  • 5 weeks later...
Apologies for delay - but a little more progress.
Base Interior Grey/Green - in this case MRP.
Detail painting and weathering to follow - but the base coat shows up the superb detail...
48b427_a4be8108a6e148f5888efefb62374444~
Dry assembled:
48b427_2e1a4160e7504795b53b6afc7bc20435~
48b427_5f3c61fc35a64ec1bcf0e7e35a756080~
48b427_998dd6113ef7496589c2a28739198292~
With a tiny bit of trimming in places, the fit to the fuselage halves is superb!
48b427_e66af35085e147db841b4132efc968eb~
Main panel back and boxes sprayed black - and dry fitted:
48b427_0022dfe72975455daf2538649595f58b~
And the two halves closed up - again - just a dry fit at this stage.
I've also softened the transition from the base of the canopy to the fuselage sides with a little Milliput - need to add some detail back.
48b427_8b02b4b440b54bbe9c1d5c9a0e395036~
48b427_6e5c407ded3849ff99527516c5ac10c0~
Absolutely loving this kit - the detail and fit of parts is fantastic - and hugely rewarding to work with.
Iain
Continuing the 'dry fit' theme - it would be rude to not slot the tailplane in place - that's how good the fit is! I've also reshaped the cross section of the rear fuselage a little so it's a bit flatter on the upper quarters on either side of the opening for the turret fairing:
48b427_f010b3c0511540d4927b7ce127f08fa3~
And try out the wings, rudder, rear decking and cockpit canopy - again - all dry fitted!
48b427_7b3139aedb7b47d88aa0eb43376fdce1~
Note that I've also modded the 'ears' on either side of the cowling part - they are now recessed, rather than proud of the surface:
48b427_767fc21dc3de465d95472ac35eda606e~
Really looking forward to getting the cockpit interior all painted up and assembled - it's going to look quite something...
Iain
Thanks Andy - I think you'll enjoy building it...  🙂
BTW - there is absolutely no surface prep under that grey-green - just a little work with a file to clean up print support attachment points. The print resolution really is that good!
Iain
