Popular Post Haggis Posted February 12 Popular Post Posted February 12 Hi chaps. Here's my latest, a built test shot of the upcoming Typhoon Car Door by Airscale. This has an injection moulded fuselage and tailplanes (plus clear bits) and everything else is 3D printed. Check out the build thread for phots of the build process. Paint was mainly Tamiya with MRP for the markings (Aqua for the blue), all main markings and stencils were sprayed using the indispensable 1 Man Army masking set (another prototype) and the squadron (56, my old Tornado F3 unit) codes and serials were cut on my Portrait 3 cutter. Weathering was an oil sludge wash followed by Oil Dot Weathering and dust using Ammo Oilbrushers. Look out on the YouTube channel for the build series coming soon. I did something a little different for the IFF aerials. I drilled holes in the fuselage and tailplanes, then threaded the Modelkasten elastic thread into thin brass tubing which was then inserted into the holes. Worked a treat! Source: IWM Zola25, Model_Monkey, Pavel Vacek and 49 others 47 5
Polecadt Posted February 12 Posted February 12 A truly beautiful build of a brutal beast👍 Martinnfb 1
mozart Posted February 12 Posted February 12 (edited) Super finish, congratulations on a very fine looking Tiffy. Edited February 12 by mozart Martinnfb 1
Shoggz Posted February 12 Posted February 12 Terrific Tiffy Jamie. Look forward to seeing it on the YouTubes! Martinnfb 1
LSP_Ray Posted February 12 Posted February 12 3 hours ago, Haggis said: Hi chaps. Here's my latest, a built test shot of the upcoming Typhoon Car Door by Airscale. This has an injection moulded fuselage and tailplanes (plus clear bits) and everything else is 3D printed. Check out the build thread for phots of the build process. Paint was mainly Tamiya with MRP for the markings (Aqua for the blue), all main markings and stencils were sprayed using the indispensable 1 Man Army masking set (another prototype) and the squadron (56, my old Tornado F3 unit) codes and serials were cut on my Portrait 3 cutter. Weathering was an oil sludge wash followed by Oil Dot Weathering and dust using Ammo Oilbrushers. Look out on the YouTube channel for the build series coming soon. I did something a little different for the IFF aerials. I drilled holes in the fuselage and tailplanes, then threaded the Modelkasten elastic thread into thin brass tubing which was then inserted into the holes. Worked a treat! Wow, Haggis, beautiful! May I post this one on the website, too? Martinnfb and Kagemusha 2
alaninaustria Posted February 13 Posted February 13 Very nice work Jamie! Beautifully done! Cheers Alan Martinnfb 1
Rod Bettencourt Posted February 13 Posted February 13 Whoa!! Dang that is awesome! So scale looking.Thank you for sharing this. Rod Martinnfb 1
Mal_Belford Posted February 13 Posted February 13 Yaih...and yes it looks fantastic imo, very very nice indeed, and lurked the build thread when it were ongoing. Like it very much. Martinnfb 1
Martinnfb Posted February 13 Posted February 13 Can't imagine better promotional build than this one , absolutely splendid. Bravo! Cheers Martin Martin Kubis 1
