1,172 -
Days Won
13
Everything posted by F`s are my favs
KH T-6/Harvard Kicked Up A Notch: Apr 14/20: Finished!
F`s are my favs replied to chuck540z3's topic in Works in Progress
wow that did happen to my Raptor in 1/72 during the giod old days I tried to imagine the real plane flying throough the air by handling the model right in front of a fan heater... the airflow was very enjoyable, but after that the closed canopy accepted the shape of the seat and the ip hood. :d some of the plastic along the leading edges also softened. I use this model for tests and experiments now. On to the topic, I also think a vacuformed canopy would be the best solution. -
Thx Brett. Yep, I'll take good care of them with the oil canning effects.
oooh, it went just beautifully I'm very happy right now. The merging of the canopy and the frame went perfectly... I don't know how much it is visible from these pix, but enjoy!
F-117A Nighthawk (channelling my inner scratch builder)
F`s are my favs replied to Uilleann's topic in Works in Progress
Hi When the Spirit (the mojo, not the B-2) is good, then the black side should come from where it was (the Darkside, not the darkness) and resurrect the lightness , which will .... I don't know . . . I might be a little drunk, not that much, but, Lockheed rulez! Just make it real gut! It's an absolute beaut and it's almost on the final stretch. -
I had to put the canopy up a bit with two tiny shims, which caused tiny tiny spaces along the side edges. The front side edge has a little bit of space and imperfections too, but it will be covered whatsoever so I "filled" the side edges only. With long stripes of 1mm plastic, then a little bit of sanding at "at an angle", and they are perfect now. Can you see the darker plastic along the edges of the sides: Then the frame is riveted, detailed and painted too - black acrylic first: ... and weathered: Now finally the gluing of the canopy. . . . .
Canopy adventures... So basically I "reupholstered" the inner side of the frame with 1mm plastic sheet to add more thickness. That's how it was before: and after, with the detailing and the 2 hidraulics for the closing/opening: Then, I'm about to change the plastic zig-zag ram pattern with PE pieces. The original plastic ram is too too thick and had imperfections from the cutting: Still not glued but those are the PE pieces:
Sepecat Jaguar GR3.A / GR1.A in 1/12th Scale
F`s are my favs replied to Timmy!'s topic in Works in Progress
wicked evil! -
The adventure with the side frames of the cockpit. OOB they are just long clean pieces of plastic... That's how they look like in the real plane: I made provision for the canopy handle and for this huge black knob in the pic above, then I glued another stripe of plastic with the same thickness undernead and sanded them. The two cooling tubes that go into the frames are also added while the cooling grids will be easier to add after the painting - with just thin stripes of tape... and it is so much better now. Still not painted though.
The cockpit rear bulkhead. A lot of cockpit mods are going on and at least that part is just about done. Here it is before: And those are the hydraulics for the opening of the canopy in their imaginary positions (not functional yet). I somewhat cheated and made them retractable 'through' the bulkhead. One shows how they should look like when the canopy is open and the other - when the canopy is closed. And here it is painted, with wires and rivets and basically it's prepped:
1/32 Kitty Hawk F-5E/N: "Kicked Up A Notch"
F`s are my favs replied to chuck540z3's topic in Ready for Inspection
Gorgeousness at its finest... What else to say the 7th and 18th pics from top to bottom are my most fav ones! -
Basically the same journey with the side panels... The vertical side panels are done too and they are glued to these side panels. All is weathered good and I`m dealing with the closing/opening of the canopy... i.e the rear bulkhead of the cockpit. Hopefully it will be ready for pix soon.
Tomcat, Afghanistan, OEF, 2002, Diamondbacks.... sounds like a very nice plan! :) And that's a wonderful start. Make it real good, keep us posted, and WELCOME! :)
- 24 replies
hi Squizzy, it's awrsome to see another huge Nighthawk! nice IPs for start!
The main ip is done: - the amount of holes; - the rods to replace the switches/knobs; - and the ready thing...
btw here is a video of the FLIR testfitted and the tourette rotating.
well they are in a reversed order but I'm at the ip now. cheerio
again sry about the lack of spacing between the images. The nlg is ready and glued in the bay, which is then glued to the cockpit tub and then all will be glued to the lower fuselage cause its easy this way (for the making of the nlg bay door and the canopy moveable). So for the cockpit, i decided to make something for the first time as well - replacing the toggle switches and the knobs with plastic rods, then cut them, shape them, etc. I have now micro drills and can make tin almost invisible holes, so they will get in use nicely here. the side panels are the testbed and they are just about done... still plenty of detail to be made. Then i got started with the main ip. its painted and the decals are added. I have Micro Set and used it, it's perfect, the decals accepted amazingly the shape of the buttons, knobs etc. Pix in a sec.
guys sorry about the displaying of the pix. I'm trying to post from my phone for the first time... not easy but my pc is kind of broken.... from over a month now, and they still don't know what is going on with it. but i couldn't wait to update the build. So, I'll try to explain the pix above. first the Flir is done. i made it moveable via two gears with an accessing port through the nose wheel bay. kind of neat. i also choose the scared plastic method to imitate the screen, which is fitted after making a small recessed edge along the perifery of the provisioning. it's glued and the ram stripes are glued along the edges but i couldnt take pictures yet. I'm continuing with the cockpit...
MIG-15 Bis BG Air Force Trumpeter 1/32
F`s are my favs replied to ShelbyGT500's topic in Works in Progress
I also have no words.... You are wicked evil! Amazing weathering over the foil... And those rivets....awesome! -
Awesooooome! My favorite part - the side IPs. Very very GJ!
+1 ! Can't wait to see it primed....
@Barry, thx a lot. They really have nice meshes and yet I think they are a little bit on the coarse side. @Thunnus, thanks man! It's my 5th or 6th model with moveable parts... Actually this allows to make two or three models out of one because it transforms from a parked to flying display position and beyond. And each looks like a different model.
