John1 Posted August 25, 2024 Posted August 25, 2024 Finally done with my close to 1 year project building a UH-60L out of the Kittyhawk MH-60S kit (not nearly as easy of a conversion as I originally anticipated). To the base kit, I added a ton of aftermarket (including Werner's Wings decals, floor armor panels, horizontal stab, interior bits, Live Resin M240's and mounts, Reedoak's helmets and helmet bags, Quinta seat belts, Eduard steam gauge IP panel) and an equal amount of scratch built details. Also replaced all the recessed rivets with either .03mm solder balls or Archer's awesome rivet decals. Subject is a hardworking Lima flying in circa 2007 OIF making another "ass and trash" run out to a FOB. Loach Driver, Model_Monkey, Polecadt and 22 others 25
Shoggz Posted August 25, 2024 Posted August 25, 2024 That’s a superb build. I love the weathering- top notch. John1 and Martinnfb 1 1
thierry laurent Posted August 25, 2024 Posted August 25, 2024 Wonderful build!!! John1 and Martinnfb 2
Cbowling Posted August 26, 2024 Posted August 26, 2024 The weathering looks great. It’s got that “used” look, just like the real ones. I also like the non-slip surface on the cabin floor. Thanks for sharing. Martinnfb and John1 2
John1 Posted August 26, 2024 Author Posted August 26, 2024 10 hours ago, Cbowling said: The weathering looks great. It’s got that “used” look, just like the real ones. I also like the non-slip surface on the cabin floor. Thanks for sharing. Thank you! That non-slip on the cockpit floor is actually BAPS plates (Blackhawk Armored Panel System). A floor armor kit that was added to every UH-60 that was deployed to Iraq / Afghanistan. The set came from Werner's Wings. Martinnfb and Cbowling 2
Rod Bettencourt Posted August 26, 2024 Posted August 26, 2024 Oh I dig this! great looking build all around. Thanks for sharing. Rod John1 and Martinnfb 1 1
Aluxe Posted August 2 Posted August 2 The Black Hawk— the helicopter I like best of all... Maybe it was a photo the local newspaper published of the invasion of Grenada; I had never seen one before, and I fell in love with it. Its performance is equally fantastic... I love it! Martinnfb and John1 2
Loach Driver Posted August 5 Posted August 5 Stunning build, John, as always. Full commitment to getting the most accurate finish possible. 👍 LD. Martinnfb and John1 1 1
Martinnfb Posted August 5 Posted August 5 You are a madman John, in a good way. That level of dedication and attention to detail is inspiring. Bravo! What was your source of soldering balls and how much did you needed to cover the whole thing? I am planning to challenge my sanity with the KA-52 riveting job. Cheers Martin John1 1
John1 Posted August 6 Author Posted August 6 6 hours ago, Martinnfb said: You are a madman John, in a good way. That level of dedication and attention to detail is inspiring. Bravo! What was your source of soldering balls and how much did you needed to cover the whole thing? I am planning to challenge my sanity with the KA-52 riveting job. Cheers Martin Thank you! I got the solder balls from Amazon. I think my WIP has details about how I applied them. Regarding them, I burned out pretty quick on using them exclusively. Ended up using Archer’s rivet decals for the straight runs and the solder balls for smaller, curved or non-uniform runs. Much quicker and I was very pleased with the results. Have fun on your Ka-52 build, that’s a bad -ass helo! Martinnfb 1
