14 minutes ago, DugyB said:
As tempting as this fella is I’ll hang out for the hard wing version, or MKI late 🤔 what’s it proper title …
Metal wing perchance? :huh:
5 hours ago, geedubelyer said:
I just got the notification email Max.
Living in the south you're closer to New Zealand so mine obviously took longer to arrive. :coolio:
After Amazon crashed earlier, maybe they had to resort to cleft stick runners....
Roger that, metal win, I can assume it’s on the not to far horizon 🫡
Edited by DugyB
I'll pass on this one.  If when they release a metal winged Hurricane with a slightly larger range of possible markings, I will most likely get one.  Hopefully BEFORE that though, I'll be preordering a Mk. Vb/c Trop.
Edited by Juggernut
I bought some decals for a Polish №317 City of Wilno Sqn Mk I aircraft from early 1941. The serial was V7013. Anyone know which that machine was: fabric or metal wing?
If the latter, which its V prefix serial suggests (?), I'll hold out for the "late Mk I" too, or do the Czech №312 Sqn bird flown by Alois Vaŝátko, serial L1926.
Tony
Putting Hurricane I changes into the one list.  First order 600 L serials, second order 300 N serials, third order 1,000 P serials split 500 Gloster, 500 Hawker, with the Hawker section gaining another 24 P, R and W serials as replacements for foreign orders.
Hawker:
61st aircraft L1607 first factory fitted ventral spine (Unconfirmed), taken on charge 6 July 1938.
331st aircraft L1877 fitted with Metal wings for development, taken on charge 16 March 1939
363rd aircraft L1909 first factory fitted Merlin III, taken on charge 20 April 1939
434th aircraft L1980 first factory fitted two pitch propeller, taken on charge 12 June 1939
480th aircraft L2026, marked metal wing, Rotol propeller, development, built in July 1939, taken on charge 28 October 1939
481st and 482nd aircraft L2027, L2028 marked metal wing, both taken on charge 20 July 1939, L2027, L2028, L2039, L2045, L2046, L2047, L2055, L2058, L2065, L2066, L2067, L2068, L2077, L2078, L2079 marked metal wing (July/August 1939)
668th aircraft N2397 and subsequent fitted with TR1133, taken on charge 9 November 1939
685th aircraft N2426 marked as last aircraft of the order with fabric wings, taken on charge 14 November 1939, but see below
901st aircraft P3265 and subsequent fitted with Rotol propellers except for at least one batch meant for tropical service which retained the two pitch DH propellers, P3265 was for development, built in February 1940 but not officially taken on charge until 31 May 1940.
June/July 1940 Hurricane I built with fabric wings at Brooklands P3714 to P3717, P3737 to P3739, P3755, P3757 to P3761, P3767, P3768, P3770 to P3774, P3854, P3858 to P3869, P3872 to P3875, P3882 to P3890, P3897 to P9303, P8809, P8810, P8816 to P8818, R2680, R2681, V7200 to V7209, V7222, V7224 to V7235, V7276, V7281.  Total 85 aircraft.
The Ministry of Aircraft Production Price Books indicate the 300 N serials were 35 Fabric wing, 253 metal wing, 12 sold to other customers (Yugoslavia, last 12 serials so expected to be metal wings)  The metal wings cost £1,210 the fabric ones £1,008. N2426 is the 85th of the N serials batch meaning 35 out of the first 84 had fabric wings.  If you go by taken on charge dates it was part of a group of 5 taken on charge 14 November 1939, the 57th to 61st N serials to do so.
A further complication is the 20 aircraft N2318 to N2337 were the first built at Langley, some had fabric wings, delivered from October 1939 to January 1940, time wise lagging behind later serial deliveries from Brooklands. Langley also built N2453 to N2502 and N2592 to N2564 again time wise lagging behind later serial deliveries from Brooklands.  For the P serials it was 280 Brooklands, 220 Langley.
It appears from L2026 (480th aircraft) to N2426 (685th aircraft) there was probably an increasing percentage of metal wing Hurricanes built.
Gloster production started in October 1939 with Merlin III, two pitch propeller, metal wing, the 100th built, P2681 and subsequent fitted with TR1133 radio, the 101st built, P2682 and subsequent fitted with a Rotol propeller, P2681 and P2682 taken on charge 27 February 1940
Date wise production starts in December 1937 with Merlin II, fixed pitch propeller and fabric wings, Merlin III from April 1939, De Havilland two pitch from June, a mixture of fabric and metal wings July to November except a handful of possible laggards from Langley, from then on metal wings except the mid 1940 batch, mid November 1939 (Hawker) and late February 1940 (Gloster) change over to TR1133, late February 1940 change over to Rotol propeller.
Shoggz' inbox was not full. Mine was. No harm was intended to Shoggz' fine reputation.
Compensation for inconvenience will be offered by beverage at Telford during either or both days - seems only fair.
Cheers buddy.
Chris
Edited by Christa
Error
Hawker:
Interesting and detailed,  many thanks. But with apologies for throwing a further complication into the mix, I understood that many aircraft originally built with fabric-covered wings were subsequently refitted with metal ones.
Ditto, very useful. I read that the wing changeover took about 3 hours to accomplish.
Tony
Wonder if there will be a an Edgar Cobber Kain special boxing (similar to Brian Lane Spitfire set) in the future given the Kotare and Kain being New Zealand products and Kane being the first publicised RAF Ace of the War, somewhat surprised markings arent included in this release. Unless of course the BEF Hurricanes were Metal Wing conversions. Also fairly sure I have a set of Radu’s Romanian Air Force Hurricanes knocking about my Decal Folder somewhere and seem to recall some fabric wing options on that.
