Out2gtcha Posted May 7 Posted May 7 Ok thanks gents. Very little of anything like that on the Hornet for obvious reasons but its nice to know they showed some restraint. Uncarina 1
antonlemmy@yahoo.com Posted May 7 Posted May 7 On 5/6/2026 at 6:42 PM, Out2gtcha said: Now if we can JUST get these guys to make a 1/32nd IM F7F!! Yeah … I remember your battle with the HpH kit! Out2gtcha 1
Out2gtcha Posted May 8 Posted May 8 1 hour ago, antonlemmy@yahoo.com said: Yeah … I remember your battle with the HpH kit! Haha so do I......... She stares st me longingly fron the display case every day. I will get back and finish her eventually. Kagemusha 1
Uncarina Posted May 8 Author Posted May 8 Getting this thread back on topic, I realized that the BarracudaCast gunsight had some slight but noticeable differences, so I made some modifications: For the side placard I used an Airscale decal. I'm pretty pleased at the modification overall, but I might go back and redo the gauge markings. Cheers, Tom Kagemusha, AngryJazz_Models, Landrotten Highlander and 15 others 18
Out2gtcha Posted May 8 Posted May 8 Nice work Tom! I too used some Airscale decals to supplement my Hornet. Uncarina 1
Uncarina Posted May 9 Author Posted May 9 3 minutes ago, Out2gtcha said: Nice work Tom! I too used some Airscale decals to supplement my Hornet. Thanks Brian! I see an airscale compass decal in my future, and I'm unashamedly using Peter's 1/18 Sea Fury build as a reference. Cheers, Tom Out2gtcha and mozart 2
mozart Posted May 9 Posted May 9 I’ll be keeping an eye on this one Tom, and using Peter’s build as the ultimate reference is a wise move, I did exactly the same with his Fury biplane. Uncarina, Kagemusha and geedubelyer 3
scimitarf1 Posted May 9 Posted May 9 On 5/6/2026 at 11:40 PM, Uncarina said: Thanks Brian! I do as well. They remind me of the Special Hobby Tempest and Whirlwind kits but with better fit and instructions. Sincerely, Tom And no anhedral on the centre section! Uncarina and Iain 2
Uncarina Posted May 9 Author Posted May 9 6 hours ago, mozart said: I’ll be keeping an eye on this one Tom, and using Peter’s build as the ultimate reference is a wise move, I did exactly the same with his Fury biplane. Glad to have you checking in! Cheers, Tom Out2gtcha 1
Uncarina Posted May 10 Author Posted May 10 Moving onto the rest of the cockpit, I assembled the sidewalls, addin a blend of plastic parts and photoetch. The fit and engineering is impressive, and the only modification I made was to replace plastic cables with lead wire: I also assembled the seat, adding texture and more of a three dimensional look by using Tamiya putty diluted with thinner. This also removed the quilted effect on the bottom cushion which I believe is more prototypical: Moving on I'll be finishing up cockpit assembly, spray everything with Tamiya Rubber Black, then add weathering effects, paint details and add placards and stencils. This has been a lot of fun to build so far! Cheers, Tom mozart, ROM, BarryWilliams and 15 others 18
LSP_Kevin Posted May 10 Posted May 10 Nice work, Tom. I believe for an in-service aircraft, there wouldn't be any seat cushion at all, as it's space reserved for a parachute pack. Kev Uncarina, KiwiZac and Martinnfb 3
Uncarina Posted May 10 Author Posted May 10 7 minutes ago, LSP_Kevin said: Nice work, Tom. I believe for an in-service aircraft, there wouldn't be any seat cushion at all, as it's space reserved for a parachute pack. Kev Thanks Kev! Good to know. I might be able to correct this. Cheers, Tom LSP_Kevin, Jim Barry and Martinnfb 3
Kagemusha Posted May 10 Posted May 10 On 5/10/2026 at 9:44 PM, Uncarina said: Thanks Kev! Good to know. I might be able to correct this. Cheers, Tom There's a replacement early type seat, and spinner, from skunkworxmodels@gmail.com Out2gtcha, Uncarina, KiwiZac and 4 others 7
Uncarina Posted May 11 Author Posted May 11 5 hours ago, Kagemusha said: There's a replacement early type seat, and spinner, from Aerocraft, out of stock currently due to relocation. Thank you, I saw this as well. I’ve managed to make a correction but a primer coat will be the judge! Cheers, Tom Martinnfb and LSP_Kevin 2
Greif8 Posted May 11 Posted May 11 Very nice start Tom! The IP looks great and the modifications to the gunsight are really well executed. The cockpit looks like it has some nice detail. Ernest Uncarina and Martinnfb 2
