Uncarina Posted May 6 Posted May 6 Throwing my hat into the ring of DBMK kit builds! I'll be building a Canadian subject, either one of the options from the kit or a subject from the Uprise Decals sheet. In the meantime, I've gotten started. The build starts with the instrument panel, and I've chosen to use the decals over the kit part vs. using photoetch. I prefer the 3-d look of the original panel, and the decals conformed flawlessly, just having a tendency to fold in on themselves. However, they are very durable and some gentle pursuasion set them in order. After painting the panel Tamiya Engine Black I used Tamiya Clear as a gloss, then applied the decals. I used MicroSol and Set but they probably would have conformed anyway. I finished off with a flat coat, then painted Future onto the gauges: Here you can see I've also moved onto the gunsight assembly. I had a leftover gunsight from BarracudaCast that had slightly better detail and decals, so I used this instead. I'lll be holding off on applying the panel glass until later in the build. Now onto the rest of the cockpit! Cheers, Tom Madmax, Gazzas, Martinnfb and 22 others 25
Out2gtcha Posted May 6 Posted May 6 Neat! I know the Hornet might not quite be up to the same exact standards of the (high pressure?) Sea Fury, but I really dig these DBMK kits so far. Nice OOB details that you dont have to add much to except a tiny bit of modeling skills, and/or some new markings if wanted. Cant wait to see more! Uncarina, scimitarf1 and Sasha As 3
Uncarina Posted May 6 Author Posted May 6 1 minute ago, Out2gtcha said: Neat! I know the Hornet might not quite be up to the same exact standards of the (high pressure?) Sea Fury, but I really dig these DBMK kits so far. Nice OOB details that you dont have to add much to except a tiny bit of modeling skills, and/or some new markings if wanted. Cant wait to see more! Thanks Brian! I do as well. They remind me of the Special Hobby Tempest and Whirlwind kits but with better fit and instructions. Sincerely, Tom Out2gtcha 1
Out2gtcha Posted May 6 Posted May 6 Just now, Uncarina said: Thanks Brian! I do as well. They remind me of the Special Hobby Tempest and Whirlwind kits but with better fit and instructions. I think so too Tom...............accuracy first and foremost, but a very close 2nd for me is fit and buildability. Uncarina 1
Out2gtcha Posted May 6 Posted May 6 Now if we can JUST get these guys to make a 1/32nd IM F7F!! Ginja Ninja and Uncarina 1 1
Uncarina Posted May 6 Author Posted May 6 5 minutes ago, Out2gtcha said: Now if we can JUST get these guys to make a 1/32nd IM F7F!! I want that for you Brian! Cheers, Tom Out2gtcha 1
Out2gtcha Posted May 6 Posted May 6 Its a big BIG boy. Dont know if it will ever happen..... Uncarina 1
LSP_Kevin Posted May 6 Posted May 6 Nice start, Tom! I better get a move on. I've had my kit for months, and guys who have just received theirs are already catching me up! Kev Uncarina, geedubelyer and Out2gtcha 1 1 1
RCPlym Posted May 7 Posted May 7 1 hour ago, Out2gtcha said: 1/32nd IM F7F!! In any media for me! That is one US Navy/Marines prop job I could definitely attack with glue! I'll never forget the one I saw running up it's engines at the end of the runway at RAF Wroughton decades ago! What a beast of an aircraft! Out2gtcha 1
Out2gtcha Posted May 7 Posted May 7 Out of curiosity, how prevalent are the rivets on the Sea Fury? RCPlym and Uncarina 2
Uncarina Posted May 7 Author Posted May 7 2 hours ago, LSP_Kevin said: Nice start, Tom! I better get a move on. I've had my kit for months, and guys who have just received theirs are already catching me up! Kev Thanks Kev, and you are the pathfinder! Cheers, Tom LSP_Kevin 1
Uncarina Posted May 7 Author Posted May 7 33 minutes ago, Out2gtcha said: Out of curiosity, how prevalent are the rivets on the Sea Fury? On the aircraft itself? Cheers, Tom Out2gtcha 1
Out2gtcha Posted May 7 Posted May 7 6 minutes ago, Uncarina said: On the aircraft itself? Cheers, Tom On the DBMK model. I know the real one does have them, but they seem so flush in some areas as to nearly not be seen at all. Uncarina 1
LSP_Kevin Posted May 7 Posted May 7 1 hour ago, Out2gtcha said: On the DBMK model. I know the real one does have them, but they seem so flush in some areas as to nearly not be seen at all. You can see some of the rivet detail in my own build, Brian. It's a very petite mix of raised and (mostly) recessed detail, and is very nicely done. Kev Uncarina, geedubelyer, Out2gtcha and 1 other 4
Uncarina Posted May 7 Author Posted May 7 19 minutes ago, LSP_Kevin said: You can see some of the rivet detail in my own build, Brian. It's a very petite mix of raised and (mostly) recessed detail, and is very nicely done. Kev I agree with Kevin. The rivets are reminiscent of the Tamiya Spitfires. Cheers, Tom geedubelyer and Out2gtcha 2
