Madelf75 Posted October 28, 2024 Posted October 28, 2024 This has to be one of my favorite it's . The fit is really good . Sasha As and Martinnfb 1 1
Specter1075 Posted October 29, 2024 Posted October 29, 2024 22 hours ago, MikeMaben said: Hello Spec Howdy! I created my account nearly fifteen years ago, but have tended to be a reader more than a writer. I guess age has changed me. Shoggz, Mebo, Paul in Napier and 1 other 4
Sasha As Posted October 29, 2024 Author Posted October 29, 2024 14 hours ago, Madelf75 said: This has to be one of my favorite it's . The fit is really good . Madelf75 thank you ! Martinnfb 1
Sasha As Posted October 29, 2024 Author Posted October 29, 2024 Moving on to the recesses of the main chassis struts with the cannon compartment. The resin parts are warped, the left and right niche have differences in size. Stotochil all the attachment points on the wing under the niches from the set. With difficulty they are in place. Still need to be adjusted. But the main surprise is a gap of almost 3mm between the wing halves. It will be necessary to remove not only the thickness of the resin, but also the plastic, otherwise it will not be enough. Gazzas, Paul in Napier, Shoggz and 8 others 6 5
Specter1075 Posted October 29, 2024 Posted October 29, 2024 Aires is absolutely notorious for that issue. Sometimes you can thin the resin and plastic enough to make their parts fit, and sometimes you can't. It is inexcusable that a company can create parts that are totally unusable but they do. I've thought at times about creating a database of Aires parts identifying which sets fit and which do not, but never worked up the ambition. Paul in Napier, Sasha As, KiwiZac and 3 others 6
Sasha As Posted October 30, 2024 Author Posted October 30, 2024 7 hours ago, Specter1075 said: Aires is absolutely notorious for that issue. Sometimes you can thin the resin and plastic enough to make their parts fit, and sometimes you can't. It is inexcusable that a company can create parts that are totally unusable but they do. I've thought at times about creating a database of Aires parts identifying which sets fit and which do not, but never worked up the ambition. Specter1075 I totally agree with you ! Martinnfb 1
Sasha As Posted October 31, 2024 Author Posted October 31, 2024 The resin recesses are as much as possible. Top of the wing too. As much as possible. It all worked out. The wing halves came together. Glued the cannons, detailing small in the niches. Glued it to the bottom of the wing. The positioning here should be very precise, just a little past and again not fit. Martinnfb, Greif8, TankBuster and 13 others 16
Greif8 Posted October 31, 2024 Posted October 31, 2024 Very fine work on some tough issues Sasha. I agree with Spectre about Aires stuff I have had some really interesting challenges with their stuff in the past. Ernest Specter1075, Sasha As and Martinnfb 2 1
RichSpreier Posted October 31, 2024 Posted October 31, 2024 1 hour ago, Greif8 said: Very fine work on some tough issues Sasha. I agree with Spectre about Aires stuff I have had some really interesting challenges with their stuff in the past. Ernest I just finished an A-4 using all of the same Aires stuff. I think I saw on this site that Aires means "it doesn't fit" in English. Martinnfb, Sasha As and Specter1075 3
Sasha As Posted October 31, 2024 Author Posted October 31, 2024 2 hours ago, Greif8 said: Very fine work on some tough issues Sasha. I agree with Spectre about Aires stuff I have had some really interesting challenges with their stuff in the past. Ernest Ernest thank you ! Martinnfb 1
Sasha As Posted November 2, 2024 Author Posted November 2, 2024 Glued the wing halves together. It's all done. Assembled ailerons, tail. KiwiZac, Paul in Napier, MikeMaben and 10 others 13
Martinnfb Posted November 2, 2024 Posted November 2, 2024 Meticulous work Sasha. Cheers Martin Sasha As 1
Sasha As Posted November 2, 2024 Author Posted November 2, 2024 25 minutes ago, Martinnfb said: Meticulous work Sasha. Cheers Martin Martin thank you !
Greif8 Posted November 3, 2024 Posted November 3, 2024 Superb work Sasha, that interior looks gorgous. Ernest Sasha As 1
Sasha As Posted November 3, 2024 Author Posted November 3, 2024 5 hours ago, Greif8 said: Superb work Sasha, that interior looks gorgous. Ernest Ernest thank you !
