5 minutes ago, mozart said:
Tolga is also doing a test shot build on Britmodeller but doesn’t seem to have encountered your issues Kev. I don’t know if that’s good news or not! :rolleyes:
Well, there are three main points to make as a response. Firstly, there isn't a modeller alive who's as capable as I am at screwing up simple things. (It's not even up for debate.) Secondly, Tolga is a much more accomplished model builder than I am, and the evidence for that is all over these forums (even if, sadly, his Sea Fury build is not). Thirdly, Tolga doesn't really show detailed steps in his build about how things went together, so it's not clear whether any problems were encountered.
My special skill isn't making good models, it's recovering from dumb mistakes. So I'm happy enough to have once again put that skill to use!
Kev
5 hours ago, LSP_Kevin said:
As you can see from the photo, they don't flop into place from above, but rather, need to be slid into place from the side. And it was then that I realised that the instructions call for you to do this before you fit the wing spars! That said, I still can't see how that would make a difference, as it's actually the wing-fold bulkhead blocking the parts from moving into position, not the wing spars. In any case, no one else has called this out as an issue, so I can only surmise (yet again) that I screwed something up here
Kev,
There is a build on YouTube - maybe Model Minutes? who encountered the same issue. I made a note of it when I saw it so I don't think you are alone. He also had the same gap on the wing fold line you did, but it looks like you found the culprit where he did not. I have been making notes all over my instructions. It sounds like maybe some of the wing fold bulkhead could be left out ( or at the very least trimmed) for the extended wings? Appreciate you blazing the trail as I hope to have mine on the bench soon.
Regards
John
Thanks, John. Good to know that I’m not alone! I’ve been following Model Minutes’ posts sporadically on Facebook, but didn’t see that he had similar issues. I think following the instructions to the letter is vital with this kit, as my build is a testament to what happens when you don’t!
Kev
1 hour ago, Cicchino said:
Kev,
Regards
John
I suggest keep the spars and leave our the bulkheads
Want to make a bet?
I recently found I am incapable of counting to eight having completely missed two elements from a decal sheet that has now been printed... 😂😂😂😂😂😭😭😭😭😭
I have also recently printed duplicates of some major 17+hr prints... 😭😭😭😭😭
Oh! And I forgot - I also scratchbuilt TWO starboard sets of wheel bay innards for Frank's Lightning ... All the pipery and wiring nicely formed... Ahhh well. Age is creeping up. 🙄
Edited by RCPlym
1 minute ago, RCPlym said:
Want to make a bet?
I've screwed up a Bandai kit. Twice.
Case closed.
Kev
Case closed.
Kev
Which one? I'll give one a go for giggles!
This one:
https://www.scalemates.com/kits/bandai-0202289-resistance-x-wing-fighter--966474
... for which I had to buy another kit to replace the part I destroyed ...
And this one:
https://www.scalemates.com/kits/bandai-0196692-snowspeeder--940485
That said, they both turned out OK:
Kev
34 minutes ago, LSP_Kevin said:
This one:
And this one:
Kev
Ah. I give in. You win. I ain't going down the Star Wars models rabbit hole... 😂😂😂🤣🤣🤣🤣🤣
And the ones you buggered up turned out fine! 👍👍👍👍
Edited by RCPlym
