46 -
Posts posted by Uncle Les
8 hours ago, TomcatKirby said:
Hi, Les
It does look good and a tremendous undertaking… well done!
I have and compared the vac to some blown up drawings from Detail and Scale and noticed it might be short AND maybe too narrow in the main fuselage. And totally agree on the nose. I know drawings aren’t always accurate, but something didn’t look right.
Curious to hear any other observations.
Regards,
Kirby
Thanks. I learnt a lot from this project and will endeavour to transfer knowledge gained into the next one. I did something similar with the vacform and the pans and came to a similar conclusion - hence me going the way of 3D design and construction.
8 minutes ago, Maxim61 said:
I don't think it turned out too bad. The nose profile is difficult to get right on the F-111 and I did notice it, but then I'm an F-111 nut. Do you have all the station dimensions for the air frame? I could pull them from the F-111 structural manual if that'll help? The Hasegawa 1/72 scale F-111 series is still the best in profile and detail. Reskit are hinting at a the possibility of a 1/32 F-111 kit which I think would be mostly 3D printed.
I do not have all the station dimensions so yes I would appreciate that thanks. If Reskit did proceed with a complete airframe I'd be there in a flash. I intend to build on what I learnt from this experience (pun unintended) and fashion another pig, probably a bombed up USAF bird.
Slight correction to Kevin's observations - the airframe around the cockpit is cast resin from 3D printed sections of my and a friend's designs. I have the Tigger vacform example and consider it not even close to being useful. I mistakenly used a Hobby Boss 1/48 example as a reference ( note the progress pic below ) and the nose profile is too shallow before it suddenly jumps up the front of the cockpit - after making that mistake I bogged it up and as a result that nose profile is a degree off in ascending gradient towards the cockpit front so yes the nose profile from the side is off to the keen eye. I promise to fix that for the next one. The spine is also too high by a fraction also resulting in a bit of a hump - these are the issues one faces when building a large model in sections !
One other take away from using the HB 1/48 kit - their walkway decals are flawed as they've managed to swap the WALKWAY stencils with the NO STEPS resulting in some serious OHS issues if you walked on the wings ! I scanned the decals (1/48) and digitally remumbled them by 150% ( 1/32) and only realised the error the day before Expo ( the build physicaly started a week before my self-imposed deadline - delays for a month not self-imposed ) so by that time it was too late. I will edit the file for the next one.
This build served as an excellent education for me in what to do and what not to do when taking on a project like this.
Some pics included here to show some of the virtual progress.
- Daniel Leduc, LSP_Kevin, Learstang and 3 others
- 6
22 hours ago, LSP_Kevin said:
The Beaufort is a conversion of the Revell Beaufighter by my friend Les Applebee (Uncle Les on Facebook and elsewhere). He designed and 3D-printed all the Beaufort bits, and combined them with the relevant kit parts to produce what you see. I've bugged him to print me up a set of parts, but to no avail.
Kev
You've got your own 3D printer now Kev, you can just magic up a Beaufort anytime you please !!
27 minutes ago, LSP_Kevin said:
I think Les plans to produce this one in all 3 popular scales (1/144, 1/35, and 1/18).
Kev
LOL ! ( Yes I AM reading this) I'm doing it in 1/32, 1/48 & 1/72 in limited numbers ( because that's how I roll).
There's one on eBay right now to drum up finance for further work. https://www.ebay.com.au/itm/194447123175
Here's the work I just finished on the 1/48 accessories set which is being test printed as I write this and some examples of where the masters begin life.
8 hours ago, Collin said:
Freaking sweet!! I mean sweet!
Can you expand a little on your improved intake?
Cheers
Collin
Nothing special, just FDM 3D printed up in ABS a slightly curvier piece and cajoled the intake lower lip into place. A little filler a load of sanding and replacement of the front sensors.
- Anthony in NZ, Martinnfb, Out2gtcha and 1 other
- 4
13 hours ago, Grissom said:
I'm not familiar with that kit and whether or not it comes with a pilot. Is it a kit pilot or an aftermarket one like Master Details jet pilot?
No the kit doesn't come with a pilot, I employed a slightly modified "Aerobonus" unit.
- Lothar, Anthony in NZ and A-10LOADER
- 3
Here's a little something I cracked the whip on last week. Basically wheels up OOB with the exception of a new scratch-built intake lip to make it curvier and a resin cockpit set. I loaded up the fuselage with magnets and will fashion a proper display stand at a later date.
Les.....the people are speaking!
I hear'em ! When the mojo's right....
- Kagemusha and Anthony in NZ
- 2
It's gorgeous Les, how did it do at the contest?
Was a bit disappointed to see the update on facebook that you weren't planning to make it into a kit but if that changes, please contact me right away. I'll put down money up front to have one of these in the collection.
Cheers!
Cheers, it tanked in competition - but excelled in being noticed ! I've got to get the MB326 out there and it's taking longer than anticipated so once that's done and I see how it goes I might change my mind on doing something with the MB339 masters.
Here's one I finished last week.
brief build story : https://www.facebook.com/pg/uncleles1/photos/?tab=album&album_id=1687672618018678
- mark31, scvrobeson, Out2gtcha and 2 others
- 5
I built it on the long held premise that as soon as you scratchbuild something vaguely popular it'll magically appear as a mainstream kit just as the last coat's drying.. So guys.. I'm doing my bit for the greater good !!
Thanks Hubert, re the Winjeel, no not as yet as some serious flaws in my master came to light. The wing root and chord are a couple of mm too thin horizontally and this has ramifications that require a rebuild.
The model was entered as a composite - Revell Mirage III ( front end ) & Revell MiG29 (wings) plus scratchbuilt components... but the manufacturer part of the entry form only shows the major branding. Thanks for calling it superb ! - Les
- SharkOwl and EvilCarrot
- 2
Awesome build mate.
Is it finished yet ?
Wow, you didn't waste any time getting into it ! I recommend using the opaque vacform canopy supplied as a guide to getting the fit right and to act as a sort of mask for the coaming - but you'll work all that out. I'll watch your progress with keen eyes !
- Iain, D.B. Andrus and etendard
- 3
1/32 Scale F-111
in LSP Discussion
Earlier today before the model gets stored away for the next decade.
