291 -
Days Won
2
Everything posted by Isar 30/07
Early MiG-27 in Guards units?
Isar 30/07 replied to thierry laurent's topic in Aviation Discussion & Research
Thierry, maybe I can help with that question. I have a book in german called "Rote Plätze" - in translation something like "air bases used by russian air force". This book discovers all the airfields/bases in the former GDR used by russian air force. A very intersting book indeed! Checking this book there are a four pics of Mig-27 wearing the Guards badge at the intakes. Later this evening I´ll send you these pics - maybe this answers your question. Cheers - Reimund -
Pauke! Pauke! – NIGHTFIGHTER! Me 262 B-1a/U1 Red 12
Isar 30/07 replied to 109's topic in Works in Progress
WOW - this is very interesting! Can´t wait to see how it looks with RLM 76 on! Cheers - Reimund -
Grumman A-6E Tram Intruder VA-75 AC504
Isar 30/07 replied to reconspit's topic in Ready for Inspection
Chris, as written before - a very impressive build - I like the camo and weathering! Cheers - Reimund -
Wow wow wow! Congratulations! THIS is amazing! Your Corsair reminds me to start mine…. Reimund
Christian, your Mirage is an amazing masterpiece! Congratulations! Servus Reimund
Bf 110E-3/trop 2.(H)/14 North Africa - almost done
Isar 30/07 replied to Fanes's topic in Works in Progress
Servus Joachim, looking at the "damage", I thought this wouldn´t look that bad - it´s a desert veteran that fought most against the elements. Correcting the mishap, now it´s a really war weary 110. Glad, you could fix it and it looks now more convincing to my eye! Can´t wait to see more Progress! Cheers - Reimund -
ICM Gloster Gladiator —— new pictures !
Servus Chris, simply stunning! The model and the rigging look perfect! Congratulations! Cheers Reimund -
Happ new year Joachim, hopefully you can repair this mishap! Did you do a "sealing" coat BEFORE you started weathering? I´m using Future every time I did a step in weathering (paneling i. e.). It is only slightly time consuming but very useful if the result isn´t satisfying - removing could be done without any damage to the previous steps. Take a breath, have a cup of coffee - and come back with this fantastic 110! Reimund -
ITALERI F-104 G Starfighter 1/32 German Navy MFG 2
Isar 30/07 replied to F-4Phanwell's topic in Ready for Inspection
Werner, good to see you here on LSP with your first model - an excellent looking 104 and a very impressive photography! Congratulations! Or how a bavarian would simply say: a pfundiga fliaga! Reimund -
A beautiful Kurfürst! The paintjob looks very realistic, i. e. the "late war style" faded camo! VERY IMPRESSIVE - cONGRATULATIONS! Cheers, Reimund
- 26 replies
- barracudacast
- eaglecals
(and 4 more)
Tagged with:
Messerschmitt Bf 109 G-6, 2./JG 51, Black 13
Isar 30/07 replied to 109's topic in Ready for Inspection
Bernd, da legst di nieda! Perfect looking model, i. e. the riveting! And - it takes not much to present a model very spectacular! Reimund -
1/32 PCM Hawker Hurricane Mk.1 Early
Isar 30/07 replied to Tolga ULGUR's topic in Ready for Inspection
Tolga, wow - another perfect looking model! I did this model a few years ago and I know what it takes to present the model the way you did! Congrats! Reimund -
Henschel Hs 129 B-2 - GREY MATTER FIGURES
Isar 30/07 replied to Isar 30/07's topic in Ready for Inspection
For sure I will when it comes to stores in Germany. -
Thank you very much Mike! -
Thank you very much for your comments! The model was airbrushed using XTRAColor paints. After priming and preshading I added some spots of the highlighted colors (RLM 70/71/65, 04) here and there. Next step was adding Maskol using a sponge to cover those spots partly. Then I sprayed these colors again - this time silghtly darkened and put some salt onto these areas once the color has dried (it was my first try using salt - it could have been done using Maskol again). After this preparation the camo was sprayed on and the panels were hightlighted more or less. Once the paint has dried the salt and Maskol was removed. I was satisfied with the result even those once salt coated areas did not show very much of the work. You can use dark aluminium as a base und add Maskol to represent chipped paint but I did not on my Henschel. Instead, I used a pen called "Faber silver chromos" (I bought at an art supply store) that you can use as a lead pencil once the final coat has applied. Shoeprints were made using rubber shoe/boot prints from Calibre 35 and pigments mixed with a few drops water. Using water is very handy as you can correct/remove it easily if you don´t like it. One thing I´ve noted using Maskol: Using Maskol in combination with XTRAColor was easy and I could remove all the Maskol without any problems. When using Gunze paints the Maskol has a strange tendency not to be removed….. Strange as XTRAColor takes much more time to dry. http:// http:// http:// Reimund -
http:// http:// http:// http://http:// http:// http:// -
Gents, this is my Henschel HS 129 B-2 I´ve done a few years ago. This kit is challenging as it is partly very simple (landing gear i. e.) but was then the only model of this tank hunter. As I was inspecting the parts I came up with the idea of opening the port weapons bay (the fuselage side were so thin you could see the light). Ok - and when opening the gun bay, why not do a little diorama? My diorama depicts a moment prior to the next mission during the battle of Kursk, summer 1943. The gun bay was done scratch using a MG 151/20 from Aires. Figures and starter cart came from Verlinden, the squadron´s mascot, a German Shepherd (Mantis), lies beneath the port wing seeking some shadow from this hot summer day. Building this kit was fun despite some shortcomings - the fit of fuselage halves and wings/fuselage was far from beeing perfect - but I enjoyed this built as I had to improvise here and there. I´m pretty satisfied with the result. Now looking forward to see the ZM Hs 129, though the GREY MATTER FIGURES Hs 129 B-3 (the beast with the 75mm gun) is still waiting in my stash... Reimund http:// http:// http:// http:// http:// http:// http:// http:// http:// http://
Ta 152H-1 W.Nr. 150168 "Green 9" Ofw. Willi Reschke
Isar 30/07 replied to Miloslav1956's topic in Ready for Inspection
Once again a brilliant model! I like the realistic weathering including the small dent at the propeller hub (or do I see something that isn´t there?) Reimund -
Lothar, a good idea not to put the model into the waste! I love it a lot - some kind of markings not often seen! Very impressive!!! Reimund
WOW - thanks for sharing! Trying to replicate this on a model is a very thin line between "very realistic" and "pal, you overdid it a lot". Reimund
very impressive model - once again! Reimund
1/32 Trumpeter A-1H Skyraider South Vietnam
Isar 30/07 replied to pouikpouik's topic in Ready for Inspection
Very realistic paintjob and weathering! Reimund -
We have 32nd B-17, B-24 and Lancasters (plural!). What's next? B-29?
Isar 30/07 replied to Brent's topic in LSP Discussion
When seeing my stash, I´m always wondering when these multi-engine kits will ever be built. Next challenge: where to place when built. I did a Mistel, B-25, He 111, Ju 88 and Bf 110 and placing/presenting (and even stowing) is a major problem. Beside this - here´s my wishlist: - Ju 52 - Do 17 - B-26 - He 177 - C-47 - FW 200 - SH-3 - CH-46E - Ju 290 -
Finished !!! 1/32 Revell Junkers Ju-88A-1
Isar 30/07 replied to Tolga ULGUR's topic in Works in Progress
Having missed this build so far.... But this is AWESOME! Like the paintjob much! Tolga, this will be a real beauty! Reimund -
Great subject, wonderful done! Congratulations!
- 27 replies
