KUROK Posted September 6 Posted September 6 My P-40N is coming along and is close to paint. Lately, spare time is hard to come by...but it will happen. One thing that I have concerns about is how to attach each end of the radio antenna to the mast and the vertical fin. I have some EZ line (used to use stretched sprue in 1/72 and 1/48). In this scale I don't think a glob of superglue will look convincing. There are also insulators to think about. How do you guys do these in the bigger scale?
LSP_K2 Posted September 6 Posted September 6 I always used to superglue them. Now I've pretty much given up on adding antennas, regardless of scale. Mal_Belford 1
Mal_Belford Posted September 10 Posted September 10 Depends on aircraft of course. Usually early in the build i ad holes on the vertical fin or if a small pole then drill a hole. Then them details, depends how they look, use PVA or Kristal Kleer, some times a thin alu tube or a syringe needle. Ex on the german style insulator that looks like a small cup, tooth pic and heated clear plastic ex from medicine pill, then cut the top and you got small cup and drill a hole... Did a test run, here you can se. Smaller scales i use CA glue and drilled holes...yes some times on bigger...details in the wire ive used PVA wood glue and when dried painted them, note the belly antenna, added a smal alurod 0.4mm as a sleeve for the antenna that were the stiff wire for rigging ships, doesnt break during handling model. So different approaches depending on the model. LSP_K2, nmayhew, KUROK and 3 others 6
KUROK Posted September 15 Author Posted September 15 (edited) Thanks, Mal! @Mal_Belford Nice 109 too Edited September 15 by KUROK Mal_Belford 1
Merad Posted September 15 Posted September 15 I use thin CA with ez-line. You only need a tiny drop and it basically absorbs into the line and becomes invisible. KUROK, Greg W and Mal_Belford 3
Greg W Posted November 29 Posted November 29 Hi KUROK You might get a little something out of this thread as well. Worth a look... CRAZY IVAN5 and D.B. Andrus 2
