  • 1 month later...
Is he even alive?
Well yes - I have a tiger by the tail with the sliding canopy, plus we have a new puppy in the house who is a full-time job let me tell you!  A land shark.
Just a picture of the Rhino proceedings to let you know there is progress:
It's a razorback!
I think I am ready to try printing transparencies using the latest techniques cussed and discussed on Jim Barry's P-38 thread.  Eleven parts total not including duplicates.  Windshield and canopy transparencies.  The frames for both the windshield and the canopy need more work.  The canopy frame is one son-of-a-gun to Rhino design.  Good lord.
Also fwd fuselage frames, longerons, and canopy support structure are in work:
The frame which constitutes the back wall of the cockpit needs to be done at this point.  The firewall, of course has already been done.  In order to assemble the fwd fuselage parts onto the firewall, I am going to have to design, print, and build a fixture, mostly to make sure those four wing attach lugs per side are crack-on perfectly positioned relative to one another.  I have thoughts only at this point....
I hope to show actual parts next post.  Til then, take care all!
46 minutes ago, JayW said:
Is he even alive?
It's a razorback!
Just like the real thing. 😁
Follow my process to the letter and you will get crystal clear results.
Remember: NO polishes of any kind. No varnishes until the very end. Acrylic varnishes, future etc. are useless.
The real key stage is with the 600, 800, 1000 and 1200 grits to get the surface as print layer free and a matt smooth as possible for the 1500 and incremental grits to 8000. Loads of soapy water for lubrication and sanding waste removal. No point going finer than 8000 grit.
If you don't get rid of the 600 and 800 grit 'trenches', it will always result with scratches showing.
I cringe at the thought of using 600 grit on clear surfaces.  But it must work...just the thought.
It isn't clear at all to begin with - the prints are virtually white.
But to remove the inevitable layer lines, no matter how fine, it has to be pretty aggressive to begin with.
I guarantee it works every time , but no shortcuts and only if the necessary time is taken.
