Wanted to show you progress on P-40 from GWH. Kit is just superb. Their next F6F is for me must-have. I can only encourage them for more.
I added magnet on propeller tip and on propeller itself.
?ugs4mih
?9rihlye
?5f7y6zv
Then I remade headrest (kit one is just oversized) with epoxy putty.
?9xq6wxa
?vcfsxnn
Cockpit frame fits perfectly.
?fcok3zy
Fuselage to wings joint is very clever, as you can see filler is needed only in rear fuselage.
?vj6uetr
Edited by shadowmare
Really nice work.  I love what you did with the headrest.  Are you planning something similar with the wheel well canvas?  Kit part looks ok but is noticeably thick around the opening.
Thank you, no really for me it's ok, there are other things I want to spend extra work.
?f853e1i
?ftb80fl
Interior is perfectly done, and fuselage halves have no problem to join.
?u2b1k0y
To make elevator more sturdy I glued metal rods. There is an opition to make it movable but it's a bit too delicate thing so it will be unpositionable.
?i808pz9
Then I decided too open some hatches underside it will be pity to close those installations.
?9agm6bj
?iai9hsz
?6lt6kx9
PE in box is really thin, I decided to glue it on some plasticard. It should be done in titanium i guess to make less than 1mm thickness sheet durable. It's opposite to Tamiya their PE is armour grade thickness.
Cockpit finished, Eduard 3D decals used. What is unfortunate is fact that it is lacking many details. Basing on this photo I added some.
?4gh17rp
?94xnoxy
?pqdj4ur
?o1a9vhr
?f8a3hw7
?mjxsejc
?9bha2o6
Testing canvas effects.
?j328dcf
Surfing on net I found this info about radio equipment on Britmodeller:
Quote
They were delivered wired for RAF radio equipment but without the radio transmitters and receivers. AVG ground crew stripped out the RAF wiring at Kyedaw airfield in Burma and installed the US-manufactured commercial RCA-7-H radio transceiver as used in Piper Cubs.
Obviously for me kit is lacking radio box, does anybody have more info about it?
?ihdesvs
Airfix P-40 in 1:48 have it (Eduard PE glued), but I assume that is not correct for AVG.
Small update, fuselage plus wing merged together. This was a real beauty, prettier than later P-40s in my opinion.
?ohnlh32
Kit has a real-life sliding canopy but afer few tryouts 2 nasty scratches appeared 😵‍💫.
?g46ulro
This was coused by those 2 suckers:
?w1immhp
It is not a big thing because 2 glasses behind cockpit needs polishing too.
?xch8sdm
I made better joint of ailerons to wings using metal rods, kit one exist in very delicate form.
?eixg51m
There is some useful research regarding AVG Hawk 81-A2 pecularities
https://scalemodels.ru/modules/forum/viewtopic.php?t=92748&postdays=0&postorder=asc&start=0
As concern "RCA-7-H" - there is obviously communication equipment name misinterpretation. RCA - just the brandname. The communication set consists of separate receiver (e.g. AVR-7/15/20 receiver and AVT-7/15/20 transmitter). There were two separate boxes inside radio compartment and two remote control panels in the cockpit.
