Although part of the monograph dedicated to the Mirage IIIE, we are finishing this trailer valid as a companion of aircrafts of the era between the 60s and 90s.
It can be opened to let the modeler to mount batteries and switch to have this problem solved over the diorama as happens in the reality. Supplying power for leds for its own lighting and for the aircraft. Consisting of backlighting for the control panel and corner lights for lighting the load jobs. But the main objective of the model is to supply low voltage electricity to the aircraft for its own lighting with leds, such as position and cockpit lights. For this, you can connect real electric cables from the batteries in this model to the aircraft visible on the runway without the need to make holes in the landing gear of the aircraft that weaken its support or complicated lattices under the diorama to reach a front switch. The cables are simply visible on the runway as in any power charging process of a real aircraft.
For the Mirage IIIE, these cables can enter into the aircraft if you have purchased our detailed exterior of the Mirage IIIE, which already includes the ventral opened panel for the power load.
As historical reference, this generator model was used in bases with Mirage IIIE and later with Mirage F1.
Edited by Tecnikit
