1,279 -
Days Won
10
Everything posted by sandbagger
1:32nd scale Mosca-Bystritsky MB bis fighter
sandbagger replied to sandbagger's topic in Works in Progress
Hi all, The weathering has been applied and sealed. 'Flory Models' Dark Dirt and Grime fine clay washes. Now onto the pre-rigging before construction, Mike -
Hi all, I thought of replacing the Russian markings using masks and airbrushing the three colours. However, aligning concentric circles accurately and without over spray was always going to be tricky. Therefore I decide to print the decals instead, using an Inkjet printer, not Laser. This is the process I used: Create the decal in Photoshop Pro software or similar. Test print on paper to check size. NOTE: As the centre of the Russian markings are white, I used Mr. Decal White decal paper, to avoid the surface below the applied decal showing through too much. Place the decal paper into the printer feeder tray with the glossy side facing up. Adjust the printer setting for the paper to ‘Premium Gloss Photo paper’ or equivalent and set the print resolution to high. Print the decal sheet. Leave the printed decal sheet for several hours to allow the ink to fully dry. NOTE: During the following step, do not apply too much sealer over the decals, as it can flood the surface and when dry cause a ’fish eye’ effect. Also spray at a shallow angle to the decal sheet, not at 90 degrees and at a distance of 12 inches or more away. Wear a respirator and spray in a well ventilated area. Apply a several light coats of sealer over the decals, using such as ’Krylon’ Acryli-Quik acrylic lacquer or similar. Allow each coat to thoroughly dry before applying another coat. Check decals are fully covered and sealed with the clear coat. NOTE: If using White decal paper, make sure you cut around the decals as close to the outline as possible, to avoid the white decal paper showing at the edges. Carefully cut as close as possible around the decal to remove it from the backing sheet. Make sure the model surface is smooth and has clear gloss acrylic coat, such as ’Alclad' Aqua Gloss 600 or similar. NOTE: Adding PVA adhesive (white glue) to the water, used to detach the decal from its backing paper, can improve adhesion of the decal to the model and help prevent ‘silvering’ (trapped air) under the decal. Also take care not to ‘stretch’ the decals when removing the water. Apply the decals to the model as for standard water slide decals. Mike -
Hi all, The linen decals have now been applied. White primed base coat, polished then pre-shaded with 'thinned 'Tamiya' Smoke (X19). The decals were cut from a sheet of the ‘Aviattic’ Clear Doped Linen (CDL) bleached (ATT32044). The Russian cockard decals supplied in the kit are ink jet printed and not 'cookie' cut. Typical of these type of decals, that are very easily surface damaged, before or after application. If possible, I'll probably airbrush the cockards using templates - we'll see. Mike -
Hi all, The pre-shading has been applied to the fuselage, wings and flight surfaces. I've attempted to represent the engine as best I could, given that the kit supplied moulding is the worst I've seen. The single piece engine is misaligned so there is a step at each side of the cylinders. Only 6 inlet manifolds were in the kit, there should be nine (replaced with spare 'Roden' manifolds). No valve gear or push rods or spark plugs either. The kit engine had to used as no other replacement engine would fit inside the engine cowl. In fact I had to remove the top of four cylinders to get the kit engine to fit (the can't be seen in the cowl). I've used the resin propeller in the kit but replaced the centre boss plate with a spare 'GasPatch' part. I've discarded the kit supplied wheels and replaced them with 'GasPatch' spoked wheels. Mike -
Hi all, The last strut work is now finished. This is the mounting frame for the machine gun. One version of this aircraft carried a Colt machine gun, fixed to the forward fuselage and fired through the propeller arc. The propeller was protected by Nieuport type deflector plates. The version for this model had a early Lewis type machine gun that was fixed at an upward firing position of an inverted V frame. This fired the weapon over the arc of the propeller. This mounting was made from 0.7 mm diameter tube with 0.3 mm diameter internal and wrap around rod. The replacement 'GasPatch' machine gun had it shoulder stock removed, as the weapon was most likely fired by operating a cable from inside the cockpit. Now at last I can think about actually building this model!! Mike -
Hi all, The basic tail unit is done. I disregard the entire kit supplied parts, apart from the elevator halves. Basically the resin was badly moulded and with no reinforcing rods. Also short shots and the rudders were the wrong shape. The tail skid and its support frame are made of 0.3, 0.4, 0.5, 0.8, 1.2 and 1.4 mm diameter Brass tube or rod. T two rudder were cut and profiled from 0.8 mm plastic card. The photo-etch control horns for the lower rudder and elevator are from the ‘Jadar’ WW1 1:48th scale control horns (S48087) set. Most of the assembly is a loose fit at it all can't be fitted as a complete assembly until later in the build. So, now it's onto some final details on the fuselage before construction starts, Mike -
Hi all, A few updates. I didn't bother using the kit supplied resin landing gear - enough said. Instead, I made a replacement using profiled Brass tube of 1.2 mm, 1.4 mm and 1.6 mm diameter and 0.5 mm diameter Brass rod. All of which was soft soldered. The axle retaining hoops were made from 0.4 mm diameter lead wire. I've added a scratch made tank filler cap, cockpit rear wing shield (0.5 mm thick plastic card) and engine cowl retaining straps (0.5 mm sanded flat plastic rod). The cockpit surround padding was added using ANYZ’ silver braided line (AN015). Lastly I've added the rudder and elevator exit ports in the underside of the fuselage. Suffice to say I'm not using the kit supplied rudder assembly and tail skid. So that's the next job, Mike -
Hi Paul and Matt, Soldering using traditional solder wire and either flux solution or flux grease is OK, but these days I use low melting point 'Solder Paste'. Tiny balls of solder mixed in with flux paste - it doesn't run as flux solution will and it's thick enough to stay where you put it. Apply heat and it's done. Easier to clean up afterwards as well due to no flux runs, Mike -
Hi all, I've added the rear support for the wings, made from 1.5, and 1.1 mm diameter tube with 0.8 mm internal rod. I've also added 0.5 mm diameter rods to the engine cowl, which helps to support the thinly moulded cowl to the fuselage. I need to add a wind blat screen below the rear wing support and a filler cap as well as rudder and elevator control line exit ports under the fuselage. Then it's onto the landing gear. Mike -
Hi all, The basic 'V' strut assembly for the top of the fuselage is done. The strut supported the flying and landing wires at the front and the pulley on the rear for the wing warping wires. The machine gun mounting was also attached to this assembly, but that will be added later in the build, as will the rigging fittings. The assembly was made with soft soldered Brass Tube of profiled 1.1 mm and 1.4 mm diameter with internal reinforcing Brass rods of 0.4 mm and 0.8 mm diameter. Now onto the wing supports and landing gear. Mike -
Hi all, Also the forward V strut on the underside of the fuselage. This was used for attaching the fixed flying and landing wires to the front spar of the wings. The protruding 0.5 mm rods have a collar of 0.7 mm diameter added to retain the wires, when fitted. Now onto the wing supports, the top V strut and machine gun support, Mike -
Hi all, The underside of the fuselage had a 'V' strut, on which the wing warp controls were located. Given the lack of detailed information for this aircraft, it's difficult to figure out exactly how these control were configured. I believe the controls were configured as follows: Two control cables from the rear bell cranks of the control column torsion bar, were routed vertically through the underside of the fuselage. These cable were attached to a control lever at the bottom, rear of the V strut. At the front of the V strut was a 'pulley' and control lever. Wing warp control cables from both the 'pulley' and lever were attached to the rear spar of both wings. Flying and landing wires were attached to another V strut towards the front of the fuselage underside. All wires were routed above the wings to an inverted V strut forward from the cockpit. The wing warp wires were routed over a pulley on the cockpit strut. As the control column was moved left or right, the lower rear levers rotated the front pulley and lever. This caused the trailing edge of the wings to twist either up or down, causing the aircraft to roll in the required direction. So, based on this I scratch made the underside V strut assembly. I used the two control levers from the kit. The struts were 1.4 mm tube with 0.5 mm rod reinforcing. Control mounting rod is 0.5 mm rod. The pulley is a spare photo-etch propeller boss plate, secured onto 0.5 mm thick plastic card. The lightening holes were drilled through using a 0.9 mm diameter drill. Now it's onto the underside forward V strut, Mike -
Hi all, I thought you might like to see my 1:32 scale build - the French Ponnier M.1, Serial No:18 ‘Le Vampire’ of the Aviation Militaire Belge as flown by Abel de Neef from the Ten Bogaerde (Koksijde) airfield in 1915. The forum build log is here: https://forum.largescaleplanes.com/index.php?/topic/89546-132nd-scale-ponnier-m1/&tab=comments#comment-1283971 The basic kit is resin and made by ‘Planet Models’ (Kit No: PL253). The list of changes/additions to the model are: Engine: Detailed with Nickel-Silver valve push rods and copper wire ignition leads. Modified or corrected: All wing and landing gear struts were replaced with made Brass tube struts with internal reenforcing Brass rod. The lower wings had 1.0 mm diameter Brass rods added to give adequate support at the fuselage. Rigging is 0.08 mm or 0.12 mm diameter mono-filament with ‘GasPatch’ 1:48th scale turnbuckles and 0.5 mm or 0.4 mm diameter blackened Brass tube. Animation of the ailerons, rudder and elevators achieved by cutting out with Brass rod supports. Aftermarket additions: ‘Xtradecal’ parallel black stripes (XPS1), ‘Aviattic’ CDL aged varnish (ATT32094), ‘Lukgraph’ Dark Plywood (DEC004) - from their Friedrichshafen FF.33L kit (32-30). ‘Wings Cockpit Figures’ Pilot adjusting goggles - (LSK02). ‘GasPatch’ 1:32nd scale Lewis MK.1 Stripped Half Heatsinks. ‘Model Scene’ Wetland Middle (F011). As usual I've created a downloadable build log in Adobe PDF format, for those who might want to refer to it for reference or build details. It contains full step by step descriptions of the model build, its modifications/changes and is also supported with illustrations and photographs. If viewed in Adobe Reader, each build log has book marked chapters/headings for easier navigation through the log. My model website has the gallery page, so to view any model, go to the gallery (in my link below) and select it. If it has a PDF build log, it will be available to download using the 'PDF' icon on that models photo's page. For any photograph, just click the photo to enlarge or reduce the viewing size. Mike
Hi all, I've fitted the top, rear of the fuselage and then filled the 5 mm gap at the rear of the fuselage. I also sanded off the linen tapes on that and replaced them with sanded down 0.2 mm thick plastic card. The kit supplies one photo-etch access panel for fitting to the forward, left side of the fuselage. This panel was used to gain access to the fuselage internal components. The few available photographs of this aircraft and subsequent colour profiles seem to show that some aircraft had this access panel fitted and some did not. Those that did had the panels fitted into wood or metal fuselage panels (certainly not into just the fuselage linen covering). Also, some profiles show the wood access panel to be fitted into either a plywood or metal covered forward fuselage. However, all reference material shows only the left side of the aircraft, not the right side. [b]My assumption[/b] I believe it’s probable that early versions of the aircraft had no forward fuselage side or access panel, but instead had just the fuselage linen covering. On later versions it seems likely that the wood access panel was fitted and into fuselage forward side panels of metal, as used over the forward top of the fuselage and engine cowl. It also seems probable that these panels were fitted to both sides of the aircraft, so full access to fuselage internal components was possible. I couldn't find any evidence to prove otherwise. I scratched the fuselage side panels and access panel with hinges and lock plates from 0.2 mm thick plastic card. Mike -
Hi Matt, No problem - 0.8 mm thick plastic card, CA adhesive, filler and Mr. Surfacer 500, Mike -
Hi all, The cockpit is complete now. I found the photo-etch cockpit parts supplied in the kit were too flat and two dimensional. Therefore, apart from the compass, single instrument and seat straps, the rest were either scratch built or I used appropriate parts from my 'spares' box. As there is no information on the cockpit detail for this aircraft, I suspect 'Omega Models' used some 'poetic license' creating there parts. The cockpit frame work is 1.0 mm and 0.85 mm plastic rod. The pilots seat is a resin 'Barracuda Studio' part, intended for the Sopwith Camel. Frame cross bracing wires are 0.1 mm diameter blackened Nickel-Silver rod with 0.4 mm blackened Brass end fittings. The hand priming pump is 0.6 mm tube, lead wire and plastic rod. The throttle, although not I think strictly accurate, is from a Wingnut Wings Camel kit. Rudder and elevator control lines are 0.08 mm diameter mono-filament with 0.4 mm blackened tube end fittings. The linen paint is the MRP CDL lacquer and wood work is 'DecoArt' craft Burnt Umber acrylic. Weathering is Flory Models' Dark Dirt wash. I've now fitted the fuselage top rear decking and found it's 5 mm too short at the fuselage rear. So filler needed, Mike -
Hi all, The fuselage of this model is constructed from six resin parts, which are the right side, left side, top forward panel, top rear of the fuselage, engine bulkhead and the underside. The underside of the fuselage is a single piece, but the molding of this part is bad. Not only is the part twisted and with air ‘blow’ holes, but the thickness of the molding is uneven, being thick on the right side and wafer thin on the left side. This makes the underside of the fuselage virtually unusable. Therefore I decide to discard this part and make the underside from 0.8 mm thick plastic card, with 0.2 mm thick plastic card strips to represented the linen tapes. I've also decided not to make the kit supplied photo-etch cockpit, which I think is too flat and two-dimensional. So that's the next step, Mike -
Hi all, Now that the Hansa-Brandenburg W.20 is finished it's time to start the resin Mosca from 'Omega'. I sometimes wonder if the company is called 'Omega' because of the reaction modelers get when they open the box - 'OhMyG--' As you can see, most of the resin, especially fuselage and wings is so thin in places it's virtually see-through. The instructions are, to say the least, minimal. Hey-Ho - I've built 'Omega' kits previously, so at least I know what I'm in for, Mike -
Hi all, The model is now finished. I'm just waiting for the display case to arrive. The last shot for posting is the pilot figure. The next shots will be the completed model, which hopefully will maybe at the weekend. As usual, thanks to everyone for their encouragement and comments throughout this build, Mike
Hi all, Nearly there now. Just the engine/prop assembly with propeller bullet deflector plates to do. Plus of course the pilot figure, Mike
Hi all, The rigging has now been finished, apart from painting the turnbuckles. Still to do are the wheels, tail skid, windscreen, ailerons, engine assembly and the figure, Mike
Hi all, All of the necessary pre-rigging has been done, using 0.12 and 0.08 mm diameter mono-filament with blackened 0.5 mm diameter Brass tube. The wings were then fitted. The ailerons win the upper wing were controlled from the cockpit by external rods and levers, similar to the French Nieuports. The kit parts had rods that were way too short and would not reach the fuselage openings. I cut the rods away from the levers and fitted 0.6 mm diameter Nickel-Silver tubes with 0.4 mm tube inside. The protruding 0.4 tube fitted into holes drilled through the front end of the levers. Now it's onto final rigging, Mike
1:32nd scale Hansa-Brandenburg W.20
sandbagger replied to sandbagger's topic in Ready for Inspection
Thanks everyone - much appreciated; Ray: Certainly Ray and thanks, Mike -
Hi all, I've posted the final model shots in the 'Ready for Inspection' page. Thanks for everyone's encouragement and comments throughout this build, Mike
Hi all, I thought you might like to see my 1:32 scale build of the German ‘Hansa-Brandenburg W.20’. This model is from ‘Omega Models’ and is resin. This aircraft was a single seat float, designed to be carried in a water tight container on a type of submarine. The intention was to surface and remove the aircraft from its container, assemble it then launch it for reconnaissance missions. After landing near the submarine, it was be taken onboard, disassembled and stowed back in its container. The special submarines were never built before hostilities ceased and the three prototypes were eventually put into storage. The basic list of changes/additions to the model are: Engine: The resin engine replaced with the equivalent engine from ‘Wingnut Wings and detailed with Nickel-Silver valve push rods and copper wire ignition leads. Propeller: The resin propeller was replaced with a special made wood laminate from ‘ProperPlane’. Modified or corrected: All wing, float and tailplane resin struts were replaced with hand made Brass Tube struts with internal Brass rod. The entire engine support frame was hand made using Brass tube and rod. Rigging is 0.08 mm or 0.12 mm diameter mono-filament with ‘GasPatch’ 1:48th scale turnbuckles and 0.5 mm or 0.4 mm diameter blackened Brass tube. Animation of the ailerons, rudder and elevators achieved by cutting out with Brass rod supports. The beaching trolley and trestle were scratch built, apart from the wheels which were from a 'Kellerkind' model. Aftermarket additions: ‘Aviattic’ Clear linen effect (ATT32236). ‘Aviattic’ German Naval Hex (faded) (ATT32113). ‘GasPatch’ Elite Accessories 1:48th scale metal Turnbuckles. ‘Wings Cockpit Figures’ 1:32 scale Seated pilot (LSK 07A). ‘Elan Miniatures’ 1:32 scale German Naval pilot (EL19). ‘Elan Miniatures’ 1:32 scale RFC Mechanic (modified) (EL41). Coastal Kits’ 1:32 scale Abandoned Airfield Display Base (modified for 3D effect). As usual I've created a downloadable build log in Adobe PDF format, for those who might want to refer to it for reference or build details. It contains full step by step descriptions of the model build, its modifications/changes and is also supported with illustrations and photographs. If viewed in Adobe Reader, each build log has book marked chapters/headings for easier navigation through the log. My model website has the gallery page, so to view any model, go to the gallery and select it. If it has a PDF build log, it will be available to download using the 'PDF' icon on that models photo's page. For any photograph, just click the photo to enlarge or reduce the viewing size. http://igavh2.xara.hosting]Mikes WW1 Aircraft Models Mike
