JonOlsen88
LSP_Members-
10 -
Everything posted by JonOlsen88
New EagleCals ~ Me 262 B-1a/U1 Nightfighters of NJG 11
JonOlsen88 replied to Judyc's topic in Eagle Editions
Thank you very much for your reply. -
Hi! I'm interested in this decal set. Your decals are the best quality decals I've ever used. Anyhow, I was just wondering if the set includes decals for the original German markings of Me 262b-1a W.Nr.110306? For example, is there a decal for the red 6? Thanks! Regards, Jon -
Hey Marus, I'm working on an Academy 1/72 Me 163S. It's the two-seater trainer version.That'll be my next one! Are you working on anything at the moment?
- 4 replies
- Me 262
- Messerschmitt
(and 1 more)
Tagged with:
Thank very much guys for your kind words. Yeah, it's a tail-sitter. My next one won't be!
- 4 replies
- Me 262
- Messerschmitt
(and 1 more)
Tagged with:
Here's my Me 262 A-1a Kit: Revell Scale: 1/72 Replacement parts: the starboard engine is a resin part by CMK. While this part is very nicely detailed, it leaves a sizeable gap at the joint between the engine and wing. To fill in the gap, I used generous amounts of Tamiya putty. After lots of wet sanding, the gap was gradually filled in and smoothed. It took a lot of elbow grease, though! The canopy is by Rob Taurus. It's very clear and looks great. In contrast, the canopy supplied by the kit is thick, a poor fit, and has no framing. Scratch-built details: epoxy (wheel bay and interior side-wall components), and thin, transparent hobby wires for the electrical wiring. I also used a spare rod from an academy Me 262 kit. I trimmed this piece with a hobby knife, and glued it next to the canopy tub. In the Revell kit, the details in the wheel bay and underneath the cockpit tub are great. Unfortunately and inexplicably, however, Revell decided to cover up the wheel wheels!!! Using a sharp hobby knife, I removed the plastic covering up the wheel wells. Next, I did a bit of sanding to smooth out the wheel wells' edges. Main Paints: Tamiya As-16 Light Grey, As-29 Grey-Green, AS-12 Bare Metal silver, Xf-22 RLM Grey; Model Master (Enamels) RLM 70 & 71 I hand-painted the squiggles on the wings' uppersurface using a very fine, sharp-pointed Tamiya brush (Item 87074). I used enamel Model Master RLM 70 for these dark green squiggles. The original photos of the subject aircraft reveal that these squiggles on the wings were crisp and rather well-delineated. On the other hand, the same photos show that the squiggles on the fuselage were somewhat wider and definitely less well delineated. The squiggles on the fuselage also show two distinct tones, whereas the monotone appearance of the squiggles on the wings suggests the use of one very dark color. The base color for the wings is Tamiya AS-29 Grey-Green. The fuselage base color is AS-16 light grey. The squiggles on the fuselage consist of the Model Master paints for RLM 70 &71. For the fuselage squiggles, I traced the outlines on thin notecards. I then cut around the outlines with a hobby knife. In this way, I used pieces of notecard as templates. I taped the templates onto the fuselage with bits of Tamiya masking tape before spraying the relevant areas with the airbrush. This process was very time-consuming! Speaking of airbrushes, this was my first experience using one. Some of the squiggles on the fuselage were painted with a very basic Tamiya badger 350 airbrush, while others were painted with Tamiya's Spray Work airbrush. It wasn't until after I had already started the painting process that I upgraded and bought the Tamiya “Spray Work set. Needless to say, I found the Spray Work airbrush to be superior and it gave me much more control when painting. Decals: A mix of Cutting Edge decals and EagleCals decals. In my experience, EagleCals decals are the best. They are very thin and slide on beautifully. Check out the decal representing the rectangular shaped stencil underneath the windscreen on the port side. I got it from a decal sheet belonging to a Limited Edition hasegawa kit. Any comments and feedback is much appreciated! Regards, Jon
- 4 replies
- Me 262
- Messerschmitt
(and 1 more)
Tagged with:
Thanks guys for the interest and comments. Also, Kevin thanks for editing the pics! And Clumsy Dude, I'm glad you told me about the BB code. For the mottling, I used templates made by Airwaves. It would have been a lot harder for me to have done the mottling without the templates! Just for kicks, I've posted here an original photo of "Black 4." I am absolutely in love with the Me 262. >Jon
Hello everyone, This is my Me 262 by Academy. The markings and paint scheme represent "Black 4." This Me 262 served with JG7 and was found abandoned at an airfield in Prague. The decals are mostly from Cutting Edge. I used Tamiya paints, including AS 23(light green), AS 24 (dark green),and AS 5 (light blue). Based on my interpretation of the black and white photos and commentary I've read about "Black 4," I went for an overall RLM 83 upper-surface. For the replacement nose section,I tried to make it look like a very light shade of RLM 76. I sprayed multiple coats of Tamiya AS5 and TS 27 (Matt White) in an attempt to achieve this effect. Enjoy! Please let me know what you think. >Jon
How to blend in replacement engine with wing?
JonOlsen88 replied to JonOlsen88's topic in Construction & Scratch-building
Everyone, thank you so much for the great advice! I really appreciate everyone's support. I'm not comfortable with removing the puttied area and replacing it with superglue...I don't have the confidence! I'm very tempted to try using nail-polish remover, as suggested by Old Dog and D Bellis. I've also got a can of Tamiya fine surface primer...is that similar to the Mr Surfacer 1500 that Out2gtcha mentioned? Would spraying some of that stuff onto the puttied area help smooth out the puttied surface at least somewhat? I've tried wet sanding the surface more and the puttied gap looks better now than it did before, but still a bit rough. Again, I'm very grateful for all the support! >Jon -
Hello, everyone. I'm working on a Revell 1/72 Me 262. I've attached and glued on a resin, replacement engine to the wing. However, after attaching the engine, I noticed there was a long gap that runs between the side of the engine and the kit part. I filled this gap with grey tamiya putty ("basic type") and have sanded it quite a bit, but the surface of the puttied area still looks rough. Any thoughts about how I can improve the appearance of the puttied area? How can I get it to blend in better with the wing? Help! Any advice would be tremendously appreciated! >Jon
On Pinterest, I came across this photo of a very unusual Me 262 with a collapsed nose wheel. I've never seen a photo of an me 262 with a paint scheme like this one. Does any one have thoughts, knowledge, or interpretations regarding what the paint scheme might be? Check out the link to see the photo... https://www.flickr.com/photos/sdasmarchives/7585872406/in/photostream/ The nose is especially striking. My guess is that the entire nose section has been primed with a light grey primer or else in a "whitish" shade of RLM 76 "light-blue." Either of these colors was almost certainly painted on "Black 4," a well-documented and famous Me 262 that was found abandoned by the Allies at an airfield in Prague. One big difference between the nose of "Black 4" and the nose of this "unknown aircraft" is that the light-colored paint extends from the nose tip as far as the windscreen of the canopy! It also appears to me that the starboard engine has some (bare metal?) replacement parts, including an upper panel and the nose intake ring. Another noteworthy feature is that the vertical rudder (not sure what the correct term is) seems to be a slightly different shade of green from the green on the rest of the fuselage, suggesting that the rudder was a replacement part. As far as the overall paint scheme is concerned, it looks to me like it might be mostly RLM 82 light green with a dense mottle of RLM 81 brown-violet or 83 dark green. What do you think? I'd love to know anyone's interpretation of this particular aircraft's markings. It looks like the letters "VI" are visible towards the rear of the fuselage, immediately before the balkenkreuz. Do you agree? All that I've written above is just my interpretation
