Merad Posted September 22, 2025 Posted September 22, 2025 Its fascinating to compare the 3d print and hand made engines. Do you have a sense of how much time went into each one? 3d print definitely wins for mass production, but for a 1-off model like this I wonder if it has much advantage because of the time needed for 3d modeling work and test prints. Side question, what do glue do you use for all these big resin pieces? JayW 1
JayW Posted September 22, 2025 Author Posted September 22, 2025 (edited) 18 hours ago, LSP_Kevin said: Making your own 3D-printed tooling is genius. Hi Kevin. Thanks but not really. Recall I made tooling for landing gear bent-up internal metallic stiffening rods and yes - it was a bit of a revelation doing that; this is kind of the same thing. When in the world of 3D printing complex parts, assembly tooling is kind of a no-duh. 1 hour ago, Merad said: Do you have a sense of how much time went into each one? 3d print definitely wins for mass production, but for a 1-off model like this I wonder if it has much advantage because of the time needed for 3d modeling work and test prints. I looked back on the Corsair engine build, and I sequenced that one differently than my current P-47 engine build, so the comparison is not exact. Still, for the Corsair engine, it took about 8 months of on again off again work to complete the crank case and all 18 cylinders fabricated and installed onto the crankcase. Almost all that time was creating each cylinder fin by fin, spacer by spacer, and the complex rocker arm lobes with intake and exhaust ports. All scratch built out of styrene plastic, about 90 parts per cylinder. I might add that considerable time was taken to create tooling assembly fixtures. Compare to the current digital designed 3D print effort. I began this project first part of August, less than two months ago. A couple of weeks were dedicated to the engine cowl, so call it about 6 weeks so far. What I have so far is the engine crank case, a whole slew of cylinders, both front row and back row, and many more miscellaneous parts already printed and waiting to be worked on. Each cylinder is composed of only 5 parts!!! The front row cylinders are all installed with their pushrod covers and top air deflectors. It will take me only a couple weeks max to do same for the back row cylinders. That will total about 8 weeks - call it two months. Two months compared to eight months. And there is no comparison to the quality. It is almost cheating. 1 hour ago, Merad said: Side question, what do glue do you use for all these big resin pieces? I either use 2-part epoxy or CA glue. CA works fast, disallowing any post bonding adjustment that might be required. Epoxy, the 5-minute-cure kind that I use, takes about 5 minutes to get a fairly solid bond. Edited September 22, 2025 by JayW Merad, denders, TAG and 2 others 5
jeroen_R90S Posted September 24, 2025 Posted September 24, 2025 On 9/18/2025 at 9:54 PM, JayW said: It is a shame that P-47 "Dove of Peace" doesn't have a decal set. Instead I have ordered the 1/32 scale decal set for P-51D "Dove of Peace": I am hoping that both the skeleton/broomstick and dove emblems can be modified and enlarged to be acceptable. Soon as I determine that (Thunnus - are you watching?), I will decide if I am going to do the razorback "Dove of Peace". The subject checks all of my other boxes. And, BTW - that P-47 subject has large expanses of unpainted bare metal, which means I must skin it (a OD and gray P-47 would not have to be skinned). Wow! I know of no skinned P-47 model - will this be the first? As far as I know Draw Decals often do modern warbird decals, so the accuracy may depend on how accurate the warbird was painted compared to the orignal WWII scheme. (not sure but you may want to look into) I have these by Zoukei-Mura, PDF instructions: https://www.zoukeimura.co.jp/download/sws04d04_02_ee.pdf I'm not sure (based on the photo of the P-51 I posted earlier) I agree with the green machine gun and yellow background (yellow looks correct for the P-47 but not the P-51, looks white?) but the artwork seems to match. I have those decals so if you want a high-res scan of the artwork let me know and I'll look them up for you. On 9/19/2025 at 1:50 PM, tomg said: The moniker "dove of peace" on a brut like a P-47 is irony defined. Can't wait to follow your progress. According to legend Duncan's first P-47 was Winged Death but he was ordered to change it, so sarcastically renamed it to "Dove of Peace"... ----------------------------- The engine looks amazing Jay, if you'd printed a 1/18 scale workshop background you'd think it was the real thing! Gazzas and JayW 1 1
Juggernut Posted September 24, 2025 Posted September 24, 2025 Amazing R-2800! Seems like you've got a pretty good knowledge of this powerhouse and I look forward to seeing more of this. JayW 1
JayW Posted September 27, 2025 Author Posted September 27, 2025 (edited) On 9/21/2025 at 3:31 PM, JayW said: Next up is a little break. Then it is on to the aft row, the intake pipes, and the exhaust extension pipes. As is often the case, I changed plans. First, it occurred to me that if I install all the aft row cylinders now, that rigging the spark plug wires will likely be overly challenging with so many cylinders so close to each other. So I would like to rig spark plug wires for the forward row before the aft row cylinders get attached. Either way though, the ignition manifold with all the spark plug wire attach points must be present! And it attaches to the big front reduction gear housing, and the magneto/distributors. So it is now necessary to start in on the stuff in front of the cylinder banks. That includes: - Front reduction gear housing - "Turtleback" GE magneto/distributors - Ignition manifold - Oil scavenge pump - prop governor - prop shaft brush cover For now just let me show you my progress on the Rhino layout of this area of the engine. It is quite involved. Jim McDonald's R-2800 drawing has been helpful, but that engine has an entirely different set of magnetos, distributors, and ignition manifold. So I am still having to guess at some things. At least the mounting planes are the same, and they are defined on that drawing. Here: It's all there, layout quality, except the prop governor. That is next. I have to develop all this stuff enough to design a print-worthy reduction gearbox housing with attach means for all the stuff that hangs on it, and a print-worthy ignition manifold. Here it all is on a real engine: What a helpful picture. Look at those big turtlebacks! Next post should be parts, and a good discussion on prop governor/pitch systems, and ignition systems. There are two different types each on the R-2800. Edited January 29 by JayW geedubelyer, Greg W, cmayer and 15 others 18
geedubelyer Posted September 30, 2025 Posted September 30, 2025 Jay, this has been a blast. Thank you for sharing this. Here in the UK we can no longer see any of your images without using a VPN so I would like to take this opportunity to wish you all the best for the remainder of the build and will continue to read your text explanations of your processes. Cheers, Guy LSP_Kevin, JayW and Landrotten Highlander 1 2
JayW Posted October 1, 2025 Author Posted October 1, 2025 17 hours ago, geedubelyer said: Here in the UK we can no longer see any of your images without using a VPN so I would like to take this opportunity to wish you all the best for the remainder of the build and will continue to read your text explanations of your processes. What????????????????????????????? Since when? I must get to the bottom of this.
geedubelyer Posted October 1, 2025 Posted October 1, 2025 (edited) 1 hour ago, JayW said: What????????????????????????????? Since when? I must get to the bottom of this. It's a UK government thing Jay. OSA (Online Safety Act) requiring age verification. It would appear IMGUR have decided that the administration needed to cater for things is not worth it. There's a thread on it here Edited October 1, 2025 by geedubelyer JayW 1
JayW Posted October 2, 2025 Author Posted October 2, 2025 23 hours ago, geedubelyer said: It's a UK government thing Jay. OSA (Online Safety Act) requiring age verification. It would appear IMGUR have decided that the administration needed to cater for things is not worth it. There's a thread on it here Some of my most respected followers are from the UK. I am going to have to investigate using a different service.... 😑 geedubelyer 1
geedubelyer Posted October 3, 2025 Posted October 3, 2025 I can view the images again Jay. Did you migrate them to another host? JayW 1
JayW Posted October 4, 2025 Author Posted October 4, 2025 On 10/3/2025 at 1:07 AM, geedubelyer said: I can view the images again Jay. Did you migrate them to another host? I did nothing! Cannot explain. So I will delay moving to a new host. geedubelyer 1
Shoggz Posted October 5, 2025 Posted October 5, 2025 Don’t want to be Mr Downer, but it’s still the purple squares of doom for me.. “content not viewable in your region” JayW 1
JayW Posted October 5, 2025 Author Posted October 5, 2025 I am now using Image Shack. Test picture: Can everyone see this? Gazzas, Philbucknall, Landrotten Highlander and 7 others 8 2
Oldbaldguy Posted October 5, 2025 Posted October 5, 2025 So what does this hyperbolic nannyism mean for European based posters? Will the rest of us be deprived of seeing their builds now or is this limited to a single host with no other firewalls? JayW 1
geedubelyer Posted October 6, 2025 Posted October 6, 2025 10 hours ago, JayW said: I am now using Image Shack. Test picture: Can everyone see this? That is visible Jay. Thank you. I very much appreciate you taking the time, effort and trouble to switch hosts. Sorry that you have been forced to though. 7 hours ago, Oldbaldguy said: So what does this hyperbolic nannyism mean for European based posters? Will the rest of us be deprived of seeing their builds now or is this limited to a single host with no other firewalls? As far as I know OBG, the ban prevents UK residents viewing (or using) IMGUR content due to localised legislation. Nothing else is affected thus far. 🫰 Oldbaldguy and JayW 2
