j ferguson
LSP_Members-
32 -
Everything posted by j ferguson
the 2 inch venturis i'm familiar with don't have the cone in front and the tube is contained in the mount.
OK guys, the small ones are called 2 inch venturi's because they draw 2 inches of mercury (suction) the bigger one which was on Kobuyashi's plane is probably a 4 inch one. Remember the larger cone goes aft. google 2 inch venturi to see if this was the alternative.
Hi Alain, The photos I saw of the installation of the larger venturi did not start with one of what was there before the project began. If the plane started out with only the turn and bank indicator vacuum (suction) powered, a smaller venturi would have been adequate. My Cessna 120 was so equipped. I had to install the larger venturi to develop sufficient suction to drive the artificial horizon and heading indicator. Kobuyashi and company may have been doing what I did, except in my case I bought an electric turn and bank because at the 100 mph cruise speed on my plane the bigger venturi was only sufficient for the two instruments referred to above. If the Japanese artificial horizon and heading indicators were similar to ours from that period, less vacuum was required and they might have been able to run all three instruments with the one you typically see on ki-61s. You sometimes see these venturi's on the noses of pre-war DC-3's. When you do there are usually two of them - the better to get the instruments operating at lower air-speeds. I'll look around and see if I can find a good photo of the smaller venuturi. IIRC they were about an inch in diameter and maybe 7 to 8 inches long with the mounting point about an inch behind the forward part and a shallow horn extending aft. I suppose it's not surprising that these are sometimes installed backwards by modelers who hadn't looked closely at the instructions.
Hi Alain, Watch out for the chance that kobuyashi's was the only plane with the venturi. Some years ago someone found photos of kobuyashi and a couple of comrades adding a venturi to a ki-61. He had been been flying twin-engine planes earlier in his career and may have wanted an artificial horizon which he'd come to like in the twins and which may not have been standard with the ki-61 at the time. Assuming that the ki-61 either didn't have any vacuum instruments, turn and bank or gyro compass, it wouldn't have had a suction pump either and so the need for a venturi. It's also possible that he was installing a gyro driven gunsight which would also have needed a suction source. You may be able to find a discussion of this along with the photos at j-aircraft.com. It looked like the installation photos were taken of just his plane, but of course that doesn't mean that his colleagues didn't copy what he'd done. Of course it could have been an official field modification and to more than just his aircraft. good luck with what is sure to be an interesting build. If this doesn't make any sense to you, ask and I'll expand on it a bit.
ICM Fiat CR.42 CN from 377 squadriliga - completed
j ferguson replied to Fanes's topic in Nocturnal Activities
That looks like a Bosch starter magneto on the lower starboard panel. Is it? -
Hasegawa P-47D, Gabby Gabreski 1944
j ferguson replied to Ayovan's topic in The Mighty Eighth over Europe
Ayovan, Is it an Iphone and are they HEIC images? Isn't Apple just woderful? -
One went to Guy Black in some sort of trade.
Friedrichshafen FF.33 L - German Navy Zeebrügge
j ferguson replied to kkarlsen's topic in In the Navy
"accident with some alcohol"?? Internal or external? -
Springs wrote a book about marketing in the '30s which is hilarious. He was an amazing guy.
Is this Elliot Springs of Springmaid Sheets Fame?
In 1980, I was enroute from Chicago to International Falls in a C-210 when an equipment failure suggested a landing "real soon now. I put in at the airport near Grand Marais, Minnesota, 'cannot remember what it was called at the time. The part required would arrive the next day, so I was left with a lot of time, which I used to talk with the airport manager. He had flown the P-63 as a practice target near the end of the war. I can't remember everything he said about it other than it was very dangerous. They actually shot "frangible" bullets at the P-63s which caused lights on the plane to flash when hit. Wiki reports that these were used to train B-17 and B-29 gunners, but my memory was that he told me that he flew in Texas and Arizona and was "attacked" by guys in fighters. This plane would have been a great candidate for this Group Build, don't you think?
Heinkel 111 H-2 finished
j ferguson replied to chrish's topic in The Battle of Britain 80th Anniversary
In St Louis in 1971, I worked with a guy who had flown these during the war. Guys in the office were going through a spate of model building including a couple of airfix (IIRC) 1/72 H111s. A series of booklets was then available including one on the H111 which included a review by Eric Brown. I think his review alerted us to the sometimes open cockpit. We asked Ruprect abut this. I think he told us visibility from the cockpit on the ground wasn't great and driving into another aircraft was discouraged. I also think he told us that the perspex could be fogged up first thing in the morning, hence taking off with head through the roof. (I'm not entirely sure about this, it was a long time ago and I may have this confused with another source. Chrish, i have a question. If you wanted to set up the seat and controls for open air operations, did it look like this was possible with the AM kit you used? -
I'm not up to it, but if the base kit could be found in 1/32, a P-63 Flying Pinball Machine would be unique. PS: it looks as thought HpH made a resin kit of the P-63
Remember 1694
Max, I must say that your exquisite project has deeply impressed some of us here in the colonies with the qualities of this very impressive aircraft. Is one yet airworthy?
Polikarpov I-16, Type 17
j ferguson replied to Dpgsbody55's topic in 30 Years of the Eastern Front 1915-1945
the skis look retractable. Were they? -
Max,, Are you alive and well?? worried.
Didn't Brubaker fly a Banshee?
Fw190F-8 - Revell 1/32
j ferguson replied to Azgaron's topic in 30 Years of the Eastern Front 1915-1945
Did you guys know that the cooling fan turned at a higher rate than the prop? -
Hong Kong Models B-25J bomber 'Peggy Lou'
j ferguson replied to Thomas Lund's topic in Multi-Engine GB
There is always the possibility of the crack being the result of conflict and requiring a field repair. After all, if you are going to get a new canopy you have no reason not to experiment with what a shell or ack-ack fragment might have done to the one you have.Plexiglas (Lucite, Perspex?) repair on a big plane, assuming a repair did not challenge airworthiness would be to drill small hole at end of crack so it wouldn't get longer. We had a repair like this on one of the planes I flew 30 years ago. I can't remember which one or where the crack was, but inspector said it was ok until next annual inspection when we would have to replace that panel. -
I suppose this is a bit off topic, but it would be nice to see more pics of the paint booth, which looks quite clever. Not to mention your marvelous work on the 110.
Bf110G4 NJG4 1944/45 FINISHED!!!!! YIPPEE.
j ferguson replied to mozart's topic in In the Pale Moonlight
You seem pretty positive. How can you be so sure? This never seemed a problem to me, although I would concede that the things I flew didn't have panels quite as exposed as this one, but the 109s have similar exposure and no shields. -
Hi Max, Your work is exquisite. That certainly is a slick way to solder very small components. I can use it for some of the things I've found near impossible in the past. I wondered about the purpose of the two flaps atop the panel which don't white meet at the gunsight mount. Might they be light shields to prevent lights from the panel from being visible outside the plane? -
Is that what it appears to be? A cup with a drain line to make sure that whatever would otherwise leak on the tire (tyre?) will go somewhere else. Germans are so creative with no problem unsolved and then usually with clever designs. I wonder how many other things d in like this can be found in this plane.
