Phil Smith Posted November 7, 2024 Posted November 7, 2024 (edited) As I enter the painting phase of one scale model, I prep for the next. This, of course, means I generally have a couple to three models being built at once. I also have a stash that frankly needs to be addressed. In this case, my 1/32 Bf-109 G-14 is in priming and painting stage. That itself will take weeks to realize, but in the meantime I've cracked open Tamiya's 1/32 F4U-1D Corsair. First order of business in this regard is the engine (my favorite thing to work on). Though Tamiya's engine is great straight out of the box, I selected Eduard's Brassin kit for this assembly, mainly because I hate seams on complex parts like the cooling fins on piston casings. The parts go together very well and require little cleanup. After priming, I painted the engine casing XF-53 (Neutral Gray) which seemed a good approximation. I added a dry brush treatment of Testors Chrome Silver over Zinc Chromate for some wear and tear. After a gloss coat, I added a serial number plate decal and Tamiya's black panel liner. The other engine parts were primed with Alclad II gloss black, as I wanted to use metallics for these. The pistons required a bit of assembly (spark plugs and some exhaust pipes); these were painted Alclad II Chrome and the exhaust pipes Testors Metallizer Burnt Iron. The piston casings should be a dull aluminum color, but I new the chrome would be toned down after a flat clear coat while still retaining a bit of depth. After a gloss coat, the piston covers were painted XF-1 (Flat Black). After assembly, I used lead wire for spark plug leads, intercylinder drain hoses, and various other greeblies. These were painted XF-78 (Wooden Deck Tan) with details in various random earth tones for variety. Some weathering using powdered graphite finishes this off. Everything was united with a dusting of XF-86 Flat Clear, touching up the push rods with X-22 Clear Gloss. More engine work remains, of course, and this is the objective of the coming weekend in between Bf-109 painting sessions Edited November 7, 2024 by Phil Smith John1, Greif8, KiwiZac and 28 others 31
Sturmbock Posted November 7, 2024 Posted November 7, 2024 Wonderful details, I especially like the ignition cables, the whole engine is awesome! Lutz Phil Smith 1
John1 Posted November 11, 2024 Posted November 11, 2024 Engine looks great. Enjoy the kit, I built this one a few years ago, I think it may be one of the best plastic models ever released. It’s really that good of a kit. If you haven’t done so already, check out Fundekals Corsair sheet, it’s fantastic. Phil Smith 1
Dpgsbody55 Posted November 11, 2024 Posted November 11, 2024 An excellent start. If the rest of the model is as well done as the engine, this will be magnificent. Cheers, Michael Phil Smith 1
Phil Smith Posted November 12, 2024 Author Posted November 12, 2024 On 11/10/2024 at 11:45 PM, John1 said: Engine looks great. Enjoy the kit, I built this one a few years ago, I think it may be one of the best plastic models ever released. It’s really that good of a kit. If you haven’t done so already, check out Fundekals Corsair sheet, it’s fantastic. Thank you - and I took your advice and that of others on this decal sheet. Very much appreciated John1 1
Phil Smith Posted November 22, 2024 Author Posted November 22, 2024 (edited) More progress on the engine. I decided to do a dumb-ish thing, which is to connect exhaust pipes with simulated rubber hose sections tightened with hose clamps. I didn't like the way the plastic exhaust pipes connected to the resin engine (rather, they didn't), so I decided to bridge the gap using the smallest diameter heat shrink tubing and Anyz's hose clamp decals, which are excellent. Needless to say, this involved a bunch of hoses and hose clamps, but it worked out well. Why is this dumb-ish? Because one wouldn't bridge hot exhaust tubing with rubber hoses! Meh - I liked the effect and it adds interest. Next up - the cockpit! Be well, folks Edited November 22, 2024 by Phil Smith Furie, Memphis, Landrotten Highlander and 20 others 23
SwissFighters Posted November 22, 2024 Posted November 22, 2024 Looks great Phil! Terrific weathering - I really like the colour of the weathering which appears dirty but not "rusty." Thanks for sharing! Tony Phil Smith 1
JeepsGunsTanks Posted November 22, 2024 Posted November 22, 2024 That's an amazing-looking R-2800! Well done! Phil Smith 1
nmayhew Posted November 23, 2024 Posted November 23, 2024 that engine deserves to be exposed if it's covered up, you deserve to be committed! 😃 are those Anyz strips just thick decals? i was thinking of them for landing gear oleos but having to guestimate the length required would be as tedious as their application I am thinking? I'm looking forward to an airframe as weathered as its engine! Phil Smith 1
Shoggz Posted November 23, 2024 Posted November 23, 2024 Gorgeous engine work and detailing! Phil Smith 1
Phil Smith Posted November 24, 2024 Author Posted November 24, 2024 On 11/23/2024 at 5:59 AM, nmayhew said: that engine deserves to be exposed if it's covered up, you deserve to be committed! 😃 are those Anyz strips just thick decals? i was thinking of them for landing gear oleos but having to guestimate the length required would be as tedious as their application I am thinking? I'm looking forward to an airframe as weathered as its engine! Thanks - the Anyz strips are thin (good idea that these could be made as 3D decals to represent hose clamps that use a rubber backing. They probably wouldn't work for oleos, especially since the silver is shiny but not chrome. nmayhew 1
