Rob Colvin Posted March 12 Posted March 12 I was applying good ole Testors dullcoat to a nearly completed p-40 and for whatever reason it dried very glossy. I am not sure what I did different? I thinned it about the same, perhaps I put it on too thick? i will have to dullcoat some additional parts for completion so I will have another go. And yes, I am sure it was dullcoat lol. Rob
FW190A-5 Posted March 12 Posted March 12 Is it possible that it was not mixed well? Which thinner was used? Mr. Hobby leveling thinner will give a satin finish. John S.
Rob Colvin Posted March 12 Author Posted March 12 I did use the leveling thinner.....I will look into that thx!
Dainis Posted March 13 Posted March 13 FW190 is correct. Lacquer matt varnishes need a regular or even rapid dry lacquer thinner to obtain the matt finish you're aiming to accomplish. Found this out a. number of years ago.
LSP_Mike Posted March 23 Posted March 23 I've used paint thinner, and added a few drops of acetone for a "hotter" mix.
Juggernut Posted March 23 Posted March 23 (edited) I use plain old lacquer thinner sold in stores like Lowe's and/or The Home Depot. It works just fine on Dullcote and it runs about $20 a gallon. I also use it for cleaning my airbrush (Iwata) as it takes off just about anything it touches. Other than Dullcote, I use Mr. Leveling Thinner on everything else (including MRP when I need it super thin). This is what I currently have in the house: Lacquer Thinner. It's a little more expensive than I said above but it's the only kind that the Home Depot near me had on sale. They do offer a less expensive version: Lacquer Thinner. I'm not sure there's any performance difference between the two. The only difference I can see is the more expensive one is more environmentally friendly. Damn the bad luck...I had to have a store that didn't sell the cheap kind. Edited March 23 by Juggernut
