8 hours ago, PEYSSON Gilles said:
Hi Tom,
Your panel is very beautiful as your cockpit with nice details :clap2:
Gilles
Thank you Gilles!
Cheers,  Tom
9 hours ago, spyrosjzmichos said:
Really nice work Tom!
Yours and Kev's builds are really making me want to get this kit!
Thank you! It’s been a really fun build so far.
Cheers,  Tom
On 5/18/2026 at 7:51 AM, Out2gtcha said:
Looking Grand Tom!
Im really digging the "lots of kit for your buck/quid" aspect of these kits for sure.
On 5/18/2026 at 12:24 PM, Shoggz said:
Great model - great subject!
Thanks Brian and Richard, now that my wifi has been restored I’ll be posting an update soon!
Cheers,  Tom
And here's that update: I've closed up the fuselage after assembling the exhausts and tailwheel structures:
17
The fit was exemplary, and I just needed to sand down some short segments along the upper and lower aft fuselage. Something to keep in mind with this kit is the plastic is relatively soft so it's easy to create scratches where you are sanding. I'd recommend starting with a finer grit than you might usually use. This will actually save time because you won't have to go back and fill in the scratches.
I was pleasantly surprised that more of the cockpit is visible than I envisioned.The details are there if you have a penlight!
15
There's a fine seam on either side of the cockpit where the fit could be better but it's an easy fix with Vallejo, Perfect Plastic Putty, or even Elmers glue.
Something else to keep in mind is that you will have to fill some seams along the cowling:
18
I've been using the Phoenix Publications recent release as a reference, but there's abundant information on the web as well.
I've moved on to the landing gear bay and the wings. I'm actually enjoying adding the lead wire, and the kit instructions are very helpful with this. I'm also pleased to see that the fit of the upper and lower wing sections to the fuselage looks very good when dry fitted.
Cheers,  Tom
Nice progress, Tom! Don't forget that there's a reciprocal pair of seams on the underside of the forward cowl that need filling. I didn't get things to fit quite as well as you did, so had a bit more work to do.
Kev
7 hours ago, monthebiff said:
Nice update Tom, this is a fabulous looking kit.
Regards. Andy
Thank you Andy, I appreciate the encouragement! It’s been a joy to build so far.
Kev
Thank you Kev! You are the trailblazer and I appreciate you leading the way. Once I get the wings fitted I’ll be getting to that lower seam.
38 minutes ago, RCPlym said:
More please!
The more I'm seeing of this kit underway, the more impressed I am with it.
I’m happy to oblige! It’s such a great kit, you can tell it’s a labor of love by DBMK. Note that I’m leaving for Malta next week so will be picking up again mid-June.
Cheers,  Tom
Cheers,  Tom
Tom,
My wife and I were in Malta earlier this month; I think you will love it. Unfortunately I did miss the aviation museum, but we found more than enough to do in the 4 days we had. We made the quick trip over to Sicily from there.
Happy to offer some recommendations if you are interested.
Regards
John
25 minutes ago, Cicchino said:
Tom,
Regards
John
Thanks John! PM inbound.
Cheers,  Tom
Another brief update: I added wiring to the landing gear bay using the diagrams in the instructions using 0.015" (0.4 mm) lead wire.
20
19
The process was actually more enjoyable than I thought it would be, and took just over an hour. Now I have to finish the rest of the gear bay!
Cheers,  Tom
