1,172 -
Days Won
13
Posts posted by F`s are my favs
Ouch guys, need some help Or maybe it`s correct, i`m not exactly sure, because the Eduard`s F-15C in 1/48 had exactly the same issue and i thought that i should correct it. And i did. Okey, okey, it comes to this slight angle outwards of the pods of the vertical stabilizers:
I remember that i straighten the pods of the F in 1/48 as i was thinking that they should be perfectly parallel to each other. But here again the same issue... so i`m now kinda puzzled if that might be the right thing in the real plane. The photo is taken directly above the pods and from quite a distance, and with quite a zoom. I`m sure that i glued properly the ALQ pod, the alignment is perfect, of course according to the vertical stabilizer. The other thin pod is oob, it`s perfectly aligned. My logic is that the pods should be really straight parallel to the airflow, but the same issue twice?! I think i could manage to make them parallel with some small mods of the bases of the stabilizers, but should i?? What is the right thing? Thanks very much!
Chuck, when i see your updates it`s like a holiday . Very nice upgrades on the canopy frame. How you plan to imitate the sealing contours under the frame, the white ones? In my opinion, a long and thinner stripe from that Tamiya tape should work very well...
Thx Chuck!
I`m finishing the stabilizers - both are with thinned leading/trailing edges, the lights with their main colors are added, most of the panel lines are partially filled with very thinned surfacer, and after some very light texturising, and... the Pod.
Silhouettes:
- Shaka HI, Zero77 and A-10LOADER
- 3
Wings - done. The "lights" are added and only with their main colors. After the painting i should add a darker filter over the lights.
I started the vertical stabilizers and can`t wait to add the pod, but there are still plenty of things to do before that. I sanded the bulged caps near the rudders, thinned the leading/trailing edge only for one stabilizer, removed the original kit pod, one light is added, and that`s pretty much it so far:
Magnificent painting, awesome colors!
Finally the wings are prepped for gluing.
Top,
& bottom:
The riveting is very very subtle. 2 types of rivets. A complete improvisation but i think it will look very pleasant after all.
- Zero77, ShelbyGT500 and stusbke
- 3
Oh, it`s part of the detail, the kit is very good.
I thought that the gaps of the hinges look great, but after painting they will look much wider/deeper/bigger than the gaps of the hinges for the flaps, especially when the ailerons are at certain angle. Then i went through a few photos of the real plane to see what`s best, and yes, there is definitely a gap but it`s more like a seamline, not like long narrow "canyon" as it was before. And more importantly - the gaps for the hinges of both aileron and flap look with the same width. My first try with these coverings was during the assembly of F-35B for the huuuuuge gaps of the stabilators, because i wanted to make them movable too. But it was a very very small hinge (more like a rounded hinge) and the "coverings" didn`t worked well, so i glued the stabilators. Here in this F the gaps are in a perfect straight line, so it`s much easier to glue the "coverings". While for the coverings i use the thin transparent film/the protector sheet, which usually is a part of some decal sheets. The Kittyhawk decals have such a protective sheet for their decals. It`s the most flexible, strongest and thinnest possible "thing" in my opinion. Here it is onto the decals. I also plan to change the "coverings" for the intake ramps with this pieces to make them even more invisible.
I painted the hinges to see how the ailerons will look with these "covers" and it`s pretty pretty i think. At least they look more similar to the hinges of the flaps - almost invisible when the ailerons at "0 degrees". When are slightly turned - there is still a gap but much smaller. I`m leaving them like that:
I wiped off the paint, and after texturising. It`s a little bit more subtle than the fuselage.
Probbably it`s visible (near the bottom of the last photo) - i also drilled a small hole for every wing, in the base which is hidden inside the fuselage, and where the wings are screwed to the fuselage. Interestingly enough, there are two structural struts for each wing and only one matching hole of a wing for just one screw. So i drilled another hole to use 2 screws for every wing to make them more stable.
- ShelbyGT500, Out2gtcha, Zero77 and 1 other
- 4
Btw, from the photo of Zero77, i noticed another difference that might be a possible issue - the lip/rim/semi-circle/edge of the Tamiya`s intake looks a little bit thicker, than the same in the Revel model. Or maybe the edge of the intake in the Revell model is thinned quite a bit... It`s just a small difference...
Niiiice, one more Eagle in the nest, goood, i`ll follow this with interest! The camo kinda reminds me of the Chuck`s F-15 and, honestly, i didn`t knew before for eagles with that type of camouflages. It sounds like an Arctic or a cold camo. Very interesting and looks not bad on the Eagle. I have one F-15C but in 1/48, with the typical grey camo.
Happy building and modeling, and more photos!!
PS: I checked out your theme with the Prowler... and it looks gut.
Veeery nice and beautiful Phantom!
Kev, i send you a msg with the review via email. It`s prepped, hope you like it, and wow - it`s lovely to have an article here on the site!
Thx Thx Thx Thx
My pleasure!
It`s cooking up, just the photos are done so far...
Milan
Take a look at thaaaat GTRP send me some awesome upgraded parts so the F should look even better. It comes to the thicker pod for the tip of one of the vertical stabilizers, and the shimmy dampener along with the wheel set. Well, the shimmy dampener at first look is beautiful beautiful, the pod/antenna looks good too, and i`ll use them in the F.
GTR wheel set. For you who didn`t used them already - i could say that the wheel/tires are wonderful, just beautiful, definitely recommended. They are not exactly better than the Tamiya oob parts, because they are just about the same from one point of view - detailing, assembly and quality of the parts. From another viewpoint - the GTR wheels/tires are different - regarding the brand name of the tires (GoodYear with all their specific differences), they are resin parts, and in a two-colored scheme for better/subtle painting... but that`s written in the instructions from the set. I prefer to use the oob kit parts, because the tires are from rubber, soft, thus with a great grip to the surfaces, i managed to make them to rotate very pleasantly, and to carve a deeper spot for a more realistic look.
Thanks very much Gary and GTRP!
I`ll make a more thorough review these days!
I like the detailing, especially the rounded rivets, and the textile-like covering onto the middle console.
- A-10LOADER and Starfighter
- 2
Awesome! Sunny sunny!
10x Martin and cheers from me too. Yes absolutely, this texturising is like a major change of the appearance of the model, like after a wash, weathering... But i would like to leave the credits for the end, because i`m doing it for the first time and i have no idea how it will look in the finished model. The logic is that it is going to be awesome (in combination with the riveting), ...will see.
Thx Marcel! Today i was dealing for a while with the ailerons of the wings. I`ll have to make them movable, with just two pins on both sides of the base of each aileron. So far just the holes are drilled and aligned. I`ll take photos when are prepped.
The JFS exhaust - prepped and test fitted:
- johncrow, Zero77 and A-10LOADER
- 3
It was a "huge" dilemma with the leading edges of the front CFT outboard pylons... After all, i knew that both leaned and straight edges were correct, so i straighten them. And they should look beautifully contrasting with the leading edges of the surrounding front pylons.
From both sides of the nozzles there are two small exhausts (i admit - i don`t know their purpose) and i replicated them from photo etch pieces:
And a comparison photo with the oob exhaust on the left side. So far only from the one side i edited the end of the CFT. There should be a small tiny little gap, and the best way to do it justly is with embedded photo etch pieces. I tried to cut the gap with a knife, but it was not beautiful The plastic is very thick and the gap should be very clean and crisp.
- A-10LOADER, johncrow, Rocat and 1 other
- 4
F-15E --- 1/32 --- Tamiya
in Works in Progress
