Posted May 13 Posted May 13 i can't see the pics? It's not the blue square / imgur problem btw
williamj Posted May 14 Posted May 14 Just lovely. Have a soft spot for anything Luftwaffe in winter camo. Hoss FL and Martinnfb 2
Greif8 Posted May 15 Posted May 15 Beautiful work! The camo scheme looks fantastic! Ernest Martinnfb and Hoss FL 2
PEYSSON Gilles Posted May 17 Posted May 17 Good evening, Your FW190 looks fantastic, both in terms of the assembly and the excellent paint job. I like it ... Gilles Hoss FL 1
