RCPlym Posted March 19 Posted March 19 3 hours ago, Ali62 said: Hi Kev the engine set will be available from myself through Aerocraft Models, will get it up on my website in the next few days. There will be a 3d printed seat and a 3d printed spinner, both as one little set as well. I shall make a wider announcement when they appear. Chris, Will and I have sorted out the deal, and I have got all items printing really well. Excellenty! 👍👍👍
mozart Posted March 19 Posted March 19 On 3/18/2026 at 12:00 AM, LSP_Kevin said: Just a couple of quick notes before I forget. Firstly, Roy Sutherland tapped me on the shoulder and informed me that the seat padding is a post-war warbird feature, and not present on operational aircraft. It therefore should be removed if you're chasing complete accuracy. Secondly, the source of the 3D-printed engine I mentioned earlier is Chris Sargent, who also tapped me on the shoulder! (I'm just not sure if it will be offered directly by DBMK as an upgrade item, or by Chris as an aftermarket item - I'll endeavour to find out.) Kev, who's off to put some ice on his shoulders. Not doubting Roy Sutherland at all, but I would be interested to know his evidence for this, especially given that the quilted seat definitely existed on the Typhoon and probably Tempest. Perhaps the engine was smoother so less vibration? LSP_Kevin and KiwiZac 2
scimitarf1 Posted March 19 Posted March 19 I think Roy may have been alluding to the cushion rather than the back. You can leave the cushion out. mozart, Uncarina and LSP_Kevin 3
LSP_Kevin Posted March 19 Author Posted March 19 25 minutes ago, scimitarf1 said: I think Roy may have been alluding to the cushion rather than the back. You can leave the cushion out. Yes, I believe so, as he mentioned something about needing space for a parachute pack. Kev
RCPlym Posted March 19 Posted March 19 I'm beginning to think about getting one, although I wasn't going to get one as there's a superb Fisher Model & Pattern one in my tower...
LSP_Kevin Posted March 21 Author Posted March 21 Another day, another update. I managed to get the upper forward fuselage part installed, which completes the fuselage assembly, other than the cowl ring: This turned out to be a little more tricky than I anticipated, and I ended up having to glue it in sections, as the further forward I went, the more the parts tended to splay and drift. In the end, it turned out pretty well, though not as tight as I'd hoped. The only real gap I ended up with should be pretty straightforward to deal with: You can also see the area Will referred to earlier, which has been moulded without any rivets, to be instated by the modeller should they so desire. I haven't decided yet. From here, I could move on to the main wheel bays, and all the myriad detail parts supplied for them. The work I'd already done in this area turned out to be back-asswards - at least according to the instructions. I glued some of the structural elements to the inside of the lower wing, as I especially wanted the bulkhead that sits between the two wheel openings to be located accurately in the lower wing. So I built the other elements around it, but the instructions have you install them into the upper wing. I don't think it matters much either way, but some of the fiddly detail parts would be easier to add prior to gluing them in at all. In particular, if you decide to add the wiring that connects up all that fancy detail, for which the instructions provide a handy diagram, then your task will be much easier if you haven't already glued the centre section in place: Yikes! I'll attempt to add at least some of the pipe work shown here, but will have to see how feasible it is with the part already in situ. Now comes my major screw-up of the day. I found the instructions for adding the main gear leg attachment points a tad confusing, and ended up installing them in the reverse orientation: I knew something was off, but couldn't figure it out. By the time I did, I had to resort to sawing the parts out, cleaning them up, and reinstalling them in the correct orientation: This of course wasn't the best approach to ensure accurate fit and positioning, so I'm sure this will come back to haunt me! Personally I think this area of kit, while superbly detailed, is a little over-engineered, and not as sure-footed as other areas. More soon! Kev Greg W, Landrotten Highlander, KUROK and 19 others 20 1 1
geedubelyer Posted March 21 Posted March 21 Glad you spotted things and got everything corrected Kev. LSP_Kevin 1
PHBIO Posted March 21 Posted March 21 (edited) On 3/19/2026 at 7:17 PM, RCPlym said: Excellenty! 👍👍👍 For an international buyer, bundle (engine+kit) might be more convenient..... Edited March 21 by PHBIO
Greif8 Posted March 21 Posted March 21 Good eye spotting the issues and correcting them Kev. I think you will be fine. Ernest LSP_Kevin 1
JayW Posted March 21 Posted March 21 Coming right along Kevin. What a beast of an aircraft - I can't wait to see it in Aussie livery. This clear UV resin you speak of. What is this stuff? LSP_Kevin 1
LSP_Kevin Posted March 21 Author Posted March 21 7 hours ago, JayW said: This clear UV resin you speak of. What is this stuff? The stuff I use is from Gaianotes, and is actually supposed to be a UV-curing adhesive. I bought it from Japan many years ago, at great expense, when I first heard of it. There are many cheaper and more accessible alternatives these days. Since it's a gel, you can create small shapes with it that will hold long enough for you to cure them in place with a UV torch - great for landing lights, etc. Kev RCPlym, mozart and Uncarina 3
scvrobeson Posted March 23 Posted March 23 Helpful diagram on the wiring, and the kit looks like it's going together very well Kev! Keep it up! Matt geedubelyer and LSP_Kevin 2
LSP_Kevin Posted March 29 Author Posted March 29 7 hours ago, alaninaustria said: Any update on this beautiful build Kevin? Cheers Alan There will be soon enough, but I'm just distracted by some airliner builds, and stalling on doing all that wiring in the wheel bays - much harder now that they're already assembled! Kev Uncarina 1
