1,404 -
Days Won
27
Everything posted by kkarlsen
The tape didn't affect the metal surface, because the metallic is vax based, however to have the day glow adhere, I had to remove the 'True Metal' with turpentine before painting. Kent
Hey Guy's the T-33 is slowly getting there, the 'day glo' is on and someday in the near future I will start decalling... Cheers: Kent
Thank you Kevin, actually it's not, 'flawless' I wish it was but I always seem to 'mess up' one or the other part... I guess I will just have to start all over Cheers: Kent
Thanks a lot Wolf! Kent
Thank you Andy! Kent
Thanks a lot Brian
A couple of pictures of the finished build... Friedrichshafen FF.33L (CHFT) 'MN 1247' at Zeebrügge Cheers: Kent
Further progress... Top wing in place, fitted like a 'glove'! Some of the details of the CHFT model (wireless) in place. Generator from the WNW's W.29 kit + Compass at the wing root. The MG ring is also adapted from the W.29 kit. Kent
Thank you Juraj & Mark, I'm really looking forward to having the rigging done on this one...
Getting ready for the final assembly... Kent
Hmm that's actually a good question, I will have to go on another 'fishing expedition'
Grumman J2F Duck... Cheers: Kent
Wow those massive wings looks impressive Tom! Cheers: Kent
Yes they are decals, printed them myself, but it was 'hard work' the get them to settle. Next time I will use my masking method for the floats. Some last detailing: Wing fuel tank. Compass The wings are finally done, I had to do them twice because I had an accident with some 'alcohol'. I'm quite happy with the end result being 'prototype' decals and all... Cheers: Kent
Roden Albatros D.I Prinz Karl Friederich von Preussen
kkarlsen replied to Gazzas's topic in Ready for Inspection
Beautiful Albi! -
The printed naval hex sheets from Lukgraph have arrived... Tests to see how the decals react to different pre shading colors. So with the pre shading color in place... Progress of the decal'ing of the fuselage. The light grey is also Lukgraph's decals. The colors could be tweeked a bit, but overall I like the result, not too stark in the coloring. The floats with a darker version applied. Cheers: Kent
Yes please, thank you Kevin
Finally got around to work on the seats for the T-33... (Some floatplane always seams to block any progress) ' It was far more complicated than I initially thought, but now I have a pair of useable seats. Maybe there is hope now! Kent
Well it's all part of the process. 'God forbid' building a kit OOB... So on to the 'surgery' - Superimposing the different tails on top of each other, Doesn't look too bad. No trouble at all, fortunately the new shape is not too far from the kit tail planes and smaller A little progress on the floats too... I've replaced the struts with massive brass ones, drilled far into the floats. That's the way I'm used to do my scratched floats, adds a lot of 'rigidness' to the structure. Cheers: Kent
Thanks for your hard work Kevin!
Ha! I just noticed - The elevators have a different shape!!! Some more to fix...
Well this built It's turning out to be the same story as usual... I decided to built the kit out of the box and now I find myself rebuilding, scratching and 'hacking' my way through this kit!! Now I'm using the time waiting for the Hex decals to do something about some of the issues with the floats... Doesn't look like much, but the 'nose' has been widened to make it less pointed. They have also been shortened to get the right shape of the front. Found this photo of the construction of Friedrichshafen floats, showing the 'step's and the reason why the 'stringers' are placed where they are. The bottom has been fitted with new 'stringers' and i have created the sharp steps of the floats. The fuselage is coming along, with some minor altercations to fit the MN 1247. The forward engine 'ventilation? has been removed, those in the back have been 'opened' to an earlier version. Four small vents have been added to the front of the cowling. The propeller and the spinner have been painted. I've also started on scratching the converted radiator of the CHFT version. The tail part have been cleaned up, pre shaded and fitted with brass rods to have better control for fitting. Cockpit coaming done and the ring from the HB W.29 has been fitted to fit the new observers seat. Cheers: Kent
Rumpler 6B.1 Floatplane (Kaiserliche Marine)
kkarlsen replied to kkarlsen's topic in Ready for Inspection
Thank you for your kind comments, Glijn, Mike & Tolga, appreciate it! Kent -
Thanks! I've added a new 'header' pic with a background... Thanks for looking: Kent
