She'll be a big girl.
It's not easy deciphering the silhouette and outline of your design from those images Steve.
The rendered sheen and semi translucent effects appears to disguise some things.
Are you able to block in the shape with your software to render the airframe as solid?
Ideally, orthographic views would be useful to see the overall airframe shape/proportions.
That needs to be right - the detail work is very much secondar.
  • 1 month later...
On 1/2/2026 at 3:31 PM, Iain said:
That looks very nicely detailed - I may be tempted when done!  🙂
Iain
Detailed it is indeed and very nicely.
Some of said detail is exquisitely fine and problematic removing some parts from the supports intact. It has taken me just over three hours to remove the cockpit, seats and nosegear and other parts from the one print plate.
A few tiny 'wires' (sub 0.5mm dia) and a gauge from the windscreen departed this mortal coil and will be needing replacing or refitting, but I am very impressed.
Some BIG parts are printing overnight.
Will post some images when the runs are completed and I have assessed the parts fit. If they are as good as the detail, it will be a beauty.
No build of it as of yet due to the Lightning going forward.
Steve of Aladdin has also scaled up a set of their 1/48 Jaguar parts to 1/32 for me and again, exquisite results.
  • 1 month later...
  • 2 weeks later...
