Uncarina Posted January 21, 2025 Author Posted January 21, 2025 (edited) Finished up the cockpit by adding the rigging, final details, and decals: And then, all too soon, the cockpit and fuselage is joined together: And time to see what else I can attach: The fit is actually very good--the fuselage mates to the LMD engine almost perfectly with some slight adjustment to the thickness of the plastic where it meets the resin. And the fuselage width exactly matches, as well as the curvature of the wing interface. I'm starting to think I will pull this off! Cheers, Tom Edited February 7 by Uncarina Fanes, LSP_Kevin, Anthony in NZ and 16 others 19
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 (edited) Getting there: Edited February 7 by Uncarina Kagemusha, Shoggz, Anthony in NZ and 20 others 23
Kagemusha Posted January 28, 2025 Posted January 28, 2025 Looks great, certainly looks like you've pulled it off in mighty fine style. Uncarina and Martinnfb 2
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 1 hour ago, Kagemusha said: Looks great, certainly looks like you've pulled it off in mighty fine style. Thank you! It’s the home stretch for the conversion. Cheers, Tom Martinnfb 1
MikeMaben Posted January 28, 2025 Posted January 28, 2025 Yikes, I thot 'my' bench was a mess Biggles87, Uncarina, IainM and 1 other 4
geedubelyer Posted January 28, 2025 Posted January 28, 2025 21 minutes ago, MikeMaben said: Yikes, I thot 'my' bench was a mess Doesn't Tom's bench just make you feel at home though? I didn't even give it a second thought because my bench looks just the same Great progress Tom Martinnfb and Uncarina 2
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 4 hours ago, geedubelyer said: Doesn't Tom's bench just make you feel at home though? I didn't even give it a second thought because my bench looks just the same Great progress Tom Thank you! And yes the bench is a mess. It’s amazing how rapidly this happens after the start of a build. Cheers, Tom Martinnfb and geedubelyer 2
geedubelyer Posted January 28, 2025 Posted January 28, 2025 I can relate to that Tom. I work on a desk but I only have about 6" square of clear space at any one time. I don't think we're the only ones Martinnfb, Biggles87 and nmayhew 2 1
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 7 hours ago, geedubelyer said: I can relate to that Tom. I work on a desk but I only have about 6" square of clear space at any one time. I don't think we're the only ones Glad I'm not alone! After all, cleaning up takes away from bench time. Cheers, Tom geedubelyer and Martinnfb 2
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 (edited) Added the Tamiya AS-12 primer. Since I added the set of outer 20mm cannons I had to open up the spent cartridge slots--I had to look hard at my references to see where they were located. Cheers, Tom Edited February 7 by Uncarina Biggles87, Madmax, Sasha As and 15 others 18
Martinnfb Posted January 28, 2025 Posted January 28, 2025 Great progress Tom, regarding the bench, I see a perfectly organized work space Cheers Martin Terry1954 and Uncarina 2
Uncarina Posted January 28, 2025 Author Posted January 28, 2025 4 minutes ago, Martinnfb said: Great progress Tom, regarding the bench, I see a perfectly organized work space Cheers Martin Thanks Martin! I'm glad I'm not the only one to see it ☺️. Cheers, Tom Martinnfb 1
John1 Posted January 29, 2025 Posted January 29, 2025 Very nice work, great job on the overall finish. Uncarina 1
Uncarina Posted January 29, 2025 Author Posted January 29, 2025 8 hours ago, LSP_Kevin said: Looking good, Tom! Kev Thanks Kev! 3 hours ago, John1 said: Very nice work, great job on the overall finish. Thank you John. It took a bit of adjusting but it’s definitely a doable conversion. The biggest adjustment is actually to the cockpit floor.Tamiya has it molded onto the wing section but Kotare has this as a separate piece. This meant I had to sand it wafer thin for the Tamiya wing to fit to the Kotare fuselage. Cheers, Tom John1 1
