2 hours ago, airscale said:
fabulous project Max & beautiful execution - please tell me, do those Typhoon drawings have fuselage cross sections?
...asking for a friend 😎
They certainly do Peter....tell your friend that he could use them to produce a 3D printed Typhoon if he had the experience, skill and urge to sell lots of kits.  And you could add that once he's done that, he would then have done a lot of the leg work to produce a Tempest!!  Win - win!
Edited by mozart
Very complex, but fun looking build Max, and you are doing a superb job as always.  The CMK Napier-Sabre engine looks fantastic; CMK has upped their game with this aftermarket kit.
Ernest
Your 'friend' has very good taste Peter! 😁
Here is a link to my failed dream...
Derek
  • 4 weeks later...
I wonder how Peter's "friend" is getting on?! :D
Haven't had much chance to get to the bench myself recently, though made some "off-shoot" progress today.  I received the Modelu ground crew figures a week ago....hmmm..they're OK but I've seen better:
and when cleaned up a bit:
That left hand is awful!  The moulding over all is rather soft and vague.
The size has me slightly puzzled too, supposed to be 1/32 scale but I think they are more like 1/35 when I compare them with other figures, and yes, I recognise that there is lots of variation in scale figures.  However, I looked at my diminishing stock of Hornet heads and hands (also 1/35) and managed to change their gender and add a bit more realistic detail:
The "new" right leg was also added to the right hand figure, the original was poor.
I envisage something like this on the Tiffy:
Edited by mozart
1 hour ago, mozart said:
Preacher?
Madonna like a Prayer?
Beggar ?
all great fun!
 Yeah, its still Crazy, but geez i like it very much sir.
Really do not follow builds generally, but now i do and signed up.
Edited by Mal_Belford
The Hornet heads are a massive improvement Max.  I thought the printing of the facial features was far too soft to be able to paint well; the Hornet heads are nice and crisp as they almost always are.  Good work doing the conversion work man!
Ernest
Ernest
Thanks Ernest, I knew you’d appreciate the difference in the figures. When I look at the Hornet range I’m amazed at how such facial expressions and features are possible in such a relatively small scale. Real works of art!
On 2/23/2025 at 8:46 AM, Archimedes said:
Hi Max, that Sabre looks like a model all on its own…
Good luck!
And indeed it is Paul…..and some! For that main reason I have decided that I’m going to start a separate thread for the build of, and of course facts related to, the mighty Sabre. It will be linked to this Typhoon thread and vice versa of course.  See here.
Edited by mozart
Fantastic - can't wait!
Kind regards,
Paul
  • 3 weeks later...
With the Napier Sabre engine nearing completion, my attention is turning to the surgery required to the MDC fuselage halves, cutting off the front end forward of the oil tank and, on the starboard side, cutting out the door opening.  The Bentley drawings show a subtle difference between the shape of the earlier car-door and the panel replacing it on the bubble-top:
Not to mention of course the completely different profiles of the windshield and canopy.  The Revell one isn't great but I can't see too many options for a more accurate alternative.
The Bentley drawings aren’t cheap, but the amount of information on them and the accuracy is such that it gives real confidence in applying any changes.
Edited by mozart
Max I think these drawings should be despatched to Mark (Kotare) repeatedly, until he tells you to stop:ph34r:.
So the front end has been cut away:
I wasn’t sure how the fit of the engine and bearers would go, but it’s now clear that there’s a lot of resin to grind away:
….as shown in red. Ah well, it is what it is, but I also have to bear in mind the way in which the “tongues” on the wings interlock with each other and the fuselage when glued in place! Nothing is as simple as it seems.
Edited by mozart
