You know... it's funny how you start down certain rabbit holes and find sudden spurts of motivation and interest in something seemingly so random and specific... but that's what happened to me with this odd little project.
Background:
It all started in an antique store in Massachusetts... Sturbridge, Massachusetts to be specific. Home of the famous "Sturbridge Village", a living history town set in the 1790s through 1830s. We visited this attraction quite often growing up in the 90s, as it was little over an hour away from home. During the long weekend, we'd also stop at some local stores, including a large three story antique center where individual retailers could rent out their own booths. It was there, in a glass case on a shelf in the back I spotted a beaten up little diecast P-39.
P-39 "Miss Connie"
Now for reference this was probably in 1999/2000 when I was 13, and I was still building up my collection of 1/144 warbirds to play with, and I didn't have a P-39 yet. The only option at the time was the old Revell kit which I didn't even know it existed then! So this was the next best thing. I later discovered that this diecast toy was made by Playart, a toy company from Hong Kong that were similar in size and style to Hot Wheels, Matchbox, etc. It had retractable main gear, and a spinning prop.
Here is a complete example:
MINE however didn't have anything. No canopy, landing gear, prop, or even a nub FOR the prop, and weirdest of all... there were two perfectly small circular holes punched in the wings for some reason. So I set about overhauling the little toy. I glued a chuck of plastic sprue to the front and then sanded and shaped it to look like a spinner. I also filled in the holes in the wings with putty. While still searching for a canopy I decided to paint it as basically the only flyable P-39 there was at the time. The Confederate Air Force's "Miss Connie".
A seemingly easy and straightforward scheme of OD and grey, along with a yellow decal band around the tail, and some stars from a decal sheet. The nose was painted red and it was basically done until I found a canopy... fast-forward 25 years to today... I still didn't find a canopy. I had recently opened one of the drawers of my misfit and broken 1/144 planes and picked up this weathered and beaten little toy. Some paint had rubbed off, the spinner broke off, and it was looking rather shabby to say the least. So as a simple and quick exercise I decided to redo this model one more time. I found the spinner had relocated to my parts box so it was reunited once again. The paint was touched up along with new stars and a donor serial number from another kit. Its not the exact number but its close enough for me. I also had filled in the landing gear bays as she would be in flying mode. But what to do about the canopy?
I decided after looking at my Corgi CAF P-51D and P-47N that came with the B-29 "FiFi" set, that I would simply make a solid plug and paint in the canopy to match the other two CAF birds I already had. Making it an unofficial addition. I cut and fitted a piece of thick styrene into the well where the original canopy would go, and then began trimming and sanding it down to match the silhouette side profile of the P-39 canopy. Acting as a sort of spine, I laid think gel superglue to both sides to "fill out" the space and add dimension. Once dry, I began alot of sanding to shape done the new canopy plug into a more accurate shape. Once done I touched up the paint, added the dark blue color of the glass, clear coated it, and I was done.
P-51C "Tuskegee Airmen"
I had enjoyed the small but satisfying (and fairly quick) process of redoing the P-39 so much, I decided to look around and see what else I could add to this emerging series. It quickly dawned on me that I had actually a second Playart diecast plane in my collection. A razorback P-51B/C.
Once again mine came without a canopy, but it did have one of the landing gear and a broken prop with a few missing blades. And those weird holes again... Keeping with the CAF theme, I decided that this one would just have to become the P-51C "Tuskegee Airmen".
I set to work by removing the stickers, sanding / puttying to smooth over seams from being cast, once again made a styrene spine for the canopy, added superglue, and then sanded it down quite a bit. I filled the gear bays in as well as the holes with putty, and sanded smooth. I also added a plastic spin on the top of the razorback to bring it up a bit as it seemed fairly low initially. After it was all said I painted it in all aluminum silver, and added the OD for the antiglare panel, black and grey where needed, as well as the red nose, tail, wingtips, etc. Decals came from Draw Decal. They went on pretty easily EXCEPT for the red and yellow stripe pattern around the nose, that was a pain. Granted its supposed to fit on a Revell or Sweet kit, not some hunk of metal from the 60s-70s. I clear coated in semi-gloss and after that I was done.
And here is a shot of both from the underside.
So now with two under my belt I was "jonesing" for another plane to add to this collection. It was at this time I started to grasp fully the theme of what I was making here. Essentially the CAF aircraft fleet from my childhood. I decided to call it:
CAF in Transition: (1994-2004)
Within those ten years the CAF went through alot of changes. Both structurally, finically, as well as publicly with changing the name from "Confederate" to "Commemorative". A good PR move in my humble opinion. In that timespan, planes had been pranged, crashed, been rebuilt, repainted, and transferred to other wings. So now that I had a clear idea, and a specific decade to work within, what would be the next plane to replicate?
P-38L "White Lightin"
While at my parent's recently I sifted through a box of diecast toy planes I played with as a kid. These were the REALLY lost and misfit planes of my youth, as they were swapped out for more accurate 1/144th scale planes. But one plane did catch my eye. This P-38...
A bit of an odd toy, this P-38 originated from the (Road Tough Super Airforce) toy line. I found them in a Christmas Tree Shop we frequented.
4a8ab497-705e-48cf-a06e-24617cda849c.web
Needless to say I collected all the WWII birds and most of the jets too. By the way, who ever friggin' thought to make a diecast Storch?!
70efd115-b281-45f7-9309-21bfef8b21ef.web
Seeing as it was the only diecast F model P-38 I ever ran across, I knew it would be the perfect base to recreate the CAF associated plane known as "White Lightin"!
The toy itself was super close to 1/144th scale (similar to the two playart planes) so this worked perfect for me. I started by cutting off the wheels, grinding the stumps down, and puttying the entire plane to once again smooth out the diecast seams and rivet holes. After multiple passes of primer, putty, sanding, and repeat, I got to something I thought was decent. I ordered the decal set for this aircraft from Draw Decal once again and anxiously wait for it to arrive!
FG-1D Corsair
Not being satisfied with working on just ONE plane, I purchased a Johnny Lightning Corsair off of eBay that was missing the engine cowling and prop.
This one would be reborn as the CAF's one and only FG-1D Corsair.
Always up for a challenge I knew I could work with this. First thing was to cut off the centerline bomb rack and bomb. Then I used a Crown/Minicraft B-25 engine as I have some spare Cobra B-25 engines I will probably use eventually for those. I also used plenty of putty to cover the screw holes, seams, etc. I also used an aftermarket radial engine to put in the hollowed out cowling.
After some sanding and primer work, I shot it with dark navy sea blue, and need to go back and do a few touchups before proceeding.
So now you're all caught up to where I'm at with this project! And I have no idea how many more I'll be able to add to this collection before my steam runs out (JL P-40? :o )but I'm enjoying the process and relatively ease that they are flying together. There is a certain amount of relief when all you have to do is paint the windows onto the model. But probably the biggest question in regards to this whole project is... why? Why on earth would I dedicate the time, energy, and effort to inferior shaped planes when there are far more superior examples out there. I mean... I have some unbuilt Sweet P-51Bs and AFV Corsairs. They would look ten times better than any of these, Why would I put so much lipstick on so many pigs?!
The answer... I don't know. But I am certainly enjoying it. Maybe it's a harken back to my childhood or something, or just wanting to finally have an entire collection of these planes with the skill and know how to get it done more easily. Either way I hope you've enjoyed this journey so far and look forward to the updates!
Update on the Corsair
After some sanding and a primer pass, I was ready for dark sea blue. The first pass wasn't great and required some sanding down of paint bubbles. A second paint pass was okay by me. I then started in on the markings. Which was kit bashed from multiple decal sheets and extras.
The checkers were a pain to say the least. I'm going to try and touch up the induvial checkers with some blue and white paint, but if I cannot salvage it, then I'll start again. I might have to cut out the checkers I need, and then hit it with a coat of decal bonder before soaking it.
I also stole an extra prop from an AFV kit, so I will add that after I paint it. Should be done in rather short order! Still wiaitng on those P-38 decals though...
Here are the finished birds so far.
Next in line is the P-38.
I will start to paint the canopy in, walkways, etc. basically anything I can do before decals. And then there is the next one...
P-40N Warhawk
You guessed it.. this Johnny Lightning P-40E will be transformed into the CAF N model. While I know their are differences between the E and N, I'm willing to overlook them for the sake of this unique diecast related project. I started off by cutting and gluing a rough port stab that was missing and will continue to sand and shape it.
I will eventually add the lines in for the control surfaces. Learning from the JL Corsair, I sanded off the raised painted on markings and added putty to fill in all the seams. Next is a bunch of sanding! Once we are ready for primer, is when I'll add the missing prop.
Thanks for looking!
  • 2 weeks later...
And with that, the P-40 is finished...
The dark glossy sea blue I've been using for all the cockpits (except the Corsair) is to keep the consistency with the Corgi P-51 and P-47. It blends in a bit too much more my liking but it is what it is...
I used a model master enamel tan and Vallejo green from the RAF paint set. The bottom was just pure white.
The Chinese nationalist rondels were sourced from a post war P-51 decal set. The tigers were from the AFV P-40B/C kit. All the numbers were from the always reliable I-94 decals. The shark mouth, pandas, and kill markings were custom printed. I painted the blue band on the rear fuselage.
I had to bridge the two shark mouth decals with some paint and little bit of touch ups. Once I was satisfied with the overall result, I coated it in a satin clear to mimic how the real one was more shiny for easier maintenance. Though I still may go back with a flat coat.
This now puts me at six completed CAF fighters. I still have one more to complete before I think I'll move on to something else. Still working on the bases for these.
P-38 decals finally came in and now I can start in...
First I painted in the canopy, then I trimmed everything with white to clean it up. (Still needs more)
Then I went in with the red. The white and blue decals will go over and trim the red to make it look more neat.
Should go by in short order now!
  • 11 months later...
I've recently finished up a few more for this series...
SB2C Helldiver
The CAF's Helldiver has been the only game in town for decades attending shows across the country. It wasn't until a year or two ago that two more Helldivers were restored to fly as well. AND their are even still a couple more that are being restored to fly. So we might eventually see 5-6 flyable Helldivers in the world...
The kit is the ancient and wildly inaccurate 1975 AHM model. This was the ONLY option for decades if you wanted a 1/144th scale Helldiver. Of course now we have the added luxury of SB2C models from: Cafe-Reo, F-Toys, and now a 3d designed / printed example from China (off of Evilbay). But for me this is the kit I had in my drawer and one that was part of the original group that my father had built for me. Though he never had finished it, that didn't stop me form playing with it.
Once again I forgot to start taking any shots of the model before I started...
By the time I took these shots I had already started addressing the tail which was too small. I had some thin styrene sheets and essentially "laminated" them over the existing tail by gluing them in position, then adding putty to fill in any gaps, and started shaping it by sanding the new tail.
I also built up the rear gunner's area with more putty and sanded it until I thought it looked pretty good. Another major issue with the kit is the double wide cockpit area where it looks like two pilots could sit side by side! This was something I wasn't ready to try and fix, and decided to leave it.
I was able to find the original cockpit glass and I believe the original prop from the kit. I was able to utilize a spare rear gunner's greenhouse glass from a Cafe-Reo SB2C since they came with an extra canopy. I also added the missing tail wheel, exhausts, radio mast, and the small intake scoop on the underside of the nose bowl. I made the USS Franklin decals for the tail and printed on my home printer decal paper. The stars and other numbers are just kit bashed.
The result? Not bad but of course not the best given the medium I had to start with. Still with the goal of giving these old kits a good retirement after they gave me such joy over the years, I say it was a success.
SBD-5 Dauntless
The other one I ended up making was the CAF SBD-5. Another mainstay in the CAF fleet.
Now this kit was NOT from my earlier childhood, but it was also not too far off. As this started out life as a 1/144th scale 21st Century Toys model that could have been bought in Walmart back in the day. Needless to say when these first came out, my father and I were scouring every local store we could for these and did end up buying a few... so there were more than a few that were played with... this being one. This started off as a Coral Sea / USS Lexington example that had lost it's landing gear and bombs at some point.
And of course I didn't take ANY in production shots. This one was pretty straightforward. I ended up adding putty to fill the large cavity space between the engine and firewall area. I sanded it smooth and brush painted the tri-tone colors on. The decals were kit bashed once again.
I added guns in the nose and the radio mast. I had the original lading gear but it just wasn't working to put them in the up right position. So I used a couple of very small rubber O-rings with some styrene rods. I then filled the center of the O-Rings with super glue and painted. I was able to reuse the original bombs and repainted them to match the ones on the real CAF SBD. I finally sprayed the entire thing in a flat coat which fogged up the glass somewhat which was my bad. Wish I had took the time to mask it. Something to remember next time.
And with that the two CAF dive bombers are done!
This brings up the collection to nine aircraft total! The P-38 is the only one that still needs some touchups / details before it gets clear coated and finished.
Now this doesn't include the CAF bombers that are on there own landing gear and not these black stands. One day I'll take a shot of all of them. Hope you enjoyed!
Those are great. Looks like fun and heartwarming to connect to your past. It's like a Toy Story movie of sorts, saving them from a demise and promoting them to a mini museum.
I scratched a few 1/144  fighters before I got into LSP thing. Gateway drug
  • 2 weeks later...
What a terrific project! As a warbird fan myself I totally get where this is coming from. I love the bases in particular, the nameplates are a great idea.
