Progress!  First, the engine, which does not look too bad once the ejector pin marks and seams inside the jetpipe have been dealt with.
That should look OK under some suitably-coloured paint.  Talking of which, the main assembly has acquired some colour, as have the rotor blades.
Onward ...
Edited by MikeC
Time for some markings: unusual at this stage in the building process, but a good time to add the "Army" titles and roundels.  These are paint masks: for the afficianados they were cut on a Silhouette Portrait 3.
Et voila!
Thanks for your continued interest.
Back to the cockpit - or is it the cabin on this helicopter?  Let's say cabin, in a spirt of inclusiveness, to take in the back seats as well.  I've spent the last couple of modelling sessions dealing with the HGW belts.  These were coloured blue, for contrast with the seat cushions, and because it is a legitimate colour for these harnesses at this time: they tended to be blue or black (with parachute harnesses remaining buff/khaki/or similar).  The blue was from the AK Real Colors marker set, RAL (I can't recall the number).
So here we see the seats installed, and the cabin substantially complete, except for some distressing and "grubbying-up" and the little matter of the glazing.
I went with the decal supplied in the kit for the instrument panel; after a search in my spares box, I decided the decal would be good enough.  I think the lap straps in the front seat need some adjustment though: despite my best efforts, they've ended up looking like they've been left in the same configuration.  This was, of course, possible but not probable, there needs to be some variation I think.  About the rear harnesses: I think I mentioned that I intended to leave them as moulded, to depict the aircraft about to fly with them unoccupied.  Again, good enough for me.
And now it's a wet Easter Monday here, so I think I'll get back to this on the bench.
And now I can't put it off any longer, there's still the glazing to deal with.  "Dealing with" will mean masking and fitting, in that order, and there isn't the luxury of an aftermarket canopy mask set.  So it was out with the knives (complete with new blades) and the Tamiya tape.
It's going to be a long job ...
But once started, it didn't seem too bad.  I thought I'd better fit it all together at that point, so that I could have maximum visibility for the alignments: it's butt joints only, but fits well with some slight adjustments here and there, which is especially fortunate as I didn't follow the instructions to the letter.  They would have you build from the bottom, and thus add the doors before the upper canopy, but I still harboured thoughts of leaving at least one door open, so left them until last.  In any case, I wanted to leave one removable until the last minute so that I could fix any unseen dirt, debris, dust etc (other than that deliberately induced by pastels/paint,wash weathering) inside the cockpit.
Fixed the starboard door in the end, but I made the mistake of adding the hinges, which you can see on the front edge of the door: this made them vulnerable during further handling.  Ah well, I've only been doing this modelling lark 60-odd years, so still lots to learn.
Next, here we are with the port door a good push-fit so it can be removed again; and the fill-in masking under way.
Done ...
After this, I tidied up some seams: I was prepared to let some go, and I have managed to avoid needing any filler, although I did restort to filling one narrow gap with unthinned paint.  All in the interests of avoiding risk to the glazing.  A coat of Tamiya NATO Black, both as an undercoat and the internal colour of the canopy frames, was followed by a topcoat of Dark Green, and the white serial, again a home-cut mask.
  • 3 weeks later...
"Pfffff pffffff!"  Sorry about that, just blowing the dust off this thread, which I fear that have neglected lately, owing to a combination of another couple of models getting a bit of bench time and me doing some real-life stuff.  Anyway, l'Alouette is back.  The main rotor is essentially complete, with the blades painted in dark green + yellow, then masked off to spray the rotor head assembly.  In the second photo, a more general view of the workbench, you can see that the cabin and tail boom assembly is complete, with the engine plus main and tail rotors to be added.
There is some detail painting to be done on the rotor head after the main colour - Extra Dark Sea Gray looks about right - goes on.  Then comes the last bit before I can put it all together: the engine.  The kit engine looks good, but could probably do with a bit more detail, so I'll need to work out what needs doing that is within the bounds of my skills.   Also hoping to make the main rotor de-mountable for transport to shows, again the "how" needs working on.
Hopefully, the next update will be not too long.
Love this comin alive, like it alot sir, it got the look of a dragon fly as mentioned before....as did one myself LoL, but not same scale lol....and a dragonfly is bigger 😆....yep not exacly same heli but almost..
Edited by Mal_Belford
"Do not be afraid of moving slowly - be afraid only of standing still."  That well-known sage Anon had a point there, as I think the finish line may be in sight, but there is still plenty of work to do to get this model over it.  Not least there was a small bit of flash to remove from the rotor head transmission.
So that was done, and the two halves fixed.  While that was drying, I started on the engine and rotorhead area by adding a couple of tanks.  These will be painted the same green as the main scheme, but maybe with a bit of a contrast (lighter or darker).
A few pieces relating to the rotor-head and transmission.  The long multi-jointed shafts that go from (eventually) under the cabin to the rotorhead - they are what transmit the pilot's control movements to the rotorhead - caused me a bit of an issue until it became clear that parts 67 and 68 are misnumbered.  Part 68 in the instructions is labelled as 67 on the sprue and vice-versa: fortunately, the three parts are different, and the diagram on the instructions shows them in the correct relationship to each other - just ignore the numbers.  Also, its easy to inadvertently break one when detaching from the sprue: don't ask me how I know.
The instructions show a number of colours on various rotorhead parts, and so said rotorhead has been "prettied up" using AK paint markers.  It's difficult to see this area clearly in photos, so I did it "just because", and it may not be accurate for a British Army Air Corps machine.
The control rods added: the aircraft is a tail-sitter still, but I'm confident that with the cabin attached it won't be.
A bit more added to the engine, and some still to be added
And the cabin added: as I thought, because I'd already tested it, no need to add any extra weight to stop tail-sitting.  The tape is to stop the cabin "nodding" forward while the Tamiya extra-thin sets.  There are three attachment points: two underneath sit over a frame member, and a "tab" on the rear of the cabin.
And with a few more touch-ups to the paint, the Alouette is finished.  There is probably a lot more I could have done, especially detail in the engine area, but I decided that enough was enough, and to quit while I'm ahead.  It was quite an interesting build experience, being even more delicate in many respects than a typical WWI aeroplane, and offered some interesting challenges.   It won't win any competitions, mostly because I never enter them, but in the end I'm quite happy with it.  Will I take it out to shows?  Possibly not: despite the fact that the rotor is removable - a simple drop-in fit to the transmission - the whole thing is extremely delicate, and I would be concerned about the risk of breakage.
Thank you for coming along with me, plus the info and the kind comments along the way.  Any more feedback welcome.
  • MikeC changed the title to What a Lark! Sud Aviation Alouette II - Finished!
