Mr Smith
213 -
Days Won
3
Posts posted by Mr Smith
A big bird !!! Clean Job !!!!
Hi,i follow your build, a Sukkhoi,mmmmh
I have some problem to close the fuselage with the resin bay from Wolfpack,maybe with Aires it's ok....
Jean-luc
- Nic C.D. and Youngtiger1
- 2
Waouw....a furious man!!!! Great !!!!
Hi Oliver,
Another master build ! I'm happy to see you again!
If i can help you,i have some good picture in detail from the Frelon !
Jean-luc
Hi Oliver,
I discover your work,a magnificent work once again !
I wanted to make on of the Konninlijke Marine,but the resin parts that i received for the convertion are horrible.
It's because of that,that he stay in his box...
Jean-luc
Hello,
Yesterday , I received the Trumpeter kit...the small devil in my head have me say: Why use you not the wings of the trumpeter? It is easier!
I tried, and here is:
No modification,just a metal washer either small
And say that I have to cut the front gear of Tamiya to make it low...Trumpeter proposes it in the kit
Jean-luc
Hello Thierry,
A big challenge with this kit...i have the UM from revell,same work,same problem...i have cut the lerx and now,he sleep in the box....
Jean-luc
Yep Kevin,i have problem with IE for the first time here...
First step is to retrofit the fuselage to represent a F-14a from 1991 ( old gun ventil , refuel trap remove )
All the step ladder is erase to represent closed
The good gun ventil in place ( Wolfpack parts)
The canopy is closed,minimum details into I use "Eduard" photoetch and two "Blackbox" seat,i try to represent the two pilots ( from Academy) in a correct attitude for this scene.
I use some parts of the "Blackbox" kit
I cut the flaps from the wing,a hard job.. .
Hi everybody,
Sorry if i do not often post...my english is bad
But i shall want to show you my current build,a F-14A Tomcat from Tamiya, i started with this kit :
I try to make this plane :
For that,i need a "Superscale" decals sheet for the marking, a "CAM" decals sheet for the data in high visibility and many other accessory...
My objective is to represent the Tomcat on a catapult....the challenge for me...
Beautiful but:
Dont forget the glasse on the HUD.
The antenna on the left side on the nose seem to tilt.
Sorry for those remarks but i look .
Yep yep The glasse is in the box ...on the model for Lier
But i dont understand for the antenna on the left side on the nose.It's the threat warning antenna?Maybe a little beat but this is too late...
and no problem for those remarks!!! the antenna on the dorsal spine ( at the rear) is missing,it's photoetch part and not a good fitting...
Yes it is,you can found here,just for the exemple : http://www.modelpassion.ch/index.php/component/virtuemart/peintures--pigments/alclad/hot-metal-sepia-detail?Itemid=0
Hi Kevin,
My name is : Briatte Jean-luc
Thank's
Hi Mark,
I discover your subject,a great challenge!
I follow!
jean luc
Hi DoogsATX,
Take care with the lenght of the piston to open the canopy,the acdemy is a little beat too short.
i would try the Wolfapck pit on my F-16D,it's very a great piece
Jean luc
Ow,this not "up to date " here!
Really nice work, what paints did you use for the camo?
It's Gunze Paint,
Fantastic build Jean-luc! Really impressive. May I publish it on the website?
Kev
HI Kev,
Yes,no problem for the website,it's pleasure
Jean-luc
Su-30 MKI Russian test plane 02
in Works in Progress
Goeden Dag Rogier,
Thank's for your comment.
Yes,i have make plan at 1/32 scale,i can help you without problem :-) A ultimate reference is this book :
http://www.amazon.fr/Sukhoi-Su-27-Yefim-Gordon/dp/1857802470
I have a PDF version if you would.
I can send you many plan,i'm from Belgium,this is not too far... :-)
Best regards
Jean-luc
