campingbaer66
LSP_Members
  • Content Count
    97
  • Joined
  • Last visited
  • Days Won
    4
Posts posted by campingbaer66
  1. Hello everybody ,
    after around two months of fun and little pain I have yesterday finished my next Wingnut Wings model , the Salmson 2 in USAF markings.
    It was one of the most challenging kits from WnW until now , and the hardest task was the rigging , that gave me more problems then usual du to the complexity of the amount of double flying wires.
    As usual I used not much aftermarket stuff in the build , the only things are HGW belts and the very good Bob's Buckles eyelets.
    Without too much words , here comes the pictures , hope you like them.
    First a few in progress pictures :
  2. 11 hours ago, JT68 said:
    Superb work Peter!
    That is an excellent build.Are the wheels from an aftermarket company, if not, how did you do the spokes?....they look awesome.
    Cheer's
    Jeff.
    Hi Jeff ,
    the spoke wheels are made from PE-parts included in the kit in combination with plastik parts.
    They are not easy to make but the result is worth the time spent on it.
    Following a comparison betwenn the spoke wheels made with PE-parts and the plastik "alternative" , just made with two plastik parts.
    And completed :
    Peter
  3. Hello ,
    It's a longer time now since I have postet my last build here. But finally I have made some pictures of my latest Wingnut build and would like to share it with you for discussion.
    Maybe it is not one of my best ones but it was a lot of fun to build.
    It was the first time for me to work with "wood decails" and I must say the quality of those included in the kit was really great.
    Hope you like the result , if not please let me know your recommendation for making it better next time :).
    Peter
  4. What a unique-looking aircraft.  Beautifully rendered.  Leonardo Da Vinci would be proud!  How did you finish the engine cowling?  Painted or decaled?
    Love the contrast shown here.  Amazing rigging throughout.  You say it was no big deal, but it looks daunting to me.
    Great piece of modeling.
    Sincerely,
    Mark
    Hi Mark ,
    The cowling metal effect is painted.
    First airbrushed with Tamiya X-11 Chrome silver than brush painted with Gunze Mr.Metal Color H211 Chrome silver.
    Peter
  5. Hello ,
    after more or less one and a half months fun I can now show you the pictures of my next finished Wingnut model.
    The Jeannin Stahltaube ( steel dove ) was one of the first double seater reconnaissance planes that were used on German side.
    It was an unarmed plane and the only weapon on board was an automatic Luger pistol carried by the observer.
    The kit is relatively simple to build , the rigging looks complicated but it is not a big thing to do.
    I would definitely recommend it also to the WW1 model beginner.
    Following the picture , I hope you like them.
  6. Hello ,
    This is part two of my Battle of Britain duellist combo which I started with the Messerschmidt Me 109 E-4 of Helmut Wick a month ago :
    http://forum.largescaleplanes.com/index.php?showtopic=71809
    The Spitfire Mk.I was build based on the new kit from Revell which is designed as a Mk.IIa.
    Additional part used were :
    - Eduard Resin Cockpit
    - Eduard Resin Wheels
    - Quickboost Resin Exhaust
    - Yahu Instrument board
    - HGW belts
    - Eagle Parts resin oil cooler
    - Eduard PE-Exterior
    - Eduard Cockpit Masks
    - XtraDecal sheet for the markings of Dundas plane
    It was an easy and fun build. I really enjoyed the work with the Eduard resin cockpit.
    The Yahu Instrument board was a big advantage over the kit board and decals.
    Hope you like it.
    Cockpit pictures :
    Peter
  7. That's just Lovely work Peter. I have the same kit in my stash . Was wondering if you'd had any fit problems around the engine cowlings? Previous comments I've seen on the forums here is that the engine cowlings fit poorly when building it closed up like you have.
    This is correct , the fit of the engine cowling is not good because it is too narrow. I have solved this problem with the integration of a "spacer" made out of a spare sprue piece and some plastic card tabs to expand the cowling.
    Peter
  8. Beautiful work!  Only critique I have is you have your aileron mass balance and pitot tube locations mixed up.  Move the mass balances to the ailerons and the pitot tube to the wing and you're good to go.
    Hello Mikester ,
    That's the great thing in a forum like this.
    Many thanks for giving me a hint with this mistake of mine.
    It will be easy to correct it and I hope that will be the only fault on my Emil.
    Peter
  9. Extremely impressive Peter, how did you achieve the mottling?
    Hi Kagemusha ,
    The mottling was done with the sponge methode. I took a small part of the foam/sponge that comes with the Aires Cockpit set to do it.
    Just dipped it in RLM71 , pressed the sponge into a piece of kitchen roll until most of the paint is removed ( like drybushing ) and dab the sponge on the model.
    Believe me that I have tried that several time on some spare plastic parts before I was brave enough to do it on my model :).
    Peter
  10. Hello ,
    after 1,5 month of fun with this kit I would like to show my finished Bf-109 E-4 flown by German ace Major Helmut Wick in 1940.
    The kit is not perfekt and some small fit problems had to be solved , for example the oil cooler and the fit of the engine cowling.
    But nothing too serious and in my opinion still the best kit to build an acurate Emil.
    Hope you like it.
    Peter
  11. Hello ,
    It have been some time that I have shown something new here.
    This is my Wingnut R.E.8 Harry Tate , working time on it was more or less four month because of my typically sommer idleness for modelling.
    Was a lot of fun to build. Everything went together easily like always with Wingnut kits.
    Not much words now , I hope you enjoy the pictures.
  12. Hello ,
    It took me a month and a few days to finish this little bird from Wingnut Wings.
    Overall a relatively simple build compared with the two seaters I have worked on before this.
    Most challenging part was the alignment of the tree wings , especially because the connecting spots of the struts are very small.
    Riging was easy and it is a pity that this kit is sold out since 2012. I would like to do another one.
    Following the pictures , hope you like it.
    A WIP is available here :
    http://forum.largescaleplanes.com/index.php?showtopic=67602&hl=triplane
