elmarriachi
LSP_Members
  • Posts
    1,022
  • Joined
  • Last visited
  • Days Won
    6
Everything posted by elmarriachi
  1. Hello everybody, Hasegawas newest construction vehicle in 1:35 ....
  2. Hello everybody, Seed Models small tractor DT-54 in 1:35 ...
  3. Hello everybody, I think I call this one done ... Hope that you like it! Cheers Micha
  4. Hello everybody, some little progress after the painting ....
  5. Hello everybody, I think I call this one done .... Hope that you like it!
  6. Hello everybody, added the ropes and the hook .... and started with the base ... a road, a little bit of green .... still working on, not finished yet
  7. Hello everybody, added some additional equipment on the crane .... tools, tarp, wooden beams, chains, ... and started with a small base ...
  8. Hello everyone, the main parts are painted in blue and yellow. A first light grey washing is added and matt varnish sprayed on it... Next some dust and dirt on the chassis and inside the cab ....
  9. Hello everyone, Some progress with this one ... finished the paintjob and assembled the vehicle mostly. Some small things missing. Weathering with dark brown, rust and beige washes .... Next step is adding some load, scratches, dirt with pigments, sheer metal and a small base.
  10. Hello everyone, the worst job is done .... the rigging of the crane hook, the fixing of the hook with chains... but it is done ....
  11. Hi everybody, one of the best known tractors of Soviet production - the Charkov T-150K. It is the fist kit in 1:35 of the Ukraine manufacturer RT Models, consisting of fine resin parts and photo etched parts. Including the worst instructions ever Cheers Micha
  12. Hi everybody, a small tractor "made in Russia" - the Charov T-16M self propelled chassis Small model in 1:35 of Red Iron Models consisting of resin and photo etched parts. Cheers Micha
  13. Hi everybody, The frame is finished as well as the super structure of the crane, the boom and the cab, the engine, drivers cab, .... The boom is glued and soldered .... Lot of bending stuff Next I will add some wiring to the chassis and the structure, then start the painting. Colors I have already chosen the standard ones: black chassis, light blue cab with white front grill, yellow crane and red hook. Cheers Micha
  14. Thanks a lot mates! :) And a little bit more done .... the sealings of the windows are painted and the masks removed. The crane is mounted and the struts painted, weathered and mounted. Some wiring added. The cab of the crane received its internal painting and weathering, as well as the windows. Now some further details follow as well as the rope, chains and more stuff .... Cheers Micha
  15. Hello everybody, one further crane - the SMK-10 of Red Iron Models... Resin- and photo etched parts, wire and clear foil. Chassis completely made of resin and photo etched parts. Cheers Micha
  16. Hello everybody, some first start with the base ... Cheers Micha
  17. Hello everybody. Some first weathering .... oil colors brown, beige, gree, yellow, white, blue, burned umbra ..... And the cab mounted .... now more details and parts to the cab, weathering of the exhaust and fuel tank .... Cheers Micha
  18. Hello everybody. I think I call it finished ... I hope that you like! Cheers Micha
  19. Hello everybody, paint is on .... Mission Models Desert Tan, some highlights with ligther beige color ... oil colod washing .... and all put together .... Now some dust on the windows follows and final touches as well as a small base Cheers Micha
  20. Hello everybody, the crane is done ... mostly .... lot of wiring added to the boom and the super structure ... also some additional details added. The super structure is removable as well as the struts on the sides. Tried some equipment ... maybe some chest, bottles, tools, .... wood, blanket. ... let's see what I will add So far for the moment ... ready for painting I think ... some first colors .... Cheers Micha
  21. Hello everybody... some paint is on ... the friul tracks added and weathered .... now some more details follow ... and some dust ... and a base .... and antennas Wondering about one issue - Trophy and Droid - does this go together? Or only one of each? Does anybody know more here? Cheers Micha
  22. Hello everybody, here are some pictures of the finished P-40 "Longtrack"-radar ("Bronja") in scale 1:35. The mode is based on the AT-T ofTrumpeter, in combination with the conversion set of Panzershop for the P-40 including resin and a huge quantity of photo etched parts. Additionally used the engine cooler set of Panzershop, photo etched parts of Voyager, brass pipes (Antenna), new engine of MiniArt, Antenna bases of Panzerart and metal tracks of Friul. Further pipe works, handles and more was made of wire, different other details added scratch. The finished model was published in magazine "Scale Military Model International" and"Model Military International" Cheers Michael
  23. Hello everybody, some more progress here. The crane boom is assembled. Several parts, glued and put together. The super structure of the crane is also mostly assembled and several wiring (soldering wire) added as well as some parts which I still had from other kits. Some more wiring will folllow at the boom and on the other side of the structure as well as on the hydraulic cylinders. The boom is glued in position and adjusted to the vehicle. It will not be movable later. The interior of the drivers cab is painted in the final color now - I have corrected the turquoise color a little bit .... and painted the small things with a fine brush. Now some dust and dirt follows as well as ome other small things ... Cheers Micha
  24. Hello everybody. I have added some wiring at the first part of the upper structure and mounted the base of the crane. Here also some wiring will follow. The seats received some covering with tape and also some damages, the interior is painted in interior turquoise of Mig.
  25. Hello everybody. The sub-assemblies are mostely done now. The interior is painted and weathered, the windows will follow next and masked. Then I will start the painting with black primer, desert beige and a 3-color camo at one door and some wheels ...
