Ali62 Posted August 23, 2025 Posted August 23, 2025 Hi Guys Three new sets available. NOTE to customers in USA, with this week of uncertainty ahead, I will try and get all orders in the mail by Wednesday, any orders after that may have to be held till we know what procedure to follow to get product to you safely and without complications for you and I. On with the products New Cowl set to greatly enhance your Hasegawa Ki-43-II Oscar https://aerocraftmodels.com/nakajima-ki-43-ii-hayabusa-oscar-corrected-and-detailed-engine-cowl-set-for-132-hasegawa-kit-377-p.asp New wheel bay inserts for the Dragon and Hobby 2000 Bf-109e kits, these should save a lot of frustrations https://aerocraftmodels.com/messerschmitt-bf-109-e-improved-wheel-inserts-for-132-dragon-and-hobby-2000-kits-375-p.asp New improved detail seat to upgrade the Zouki Mura Shinden https://aerocraftmodels.com/j7wi-ijn-shinden-replacement-detailed-seat-for-132-zoukei-mura-kit-373-p.asp Landrotten Highlander, Kagemusha, nmayhew and 9 others 10 2
Dave Williams Posted August 23, 2025 Posted August 23, 2025 Order placed. Those wheel well inserts for the Dragon 109Es are much needed as all the ones I have are all floppy and distorted.
LSP_Kevin Posted August 23, 2025 Posted August 23, 2025 Fantastic sets, Ali! Will get an order in shortly... Kev
D.B. Andrus Posted August 25, 2025 Posted August 25, 2025 On 8/23/2025 at 1:38 PM, Dave Williams said: Order placed. Those wheel well inserts for the Dragon 109Es are much needed as all the ones I have are all floppy and distorted. +1
ade rowlands Posted September 11, 2025 Posted September 11, 2025 Thanks for getting around to those 109E Gear Bay Inserts. Order placed. Now how about some parts to get a Fleet Air Arm Corsair out of the Tamiya kits and some Louvered Breather Plates for the Tamiya P-51D so an RAF Mustang can be made.
Ali62 Posted September 11, 2025 Author Posted September 11, 2025 10 hours ago, ade rowlands said: Thanks for getting around to those 109E Gear Bay Inserts. Order placed. Now how about some parts to get a Fleet Air Arm Corsair out of the Tamiya kits and some Louvered Breather Plates for the Tamiya P-51D so an RAF Mustang can be made. Thanks for the order, I did not draw the inserts, just printed and marketing them. As with everything time is at a premium, I know you would like these but I am just a one man operation.
nmayhew Posted September 12, 2025 Posted September 12, 2025 On 9/11/2025 at 12:23 PM, ade rowlands said: Thanks for getting around to those 109E Gear Bay Inserts. Order placed. Now how about some parts to get a Fleet Air Arm Corsair out of the Tamiya kits and some Louvered Breather Plates for the Tamiya P-51D so an RAF Mustang can be made. 100% on the FAA Corsair bits please!!!!!
Ali62 Posted September 12, 2025 Author Posted September 12, 2025 For the FAA CORSAIR, what parts are actually required, I know about the clipped wingtips, are there other items that are required? Any detailed help would be appreciated
Juggernut Posted September 13, 2025 Posted September 13, 2025 (edited) Yes, FAA Corsairs had vents on either side of the fuselage behind the cockpit and on the bottom of the fuselage, this due to the carbon monoxide problem in the cockpit. The radios and controls in the cockpit I believe were British as was the seat harness. There is some talk the certain deliveries came with U.S. seat harness but I don’t have any real confirmation on just what those were. There were also two types of shortened wingtips. If you’ve seen Dana Bell’s Corsair No. 2, he uses what’s called the short wingtip and the short-short wingtip, the latter reducing the span of the FAA Corsairs even further. I can provide specifics on these based on what Dana Bell outlines in his book and I do have access to Corsair blueprints via Aircorps Library. Edited September 13, 2025 by Juggernut coogrfan and Kagemusha 2
ade rowlands Posted September 13, 2025 Posted September 13, 2025 I believe that none of the British ordered F4U-1Ds came with the Rocket Stubs under the wings. So that would require some work to the 1D Kit part or whether it would suffice to get a hold of the wing parts from a 1A kit and substitute them in, probably deleting the under wing light. Don’t recall other than the holes and strengthening plates for them what detail is on the 1D underwing kit part. coogrfan 1
Ali62 Posted September 14, 2025 Author Posted September 14, 2025 On 9/13/2025 at 3:17 AM, Juggernut said: Yes, FAA Corsairs had vents on either side of the fuselage behind the cockpit and on the bottom of the fuselage, this due to the carbon monoxide problem in the cockpit. The radios and controls in the cockpit I believe were British as was the seat harness. There is some talk the certain deliveries came with U.S. seat harness but I don’t have any real confirmation on just what those were. There were also two types of shortened wingtips. If you’ve seen Dana Bell’s Corsair No. 2, he uses what’s called the short wingtip and the short-short wingtip, the latter reducing the span of the FAA Corsairs even further. I can provide specifics on these based on what Dana Bell outlines in his book and I do have access to Corsair blueprints via Aircorps Library. If you are able to send me some information that would be great. I have quite a few Corsair books but not those ones, cannot seem to find them currently either in the U.K. All information helps me make sure I understand what is needed and then I do not miss obvious things. Possibly PM or you can get my email off my website as that is the best way for me to receive information, for potential projects. Juggernut 1
Juggernut Posted September 15, 2025 Posted September 15, 2025 I’ll see what I can get together and send it to you. Ali62 1
Fokkerguy21 Posted September 30, 2025 Posted September 30, 2025 Thrilled to see the Ki-43 cowling----it looks beautiful! Didn't know this was in the works Troy Molitor and CRAZY IVAN5 2
CRAZY IVAN5 Posted September 30, 2025 Posted September 30, 2025 1 hour ago, Fokkerguy21 said: Thrilled to see the Ki-43 cowling----it looks beautiful! Didn't know this was in the works +1! Now all we need is a new Ki- 43 40 go with it. I can't believe nobody has done one yet, the Hasegawa one is WAAAY out of date.
Fokkerguy21 Posted September 30, 2025 Posted September 30, 2025 47 minutes ago, CRAZY IVAN5 said: +1! Now all we need is a new Ki- 43 40 go with it. I can't believe nobody has done one yet, the Hasegawa one is WAAAY out of date. That would be great. Still, this kit has a certain charm. Not much in the way of AM (beside masks and decals)----just the PE set (which is actually pretty good) and resin wheels. This will be a nice add with the correct gun ports, cowl flaps, and a nice exhaust CRAZY IVAN5 1
