2025-04-14_02-56-37
I started this one a little while back and feel like i'm on a roll with it, so hopefully posting this doesn't jinx the project!
Anyway, Tamiya's MkVIII, plus the 3D printed MkXII conversion will hopefully end up with my FAVORITE mark of Spit, the Hot-Rod MkXII!
For those who haven't had a gander, the Laminar Flow Design parts are TRULY sublime.
20240417_122012
20240417_122329
20240417_122430
YES, there are print artifacts. No, they're not insurmountable. We will cross that bridge in a short while.
The Tamiya kit built up as expected. Everything fits great, and has plenty of detail. I kept things relatively OOTB for this build. Even using the kit supplied photo etched seatbelt!
Prime:
20240721_202006
Paint
20240721_204721
Detail
20240721_215202
Dirty
20240816_100751
As always, a few @airscale placards are applied around the place to busy everything up.
More to follow
Denzil
Edited by RadBaron
2 hours ago, Kagemusha said:
Great start, always nice to see a Spitfire, especially one a little bit different.
Thanks mate!
First thing's first. When I think conversion kit, my mind goes to all manner of rough and ready, home made resin or vacuform concoctions that are only barely less work than scratch building. So how does this one fair?
20240823_075611 20240823_080909
 The nose almost clicked into place like a kit part. Colour me relieved!
And the lower wing insert?
20240720_212946
Other than ham-fisted attempt at removing the piece of wing, the insert went in perfectly.
20240720_214710
Next, the elephant In the room whenever the topic turns to 3d printing:
Striations.
Yes, even the finest prints will have them. And these pieces are no exception.
20240827_201541
20240827_201553 20240827_201619
If it's not clear in the pics here, click on the pics to go to the fullsize images.
Striations are there, and as fine as they are, they need cleaning up.
Which really wasn't a big deal.
A couple of coats of Tamiya fine white primer straight from the rattle can, and a sand with 1000grit got things smoothed out, without sacrifice any of the scribed detail.
20240831_192439 20240831_194052
With the components resting together, she's starting to look like a proper monster!
20240826_214205
Next up is playing with some fiddly bits!
Denzil.
Edited by RadBaron
  • RadBaron changed the title to Tamiya Spitfire Mk VIII + Laminar Flow Mk XII conversion
Other than thinking it looks cool, I know nothing about the nuances of the MkXII Spitfire, let alone the little differences that needed changing between Mk VIII and MkXII. The comversion's instructions werent entirely clear about what changes were to be made to the base kit. Luckily, Mathieu from LFD was very helpful in pointing out some of those differences.
First port of call was a rabbit hole that I had nonidea existed:
Filling in the rivets on the wing leading edge.
Apparently that's not just a P51 thing!
So out with the filler. I mixed Tamiya filler with some extra thin, and slathered it over the wings multiple times until I had a smooth leading edge.
20240824_205000
20250410_185745
In the process, I destroyed the plinths for the shooty things, so a set of turned barrels will fix that issue.
20240831_200225
The kit gives options for short or long ailerons.
I followed the kit instructions and chopped the ailerons down to replicate the shorter ones.
Turns out this is wrong.
20240816_131914
The kit also gives the option for the small or big mass-balance elevators. Again, following the kit instructions, I dutifully chopped up the horizontal stabilizers to suit the larger mass-balance.
Aaaaaand this too was wrong. I should have used the smaller mass-balance elevators.
20240816_103958
Also, gosh that seam is in a really PITA spot!
A quick look on Google would have told me what I needed to know about which flight controls to use.
large_CH_012753_1
I hadn't yet thrown out the chopped off parts and could have cobbled them all back together, but luckily, an even easier fix was simply spending money.
All the parts I needed were contained on one sprue, and luckily one of the kit pickers on Internet-Auction-Site had that sprue for sale. A couple of days later, we were back in business.
20240824_200211
Take two!
Denzil
10 hours ago, MikeMaben said:
:coolio::popcorn::speak_cool:
1 hour ago, Shoggz said:
Another LFD conversion - bring it on Denzil - will be following avidly!
Thanks guys! Chomping at the bit to get this one to the paint booth!
Another difference between MkVIII and XII that I've only just realized is wheels. Tamiya supplies silly rubber tyres. Instant no go, so off to the interwebs and I had some lovely resin 4 spokes in my hands.
20240808_165600
Except the XII's all seemed to have hubcaps. NEW new wheels are on the way.
The canopy had a lovely seam down the middle. Nothing a quick polish couldn't fix.
20240831_194958
20240905_213717
Once I was happy with the finish of the wing leading edge, it was clicked into place and secured with glue. The forward wing root fairings, supplied as separate parts in the Tamiya kit, needed a little bit of finessing to fit into the new nose section, but it was an essentially painless affair.
20250412_125841
Back to regular construction and Tidying up!
Denzil
Edited by RadBaron
38 minutes ago, PHBIO said:
very intersting....you should see Tolga ULGUR wip about mk XII upper fuel tank access panel. ...
I have read through his 2 builds on here and they've proved EXTREMELY helpful!
I don't think I'll tackle moving the fuel filler backwards. I'll wait until I've shot a coat of primer to see how much more cleaning up that seam needs :lol:
Wish I'd read them BEFORE I'd started mine, but I was enthusiastic, and i never try to hold back the MOJO when it's flowing :D
Some little stuff.
Elevator trim tabs got some pushrods.
20250420_140147
Since I wasn't using the kit supplied photo-etched hinges, I made some new ones from plasticard
20250420_142456
The main canopy covers the rear section of glass when installed, so the rear section need painting before I could fix the sliding portion in place.
20250420_185254
And with that, some of the loose parts were gathered to make it look all spitfirey and noises were made!
20250420_190553
D
