Airfix designed the power egg to be assembled in two ways, with open and closed cowling. Instead of downsizing the engine, they have you to sand it downs a bit in case you’re closing the cowling around it. The whole process is trouble free.
I managed to crack the lower seam line as I was drilling a missing hole for the oil reservoir drain/ purge valve. Not a biggie, still have to replaced rivet lines.
The intake received some basic details and welding seams(to be tamed). Ventilation vents on the sides need some work ,or straight out aftermarket ones. @airscale@Roy Sutherland
IMG_8150.thumb.jpeg.6fffa607d07cca2e046dIMG_8151.thumb.jpeg.8ef1bca04d7281b04f2bIMG_8152.thumb.jpeg.fc6c4cca3aea96cd41ef
Edited by Martinnfb
10 hours ago, Martinnfb said:
ModelMonkey spinner on AIRFIX base plate that was slightly tapered.
 IMG_8156.thumb.jpeg.10268dab12300032c2c4
WOW!   kind of a big difference there. don't think I know what to say.
