Sasha As Posted November 24, 2024 Author Posted November 24, 2024 7 hours ago, scvrobeson said: That's a nice looking little mini chisel. Where did you get it from? Matt Matt I've had a chisel for a long time, it came in handy in this case, but where I got it I don't remember )))). scvrobeson 1
Sasha As Posted November 26, 2024 Author Posted November 26, 2024 It's time to show the very nuance with the prefenders))))). The steps are spackled. KiwiZac, Greif8, Paul in Napier and 7 others 10
Sasha As Posted November 28, 2024 Author Posted November 28, 2024 The sanding process is complete. The steps are removed. We can move on. KiwiZac, scvrobeson, Brett M and 18 others 21
Greif8 Posted November 30, 2024 Posted November 30, 2024 Good work on sanding the wings Sasha. Getting rid of steps can be an irritating task from time to time and you did it well. Ernest Sasha As 1
Sasha As Posted November 30, 2024 Author Posted November 30, 2024 6 hours ago, Greif8 said: Good work on sanding the wings Sasha. Getting rid of steps can be an irritating task from time to time and you did it well. Ernest Ernest thank you !
Sasha As Posted December 2, 2024 Author Posted December 2, 2024 Loaded the bow section. That should be enough by calculation. Glued the fuselage together. It's a medium fit. Putty's a big help. Biggles87, Greg W, LSP_Kevin and 14 others 17
Greif8 Posted December 3, 2024 Posted December 3, 2024 Looking good Sasha, and I am positive you have enough nose weight man! Ernest Sasha As 1
Sasha As Posted December 3, 2024 Author Posted December 3, 2024 1 hour ago, Greif8 said: Looking good Sasha, and I am positive you have enough nose weight man! Ernest Ernest thank you !
Sasha As Posted December 5, 2024 Author Posted December 5, 2024 I tried on the air intakes. It's not all smooth sailing. I haven't glued them on yet. Fuselage spackled. Ahead of sanding and restoration work on the fuselage. LSP_Kevin, Greg W, Rocat and 14 others 17
Cheetah11 Posted December 5, 2024 Posted December 5, 2024 Hi Sasha, nice work on the A-4. I completed an A-4H at the beginning of the year and found a few corrections to make. I only found this after assembly , so some sanding and re-painting was needed. The A-4E only has one angle of attack vane on the port side. The ailerons are a bit too thick and needed sanding down, obviously easier before fitted to the wing. On my example the windscreen was a little too narrow. I could not fix this with hot water. If I had to build another I will make the fuselage a little more narrow(by about 1,5mm). Cheers Nick Sasha As 1
Sasha As Posted December 6, 2024 Author Posted December 6, 2024 8 hours ago, Cheetah11 said: Hi Sasha, nice work on the A-4. I completed an A-4H at the beginning of the year and found a few corrections to make. I only found this after assembly , so some sanding and re-painting was needed. The A-4E only has one angle of attack vane on the port side. The ailerons are a bit too thick and needed sanding down, obviously easier before fitted to the wing. On my example the windscreen was a little too narrow. I could not fix this with hot water. If I had to build another I will make the fuselage a little more narrow(by about 1,5mm). Cheers Nick Nick thank you! I'll know there could be a problem.
Greif8 Posted December 8, 2024 Posted December 8, 2024 This is really looking great Sasha. You are doing outstanding work fixing all the issues with the kit and I think the end result will look superb! Ernest Sasha As 1
Sasha As Posted December 9, 2024 Author Posted December 9, 2024 20 hours ago, Greif8 said: This is really looking great Sasha. You are doing outstanding work fixing all the issues with the kit and I think the end result will look superb! Ernest Ernest thank you !
thierry laurent Posted December 9, 2024 Posted December 9, 2024 Hi. I like what you did up to now. Have a look here: this will help you in correcting various other minor external errors: https://www.largescaleplanes.com/articles/article.php?aid=2786 Hth Thierry Sasha As 1
vvwse4 Posted December 9, 2024 Posted December 9, 2024 Hi Sasha, Looking good. What do you use for putty? I cannot figure out the black. Rick. Sasha As 1
