417 -
Days Won
2
Everything posted by aircare84
Amazing build! Thanks for posting. Have a Tornado in the stash I keep looking at. You have done a great job with the kit.
Great build & finish! Thanks for posting.
Nice clean build. Thanks for posting.
1/32 Hasegawa Fw190 A8 'Red 11' Jgr.10 Schlangenschwarm
aircare84 replied to AlanG's topic in Ready for Inspection
Try posting the photos again, cannot see. -
Aviattic Lozenge decals (cookie cutter) Questions
aircare84 replied to Gazzas's topic in LSP Discussion
Gaz, The Aviattic decals do wrap around the edges, but barely. Not much overlap between the top & bottom. You have to be careful with your placement to get the overlap. I use Micro set & a hair dryer. You can also use water, you don't want to lay the decals on a dry surface so you can position if needed. Be careful touching before they have set, as the decals will stretch. Larry -
I was actually able to get mine from Squadron; https://www.squadron.com/1-32-Avionix-A-6A-Cockpit-p/blc32061.htm Took a bit to get it, but did actually arrive.
Su-27 Flanker B "Digi camo" Trumpeter 1:32
aircare84 replied to Koralik's topic in Ready for Inspection
Impressive finish! Well done. -
WNW Albatros DVa OAW, Hans Von Gössel's flying skull!
aircare84 replied to karimb's topic in Works in Progress
Karim, Glad to hear the shoulder is improving. Nice to see you back at the Albatros as well, great modelling as usual. I never did get to email Alex about the Barnyard decals, have to do that here soon. I did buy some of the new Proper Plane wood decals. They are nice, a little to dark for my taste for an Albatros DV fuselage, but would be fine for other builds; ie Felixstowe, Alb BII, etc. Keep up the great work & good luck with the rehab. Larry -
Excellent finish on that! Great build as well. Thanks for posting.
Robert, Very nice build. Great finish as well. One of the best kits I have built. Thanks for posting.
Alex, Yes, I received mine about a week ago. I was the one who sent you a photo of the crushed box the decals shipped in. The decals survived fine, so no harm. Larry
- 7 replies
- proper plane
- decal
(and 1 more)
Tagged with:
Great build ! Really like to engine. Looks like you riveted the forward fuselage ? Thanks for posting.
Mark, Not difficult to use. Just a little care is all. Not much different than applying regular decals. The prep work adds to the finished product. Check out my Albatros builds.
Mark, The Uschi decals are great. Before applying, you need a gloss painted surface, not bare plastic. They are also translucent, so what paint you put down will affect the final appearance. I usually use a off white or very light tan as a base coat. You can also vary the base coats for a variation of the final panels. I usually cut the panels slightly oversize, then trim when installed & dry. I use Microset when applying. After the position is good, use a hair dryer to set them & also conform to any details under. Be careful when applying, as the decals can stretch. Larry
1/32 Tamiya F4U-1a Corsair - Boyington's 17740
aircare84 replied to Thunnus's topic in Works in Progress
John, I added the hydraulic plumbing after I assembled the wheel wells on mine. Drilled out the fittings on the manifold & actuators before assembling, then fitted the piping. Then paint & weathering. Larry -
Vincent, What color did you use to paint the seat body? Custom mix, or a available bottle paint? Larry
Wingnut Wings Salmson 2 USAF finished
aircare84 replied to campingbaer66's topic in Ready for Inspection
Great build ! The rigging turned out well. Can see how it took some time, quite a few wires to daa. Thanks for posting. -
Great build. Thanks for sharing.
P-51D-5-NA Maj. John D. Landers 1/32 Revell
aircare84 replied to Miloslav1956's topic in Ready for Inspection
Miloslav, Another masterpiece ! The paint , finish & weathering are exceptional. Thanks for posting. -
Thanks!. Yes, I sawed the upper half off of the Barracuda nose. Practiced on the kit pieces first.
Thanks John! It took my Dremel with a drum sander & a fine round burr. Quite a bit of sand, grind, fit & repeat. It is doable, just be prepared for quite a bit of work. front of the engine & forward part of the Barracuda nose required most of the attention. Also, the barracuda nose is slightly narrower @ the spinner, so I had to trim the upper forward part of the engine to look right, where the frame piece is. Also, the Barracuda nose has a flange molded onto it that tucks inside the kit airframe, was still able to use the lower half of this flange. Wasn't much different than the rest of the kit, had quite a bit of fit issues with this one. Larry
Thanks for all the great comments everyone!
Tim, All of the larger piping was included with the engine as separate pieces. I broke 1 & had to fashion a replacement. All of the small silver lines & linkages I added.
Great build ! The rigging turned out well, right choice using fishing line. Good luck at the show. Thanks for posting.
Kittyhawk F-86D Sabre Dog - new pictures added
aircare84 replied to reconspit's topic in Ready for Inspection
Great build. The wash has added to the overall effect IMO. Thanks for posting.
