Gazzas Posted October 20, 2024 Posted October 20, 2024 (edited) Greetings fellow LSP'ers. It's been a while since my last WIP. But thanks once again to fellow LSP'er Mr. G I am able to have the materials to make the 1/32 Scale Trumpeter JU-87B hopefully look decent. I'm pretty sure we've all seen Thierry Laurent's brilliant post on what is wrong with this kit. I won't be fixing everything. I just don't have that kind of dedication. Provided by Mr. G. is an ancient 1/32 scale JU-87B made by Revell. I built this one as a 12 or 13 year old. I have to admit, I trashed the thing. Especially the snake decal. I am mainly going to make changes to the horrible front end, the squat LG, ETC racks and ordinance. The only AM will be a Master Barrels Mg-15 barrel and sights. Of course, a figure or two will be mandatory. I wanted to get the majority of the hacking done in the nacelle area done before my first post. I really had to hack apart the Revell motor to get it to fit amongst the Trumpy parts. The Trumpy exhausts are much better than the Revell parts. So, I had to use the bits of the Trumpy kit that would allow them to be used. The Revell Radiator bath has a much more elegant shape than the Trumpy. Also, the radiators close-able louvres look much better than Trumpy's grill-look. The most important point of this early part of the exercise is to get the nacelle parts to meet up properly behind the Revell Spinner. As you can see by the yellow arrow, there is a slight length issue to be dealt with later. My cut marks aren't pretty. But they'll be hidden anyway. It took a bit of work to get things right up front. But a clean look up front was achieved. Of course, there is a lot of work to do to get it pretty. And tape doesn't do a great job of holding little pieces in place. But we'll get there. Propeller blades are up for changing, too. the Trumpy blades will be hacked and re-shaped to hopefully resemble the JS-11 blades that should go on the machine and the Revell blades will be gently removed. Thanks for looking, and lemme know what you think. cheers! Edited October 20, 2024 by Gazzas CShanne, Panzerwomble, Greif8 and 30 others 32 1
Greif8 Posted October 20, 2024 Posted October 20, 2024 Good to see you back at the bench Gary! This is an ambitious project to be sure and I am interested to see how you tackle it. You have made a solid start! Ernest Gazzas and Martinnfb 1 1
MikeMaben Posted October 20, 2024 Posted October 20, 2024 We always like to see the golden oldies brought back to life. Have fun Gary. Gazzas and Martinnfb 1 1
Rick Griewski Posted October 20, 2024 Posted October 20, 2024 I am so glad you are giving that Trumpeter kit a good spanking. What better for Halloween than a face change for the original bat out of hell aircraft. I found another Revell kit so will be copying I mean watching your work. Greg W, Martinnfb, Gazzas and 2 others 1 1 3
Biggles87 Posted October 20, 2024 Posted October 20, 2024 I haven’t seen a Stuka build for ages so I’m in. John Gazzas, Martinnfb and Rick Griewski 2 1
Gazzas Posted October 29, 2024 Author Posted October 29, 2024 Welcome back, fellow modellers! I find it somewhat therapeutic cutting and filing and sanding. But every man has his limits... I'm OK for now. After getting the general shape and front alignment of the propeller spinner right, I had to start working on the rear end of the nacelle. My two concerns were alignment of the profile of the nacelle, and that the propeller axis was in the right place. Not sure where I would cut next, I spent a couple days looking at resources and was still not really certain how I would approach the problem. I had hopes that I wouldn't have to do any cutting around the crew compartment. Then, a stroke of luck! I happened upon a facebook post where some guy was proudly displaying his Trumpy JU-87 B with it's desert camo. I immediately saw what was so wrong with the kit. Aside from shape differences, the axis of the propeller was far too high. so, referring to drawings, I was able to see that the axis of the propeller coincides closely with the top edge of the wing where it meets the fuselage. When I aligned my nacelle with the top edge of the wing, it becomes apparent that the fuselage under the wing does not slope down enough. This saved me from having to mess around with the crew compartment. But I still needed to reshape the fairing immediately in front of the canopy. And there was much to be done with the Revell cowling. Firstly I had to make it's profile match the profile of the trumpy fuselage. I used my favorite quick filler of Black CA and baking soda as filler. I also wanted to fix some small problems with the upper intakes and exits where Revell had some ambiguous shapes. this included creating a new flap for the exit end. The flap is only dry fitted and will get better alignment, later. At any rate, nothing has been put to the primer test, yet. I want to make it all work, before I make it pretty. Thanks for looking, and as always, I'd love to hear your thoughts or ideas. Paulpk, thierry laurent, RBrown and 27 others 30
MikeMaben Posted October 30, 2024 Posted October 30, 2024 Excellent catch Gary Martinnfb, BiggTim and Gazzas 2 1
Rick Griewski Posted October 30, 2024 Posted October 30, 2024 I will check my Trumpeter Stuka G kit later today for the same issue. If bad I will keep it to myself, but there will be signs. BiggTim and MikeMaben 1 1
Greif8 Posted October 31, 2024 Posted October 31, 2024 Great research and even better modeling skills to make the correction your research found Gary. Ernest BiggTim, Gazzas and Martinnfb 2 1
thierry laurent Posted October 31, 2024 Posted October 31, 2024 Modelling at its best... Martinnfb, Gazzas and BiggTim 2 1
Martinnfb Posted October 31, 2024 Posted October 31, 2024 I love where this is going Gazzas and BiggTim 1 1
BiggTim Posted October 31, 2024 Posted October 31, 2024 (edited) You are an animal, sir!! Has anyone ever made corrected AM nose for this kit? Also, didn't Rutman make a set of VS111 props for the Stukas? Edited October 31, 2024 by BiggTim Martinnfb 1
Martinnfb Posted October 31, 2024 Posted October 31, 2024 https://www.scalemates.com/kits/brian-fawcett-ju87b2-1-32-junkers-ju-87-stuka-b2-and-r2-correction-set--1123992 europapete and BiggTim 2
Rick Griewski Posted October 31, 2024 Posted October 31, 2024 4 hours ago, BiggTim said: You are an animal, sir!! Has anyone ever made corrected AM nose for this kit? Also, didn't Rutman make a set of VS111 props for the Stukas? IIRC these were for his G conversion. And Fw-190D. The B needs the VS-11. Same as He-111 Martinnfb and BiggTim 2
Rick Griewski Posted October 31, 2024 Posted October 31, 2024 I heard here on LSP that The fawcett set is OOP or maybe available for by special pleading. Martinnfb and BiggTim 2
