517 -
Days Won
8
Posts posted by Antonio Argudo
This is what RLM 74 looks like, I have several samples from 5 different 109/190's and big chunk of flap in 74 color and all they match , so I know how it looks like and not like in your relic which looks way too green
Also been measuring it with my Nix color sensor my relics
this is RLM 74
1 hour ago, Vincent said:
So here you make a rule out of your very limited knowledge
The color picture of the plane he is modelling is conclusive in any case
still you have not brought any proof or evidence of what you claim as I did, only arrogant words!
the only thing I agree is that the picture is conclusive, it shows RLM 81 brown, RLM 82 green and late "sky" 76
always a pleasure, cheers
The fact that you have never seen the late 76 "sky" used combined with 74/75 means next to nothing : I have a cover panel with 74 painted in the factory on top of late 76 "sky"
yes, it means something, that it is not a very usually thing seen, just that, Mr. know it all
and please post pictures of your claims!!
Thank you guys!!!
a bit of progress on this bird, applied in some areas british Dark Green as repainted in field apparience, also the serial numbers on the tail.
cheers
17 minutes ago, reserve_22 said:
Peace
sure, I think we agree to disagree
-First tip, never trust a profile artist, I know by experience
-The photo it is NOT colorized, it is original slide 100%
-Very important point is, Never seen the late 76 "sky" used combined with 74/75 but only with late 81/82/8... (the cowling seems from another 109 donor) colors are similar to the australian 109 which is the only one with its original colors preserved
-RLM 74 didn't have that intense green tint as we see in the picture, I attach a picture of my 109 flap in 74, all match to be late war combination camo colors not standards greys
-Here more comparison between 75 and 81 brown, the difference is clear and matches the reference photo of the subject
-the tail is solid 81 brown with snake green mottling
-Model by Chris Wauchop, I won't make any obvious comment about his expertise on the matter
cheers
This are 74/75/76 colors
Here is a comparison with some relics I have in those 74/75 colors from a Bf109G10
here is Fw190F8 stab fairing I have with brown late war color, also with late yellow 76 "Sky"
- Paul in Napier, Victor K2 and duke_
- 3
I personally think it is not rlm 74/75 but a late war brown and dark green call them as you like 81/82/8... plus you can see the yellowish late "sky" 76 not the bluish 76, not standard grey camo!
cheers
- Paul in Napier and duke_
- 2
12 hours ago, John1 said:
Mike, those are great images, had no idea there was an unrestored late war 109 cockpit out there (aside from the Australian example). Any other pics available to share?
WNF G10 at Planes of fame, unrestored cockpit, notice the wood floor and the asymmetrical bulky cannon cover, cheers
11 hours ago, MikeMaben said:
Hi Troy, I would only counter that by saying there was more than one 66.
Later in the war 66 took on a slightly green tinge. Here's a G-10 unrestored.
You can see a difference between the cockpit color and the 66 on the canopy framing.
Remember too, it's all about the lighting.
that is the G10 at Planes of Fame, to me seems that the top it has been infield repainted with RLM 70, not 66, it never had a green tint, you can see different shades of RLM 66, from very dark almost black, to more lighter and bluish shade at the end of war, I have these samples from very dark 66 from 109F windshield frame which was sandwiched and never saw light until last month, also a Ju88 cockpit part and a bluish compartment fragment from the same 109F, and look at this other 109G (not mine) partial instrument panel untouched, so...
36 minutes ago, spartacus2000 said:
Hi Antonio I don't know if it is a desired effect but it seems to me that the central area of the wings on the right and left are greener than the external areas that have a decidedly brown dominant.
Maybe it's a photo effect but it looks like this on my monitor.Yes, that was on intentionally, there was a lot of repaint done in those Razorbacks, here it is a real example from a P51B ammo wing panel, you can see the OD(brownish shade) the invasion stripes (black and white) and the top layer of RAF Dark Green paint, so that's what is my aim cheers
On 6/22/2021 at 9:26 PM, spartacus2000 said:
Hi Antonio.
to prevent white from showing on the edges below the blue I usually mask the outline of the mask 0.5mm or so on.
Your work is still impeccable, the masks give the model a finish that the decals, even if perfect, fail to give
thanks for the tip, helpful indeed! cheers
5 hours ago, RaceFuel said:That really looks fantastic! What colors did you use in the marbling and weathering of this? Did you base the XF-62 with something or do any sandwich shading?
thanks mate, I used Gunze H-304 over the tamiya base, I have applied some ink filter to make the OD more brownish, next is to paint full invasion stripes and cover them with RAF Dark green but also still kinda translucent and evident what's underneath
thanks for watching , cheers
20 hours ago, LSP_Kevin said:
Wow!
Kev
Thanks Kev, it's paint time, finally
my first insignia paint with a mask, my fault didn't aligned it perfectly but it's ok lol, after you try there's no point back to decals ever....
Cheers
after a break, I put a XF62 base color
next some Neutral grey, cheers
Hi jeff, nice project
this article is quite interesting about cockpit colors, hope it helps, cheers
https://drive.google.com/file/d/1ly1fP0q11S90COXzmpmFxmr7EZU0PpUm/view?usp=sharing
- TAG, D.B. Andrus, B-17 and 2 others
- 5
after some more research I think it is clear that detail should be gone
- Paul in Napier, Uncarina, coogrfan and 1 other
- 4
Hans Döbrich's mission over Murmansk historical recreation video
in Aviation Discussion & Research
Glad to share the fantastic work of Soto Cinematics which I collaborate with for the historical recreation of Döbrich mission on 19/7/1942 over Murmansk, I made the scheme and marking for the 109's, hope you enjoy it, please like and subscribe to support the channel
