Interesting to see that large panel on the port side as separate. I think that's the first time I've seen it done in a kit.
Matt
Matt
Is that to avoid sink marks?
I can wait till this reaches normal outlets but I am definitely buying one.
Tony
Pleased to see that the pilot's emergency escape panel on the starboard side, which is not a door, is not moulded separately. Hopefully this will reduce the number of people who think it is a door (which it is not) and therefore show it open on the ground, which it never is, because it's not a door.
Did I mention that it's not a door?
Never? There are many images of that one shown in an 'open' condition.
It’s a bit like another Hawker non-door which isn’t a door…..the Typhoon. Originally designed with doors either side, the port one was sealed as part of the attempts to stop/limit carbon monoxide poisoning. So that’s a non-door door too!
Just to annoy you, if I am so lucky as to get one of the test shots, I will cut the door open and post it as such.  😀  Just kidding.
28 minutes ago, mozart said:
The port one was sealed as part of the attempts to stop/limit carbon monoxide poisoning
The door to another realm?
Open sesame!
Under maintenance, I expect, but it was not a normal entry/exit door a la Spitfire. The pilots entered and exited on the port side, where the footsteps are.
And clambering up that wing and getting your leg over (ahem) into the office isn’t as easy as on a Spit!
I don't dispute that at all, but the use of 'never open' doesn't apply. There are also many shots available where only the one door is open.
So having the door open is perfectly valid.
Easy for us young 'uns! 😂😂😂
16 minutes ago, mozart said:
Not so easy on your 75th birthday! But honoured to be invited into the front seat after our flight.
You have 12 on me.😉
I managed to get a sit in the "Last of the Many" and whatever Spitfire was with it when I was young and silly at age 23.
I shan't repeat what was said when I said to the BBMF Lancaster pilot "Can I have a look inside this olden days plane?"... 😬
