Hi all,
I have a question about how you guys handle the following challenge:
My assumption is that we all work under some kind of light when building models and then we take photos under optimal and controlled light conditions.
However, we all know that our models don't look exactly the same when under insufficient light, and some of those nice and subtle colour modulations, effects, etc. get lost. This is especially the case at exhibitions where lighting is usually not sufficient.
Do any of you have any tips to balance things out while at the same time not overdoing it on the actual model?
This kind of lighting (below) is rare at exhibitions, at least in my experience:
Best,
Nikola
Let’s face it. NO photo will ever succeed to capture the essence of the real thing, artifact, work of art or anything else.
It’s the reason why museums exist. 😇
On 11/20/2025 at 10:21 AM, mozart said:
Your assumptions are flawed in my case, I always photograph my finished models outside in natural light in chosen conditions:
Even if I use a photographic background, it’s still outside in natural light:
Have to say, they look real enough that it looks like i could climb in, spark it up, and take off. Great work on the models AND the photography!!
Don
The compromise required to satisfy both lighting criteria might ruin the effect in both.
If one builds the model to be displayed in high quality, bright lighting then colours and tones can be applied realistically and still look good. If the contrast, highlights and lowlights are exaggerated to make detail pop and look better in dim, low lighting conditions that could also look good in that circumstance.
Finding the middle ground to suit both bright and dim light could easily fail in both scenarios. Too much in one, not enough in the other.
Perhaps building so the modeller is happy with it on display under their own conditions might be the best solution?
At shows we are used to the lighting being poor and generally make allowances because of that.
Cheers,
Guy
Colour temperature of ambient light will make huge differences to results.
I use 'daylight' lighting between 5000k and 6000k for both my day job and for model making so I have a benchmark to work out any colour correction for photos (not bothered with digital, but for the film I work with it is important)
Getting models to look 'real' takes a lot of skill to control depth of field and perspective and the photo equipment used will have a massive impact on results.
I love to create the real shot with my models. Sunny days and an old Navy base are ideal! The phantom and the Bearcat  sit on a power transformer of some kind. The Fury is similarly sitting on some concrete power box in another part of the base.
pm4VmvDgj
pmCBOLq9j
pmlgfVUwj
