Kaeone57 Posted May 3 Posted May 3 Mmmmmm, Typhoon, Mmmmmm! NICE!!!! Car door, or, Bubbletop? My apologies if mentioned before! Alfonso
mozart Posted May 3 Author Posted May 3 28 minutes ago, Kaeone57 said: Mmmmmm, Typhoon, Mmmmmm! NICE!!!! Car door, or, Bubbletop? My apologies if mentioned before! Alfonso This one is a car-door converted from a bubbletop kit Alfonso. LSP_K2 and Kaeone57 2
monthebiff Posted May 3 Posted May 3 Fabulous work Max but that all looks very close and probably very difficult. I'm. Intrigued ! Regards. Andy mozart 1
DerekB Posted May 3 Posted May 3 5 hours ago, mozart said: So the front end has been cut away: Nothing is as simple as it seems. This is so much fun watching this Max! Bravo! mozart 1
mattlow Posted May 4 Posted May 4 18 hours ago, mozart said: I wasn’t sure how the fit of the engine and bearers would go, but it’s now clear that there’s a lot of resin to grind away: As you've got the Revell kit in pieces now, couldn't you graft the relevant thinner parts on here...? Might be an option. Matt
mozart Posted May 4 Author Posted May 4 Well no Matt, the whole idea is to use as much of the MDC kit as possible, just the Revell tail end and the canopy/windshield. Derek B 1
mozart Posted May 6 Author Posted May 6 (edited) A good hour's bench time this afternoon! I started by grinding away the excess resin as highlighted in the last post, and by the way thank goodness I invested in one of these recently: The "heavy duty" work that I have been doing would have taken hours with a knife and sander, but it's literally a few minutes with this beastie! But when I offered the engine up, the prominent wing interlocking tab got in the way: So it had to go. The plan is to pack the wing internal surfaces with plenty of epoxy : I'm planning to fix the wing in place shortly and before joining the fuselage halves together now that I am confident that the engine in its present state (it's not quite finished especially the underside) fits: It would be true to say that this simple conversion has thrown up a couple of unanticipated difficulties, but that's what makes life interesting int' it? Edited May 6 by mozart LSP_Kevin, Landrotten Highlander, Kais and 15 others 18
mozart Posted May 6 Author Posted May 6 No sooner said than done, Solid as the Rock of Gibraltar! Elger, geedubelyer, Greg W and 13 others 15 1
D.B. Andrus Posted May 6 Posted May 6 39 minutes ago, dennismcc said: Nicely done Max, looking good. Cheers Dennis +1 mozart 1
Greif8 Posted May 7 Posted May 7 You did a masterful job dealing with the fit issues Max! Engine conversions always come with fit headaches it seems; even when using the kit parts, and aftermarket engines/bearers rarely fit right out of the gate in my experience. I had to do some trimming and sanding on my recent FW 190 A-8 build, but it looks like you had a more complicated surgery which you did with your usual excellent workmanship. Ernest mozart 1
mozart Posted May 7 Author Posted May 7 Thank you Ernest, I must admit this really is the kind of modelling that I love and find the most fulfilling, which probably explains why my Kotare Spitfire is currently sitting unfinished right now….It’s just too straightforward! Shoggz, wunwinglow, Stevepd and 2 others 1 4
LSP_Kevin Posted May 7 Posted May 7 14 hours ago, mozart said: Thank you Ernest, I must admit this really is the kind of modelling that I love and find the most fulfilling, which probably explains why my Kotare Spitfire is currently sitting unfinished right now….It’s just too straightforward! I suffer from the same preference! Kev Derek B, D.B. Andrus and mozart 2 1
mozart Posted May 10 Author Posted May 10 Rather a lot of shrinkage on the flaps, “fits where it touches”: Tolga ULGUR, Shoggz, LSP_Kevin and 7 others 8 2
