Sir Spendalot
LSP_Members
  • Content Count
    47
  • Joined
  • Last visited
Everything posted by Sir Spendalot
  1. Just tried to order a few sets for delivery to the UK but it came up with an error message when I tried to pay (all details looked correct) Are you aware of any problems?
  2. That's freaky - they look like sketches!
  3. I built one of these in the mid 70s - so over 40 years old
  4. Beautiful job Guy! Not wanting to hijack your post but seeing the engine and cockpit photos reminded me that I have pictures taken from an article written by the pattern maker (Pat Tranfield) for this kit. These first two show the patterns built at 1/12 scale: And this last one is Pat's own final kit build. His son still has this actual built kit. If you're interested, the full article is here: https://www.largescaleplanes.com/articles/article.php?aid=3276 Cheers Paul
  5. Thanks Brian - and the good thing is you can remove the dangly bits if you decide you don't like them as they"re held in with rubber gromets (can't remember the technical term!) Thanks Ray - was really please the way she turned out Thanks Alan. Now you come to mention it, I vaguely remembering reading about the fasteners somewhere - and looking at it again, it makes perfect sense. Next time ...
  6. Thanks John - I did have a lot of encouragement The seat belts are Eduard's own that came with the kit - along with a fair amount of other PE bits.
  7. Hi All This is the Eduard Hasegawa 1:32 P47D Thunderbolt “Dottie Mae” A really nice, easy kit to build. The only real issues were with the instructions which left out a couple of steps and were not particularly clear at some stages. This was my first try with the Alclad shiny stuff – which was a steep learning curve, helped greatly by LSP members. Here’s a link to the full build story: And here’s some pics: Cheers Paul
  8. Also pulling up a chair. This was the first 1/24 kit I built (at the tender age of 14!). The original pattern maker for this (and the 109) was the father of a friend of mine. When you consider what he had to work with back then (no CAD/computers), it makes the kit even more impressive.
  9. After recoating the anti-glare panel with a matt finish, I think we’ll call this done. Here are a few snaps to be going on with. I’ll take some better pics and transfer this to RFI. Just want to say a final big THANK YOU to everyone who encouraged me through the build and came forward with the many useful suggestions (like putting the stick the right way around!!). Cheers Paul
  10. Thanks Woody - please be as bold as you like Yep - it's been a steep learning curve with regard to the metal finishes. As it happens, the finish turned out pretty much as I was aiming for - not too shiny and with the panel variations. It is a tad grainier than I'd hoped - I'll definitely use the gloss next time. With regard to the AK Xtremes - I did use these on the undercarriage doors and, to be honest, there doesn't appear to be much difference between these and the Alclads (albeit I only used the AKs on small areas so not really a fair comparison). Anyway, quick update - bar a few small tweaks, she's finished: More pics to follow. Paul
  11. Thanks Bill. I did notice a couple of photos (and the box art) where the staining had gone over the gear doors - so my plan now is to add staining but to work the basis that it's hiding any missing ZC paint
  12. Fantastic build sir. I did a USN Navy version a while back and those horrible intakes stare at me every time I sit down at my desk Think I might add some FOD guards at some stage. Also wish I knew about the black basing thing before I built my Revell 1/32 Tornado - big expanses of nothing!
  13. Thanks Gents - couldn't agree more about the decals. And now it’s on to the mucky stuff! I finished off the decals, most of which settled down nicely – just a few that needed a slice with a sharp blade and a small bucket of Micro Sol. I then sprayed on another layer of the Vallejo metal varnish and started a bit of weathering with Flory’s dark wash. A couple of pics showing the after on a couple of smaller pieces And a comparison between a wing that hasn’t been floried… …with a wing that has (hope you can see the difference - it's pretty subtle but it does bring out the panel lines) And a final pic of Dottie from the side Just have to finish of the weathering and it’s on to the final assembly! Paul
  14. Thank you. Beginning to fret less and really enjoy the build First decaling session tonight (the big ones). The decals seem quite thick but appear to be settling down well with an application of Micro Sol (they're Cartograf - so wouldn't expect anything else) Just the stencils to do now. Paul
  15. I am but a novice taking his first steps toward Alclad enlightenment
  16. Final Paint stages and mask removal. I added a few more panel variations Then I had a sleepless night trying to figure out the varnish/not to varnish conundrum. I read a number of articles which were either pro or anti the whole varnishing idea. Some said it flattens the metallic effect, others said they didn’t have a problem with it. Then there was the whole “can you use micro sol solution directly on Alclads” question – a number of modellers saying don’t because it turns the Alclads black. So, I decided to use a varnish and to give Vallejo Metal Varnish a go (diluted by about 50%). I applied this before removing the masking tape and to give an idea of the reflection I think the finish is now ok and the varnish has given a nice smooth finish without losing too much of the metallic effect. Using Alclads for the first time has been a really steep learning curve – and I think I’ve only just scratched the surface (so to speak!). It seams the finishes you can achieve are unlimited – you just need to know what you’re after and how the different paints work with the various base coat options and varnishes. I’ve got some work to do on the yellow (a bit rough in places) and then it’s on to the decals. Paul
  17. Thanks Brian. The white is definitely smoother. I'm now much closer the finish I was after - not too shiny but obviously metallic.
  18. The 2nd bottle of polished aluminium arrived … but I thought I’d try out the standard aluminium first. This appeared to be pretty much the same as the polished version but a little smoother (probably just my imagination). Anyway, this is how it came out And here’s a few panels done in white aluminium and duraluminium (not quite so subtle in real life – must figure out how to capture these metallic finishes better on camera) I’ll add a few more panel variations and then (hopefully) move off this alclad topic! Paul
  19. Further lessons in the art of Alclad! So, after my rather flat first lesson with the shiny paint, I went ahead and rubbed down one of the flaps with a micromesh 6000 pad. This pic shows the original painted version (top) and the rubbed down version. I then went at it again, but at 25psi. Much happier with the result. Not sure you can really see the difference in the pic, but it’s less grainy and catches the light better – but not too shiny. And here’s a few of the bigger bit all rubbed down and ready for the second attempt (when I get another bottle of polished aluminium!) Lessons what I have learned: A lot of Alclad goes a little way It’s tougher than I thought Rub down the Alclad for an interesting weathered look Spray at 25psi minimum Test, test, test!! Thanks for looking Paul
  20. It was the matt base (base coat and microfiller). I was trying to avoid going too shiny - but managed to make it almost completely dull/flat. But I wonder if the dullness has as much to do with the roughness as it does with the matt/gloss undercoat (light refraction and all that). The instructions say that you should spray at 15psi - but I've seen suggestions that this is too low. I'm wondering if my base coat was a bit rough because of this.
  21. Thanks gents. I'm probably over thinking this. I wasn't after a really shiny finish - it was more the smoothness that concerned me (or lack of it). I'm going to try rubbing down the flaps (that I painted at the same time) and respray them at a higher pressure. If that works, I'll rework the rest.
  22. More news and a plea for feedback: Before applying the shiny coat, I painted the trim/stripes/anti-glare bits and then masked the colourful areas and re-coated the black base Then came the Alclad I’m not sure what I expected but it seems a little rough/non-shiny. I rubbed the black down first and applied the polished aluminium in thin layers at 15psi. Was I expecting too much? Feedback, as always, gratefully received. Paul
