Dpgsbody55 Posted February 22, 2025 Posted February 22, 2025 This does look really good. Given that it's a prototype kit, the engineering is exceptional. Nice work so far. Cheers, Michael Tolga ULGUR 1
Tolga ULGUR Posted February 22, 2025 Author Posted February 22, 2025 18 hours ago, Troy Molitor said: It's all coming together. Thanks for sharing this with us Tolga. 17 hours ago, Derek B said: Impressive breakdown and build. Derek 14 hours ago, Pete Roberts said: Looks like a Defiant to me - great work all round! 12 hours ago, Martinnfb said: Smart engineering. 5 hours ago, IainM said: That is looking good @Tolga ULGUR @airscale I shall be eagerly waiting for the moment it hits the shelves!!! 5 hours ago, Dpgsbody55 said: This does look really good. Given that it's a prototype kit, the engineering is exceptional. Nice work so far. Cheers, Michael Thanks Derek B 1
Tolga ULGUR Posted February 22, 2025 Author Posted February 22, 2025 Some progress; Horizontal tails and stabilizators. In the early design there is an area to be cut out. This part prevents the moving part from fitting properly. Peter said that this part was fixed in final production. I unfortunately damaged the area around it while cutting here, fortunately I have epoxy putty Kagemusha, Philbucknall, Derek B and 30 others 33
Javlin1 Posted February 22, 2025 Posted February 22, 2025 This is looking like a keeper the production models will only get better. Tolga ULGUR and JayW 2
airscale Posted February 23, 2025 Posted February 23, 2025 More wonderful work Tolga Just wanted to note some great finds this build has led to where improvements have been made - just shows the value of a test build by an accomplished modeller - even if it is in the public domain and you see warts'n'all * Clash between compass and control stick - fixed * Missing throttle parts in Cockpit box - added * Missing rear retractable antenna - added * Canopy changes to adapt from 3D frames to Injection Moulded parts * Radiator fairing gaps - better supported & vastly reduced * Fuselage join gaps - as above * Elevator clash with fuselage fairing - checked & ok in production Still struggling with the wing / fuselage join but will persevere to improve I just want to say a public thank you to Tolga for taking this on and giving great & fast feedback TTFN Peter Out2gtcha, Kagemusha, LSP_Kevin and 27 others 27 3
Tolga ULGUR Posted February 23, 2025 Author Posted February 23, 2025 3 hours ago, airscale said: More wonderful work Tolga Just wanted to note some great finds this build has led to where improvements have been made - just shows the value of a test build by an accomplished modeller - even if it is in the public domain and you see warts'n'all * Clash between compass and control stick - fixed * Missing throttle parts in Cockpit box - added * Missing rear retractable antenna - added * Canopy changes to adapt from 3D frames to Injection Moulded parts * Radiator fairing gaps - better supported & vastly reduced * Fuselage join gaps - as above * Elevator clash with fuselage fairing - checked & ok in production Still struggling with the wing / fuselage join but will persevere to improve I just want to say a public thank you to Tolga for taking this on and giving great & fast feedback TTFN Peter Thanks for your nice comment Peter, much appreciated It is a pleasure for me to take part in this project. geedubelyer 1
Tolga ULGUR Posted February 23, 2025 Author Posted February 23, 2025 Today s update patricksparks, Biggles87, LSP_Kevin and 30 others 33
Troy Molitor Posted February 23, 2025 Posted February 23, 2025 Tolga, This is most impressive to see come together. Thank you again for sharing this with us. williamj and Tolga ULGUR 2
Tolga ULGUR Posted February 23, 2025 Author Posted February 23, 2025 6 hours ago, Troy Molitor said: Tolga, This is most impressive to see come together. Thank you again for sharing this with us. Thanks Troy
Tolga ULGUR Posted February 24, 2025 Author Posted February 24, 2025 Today's update Wingtip transparent parts are not ready yet. I decided to make it using thick acetate sheet. That's why, I do not use the interior detail part of the kit. LSP_Kevin, Dpgsbody55, Derek B and 26 others 29
Tolga ULGUR Posted February 25, 2025 Author Posted February 25, 2025 Today's update There was a little damage to the tip of the rudder. I fixed it and the rudder was installed. Should we start to paint? MikeMaben, Roy Noras, Stew Dapple and 37 others 40
geedubelyer Posted February 25, 2025 Posted February 25, 2025 Brisk yet brilliant progress Tolga. Keep up the momentum Derek B and Tolga ULGUR 2
Tolga ULGUR Posted February 26, 2025 Author Posted February 26, 2025 11 hours ago, geedubelyer said: Brisk yet brilliant progress Tolga. Keep up the momentum Thanks
dodgem37 Posted February 26, 2025 Posted February 26, 2025 (edited) A jig. One that the bottom/base can set into. Sincerely, Mark Edited February 26, 2025 by dodgem37 Roy Noras, Landrotten Highlander, scvrobeson and 1 other 4
Tolga ULGUR Posted February 26, 2025 Author Posted February 26, 2025 Here is the camouflage scheme Shoggz, Landrotten Highlander, Sepp and 11 others 14
