after getting really frustrated with the canopy 3d model for not being solid and therefor not printing, I re-drew the whole damn thing in a different way.
I think the open access hatch gave access to the canopy lock. So one could open it from the outside. I'll fashion a similar kind of lock as was present in the pilot's canopy.
Reprinting the canopy tomorrow, together with a positive vacform shape to fashion the glass. The canopy needed to be 1mm longer.
Adding tubular framing to the inside of the canopy hood and need to add the lock and handhold.
Also having to 3d model the gunsight bracket. Seriously every single MDC part is bend, foggy, shrunken, etc.
Finally after 20 tries i think i’m pleased. I made a ‘step’ in the upper canopy so that the transparent part becomes flush with the rear. If that makes sense. Need to cut and sand it so size, but this will work.
Also made a few new nose glazing parts. This will be tricky-er.
2 hours ago, Gazzas said:
How do you get such clear pulls?  They look fabulous.  PetG?
Indeed. PetG. I wasted about 20 sheets. The shape i use as a positive had to be 100% smooth so polishing had to be repeated numerous times. And the heat has to be just perfect.
too much and the plastic turns white. Still not happy with the nose cone so not sure what my next step is there.
