1,760 -
Days Won
3
Everything posted by petrov27
So not a whole lot of hands on plastic the last couple days, but I did do some messing around with my 3d printer to see how small I can print with it. I am pretty happy - the tiny toggle switches are perfect, the injector ring for the engine you can read the "Pratt & Whitney" on the printed part and the throttle quadrant very nice and an improvement over the kit part and better (IMHO) than trying to use the flat photoetch levers that come in the Eduard or Aires cockpit sets. Note these are not my 3d models; the switches are digital files purchased and downloaded from ANYZ. The throttle is a model I purchased of a full size replica of the P-47 throttle on Patreon "Thunderbolt Controls." I had to edit it quite a bit to re-proportion some things so they would print so small. I hope to at some point print the full size model. I did change the throttle lever itself to a different style I noted was present on the Dottie Mae P-47. That file was found on MyMiniFactory website by UnionJack68. Finally I found an entire Pratt & Whitney R-2800 on Cults3D website by user FANCHERELLO - amazing 3D model they have done - I printed the injection ring from that for possible use with this build. As far as the actual build, I have done some re-scribing of lost panel lines on the wings and a little more paint on the cockpit parts hope to have some more progress in the next couple days on that front....
Ohhh fantastic - glad to see this is still in process at least. Hope it does come to production some day (along with that A-20 we saw a few times in the last five years...)
Models for cockpit and exhaust Look great! I can say I am having pretty good luck with my Elegoo Saturn if you were looking for a 3D printer for your own (though lordy its messy and stinky) Just printed a 1/32 Pratt Whitney injection ring for R-2800 today and you can even read the PRATT & WHITNEY on it (note not my model just one I got off the interwebs)
Ohh - nice subject! I was just looking at this kit in the stash the other day - definitely following along with your build!
I would be in for a couple sets of Beau canopies
1/32 Fly Hurricane Mk. 2C Night Fighter (Done)
petrov27 replied to IainM's topic in Works in Progress
Very nice build - really is going to be a stunner - excellent job with the masks and markings!- 103 replies
- master
- hgw detail sets
- (and 5 more)
Day 7 Not a ton today; "bench" was cleaned and organized some though, new cutting pad delivered and put to use (got about 12 years out of the last one.) Interior bits given a prime of Tam AS-12 aluminum; hoping to "chip" some of the dull dark green back to this to show some wear and tear. On the road the next couple days so I guess it will be a break in the build...
Zoukei Moura Bf-109 G-14 a Non-Hartmann Build 1/32 Scale
petrov27 replied to Gazzas's topic in Works in Progress
Looking great - yes the rivets do add a lot in my opinion - kudos for putting in the effort on them! -
This is really coming together fantastic - love the work you have done on the interior and wheel bays
Thankya! Day 6 More playing with resin pit. Unsure what panel I will use but the back panel and rudder pedals are at least built and ready to go.
Correct me if wrong, but a 1/16 tank build could still be welcome here under "Non LSP Works" right? Pretty sure I have seen a few folks do builds in there. If allowed and I chose to take on a 1/16 tank I would share it here vs other forums (thankfully as yet I have not given in to the 1/16 tank kits though lordy it is difficult - these look so great.)
Yeah probably should wear a filter mask or somethin when playin with the resin oops... Day 5 Not a lot done tonight - very tired. I did cut several tiny bits off the casting blocks, very carefully clean them up so they are ready for assembly
Thanks once again for positive feedback! Day 4 Started this evening after work sanding the seams on the wings and flaps, a little filler and more sanding - not much to show for all that but I think I got most of the problem areas (Im sure when primer is applied it will show that I have more work.) So the cockpit. I turned to the dark side - Aires resin. I had that set lurking in the Hasegawa box taunting me, daring me to open it and inflict misery on myself. Not sure what y'all think about resin sets like Aires - they look SO great, the detail on them like twice as good as the kit plastic maybe more, but lordy trying to fit those things into kit plastic can just destroy any momentum and bog a build down. Many require massive changes to the plastic parts - extreme thinning, location lugs removed etc. and even cutting the parts off big resin blocks can be a pain. Well I decided to ignore all that and give it a shot - ya only live once. Parts were sawed off the blocks (man the resin stinks) I carved off the locating lugs and the small amount of interior detail on the fuselage halves, had to do some major surgery to the wing spar that the pit rests on etc. I tacked the resin pit together and mocked the whole thing up to end the evening and amazing it all fits real nice together now. Extremely productive evening on the bench even if it doesn't look like much. I will say the big Tamiya razor saw though spendy is a fine tool very handy to have on the bench. I did get "Dark Dull Green" in the mail from Sprue Bros today - Mr Paint's rendition - it is pretty dang dark and intense. I may play around with that - trying to match what I see in the pics of the restored Dottie Mae - maybe I am making an assumption that the green they used is dead accurate, but it looks good to me...
Damn amazing pits here all - that Mossie and 109 are fantastic as are those on the previous pages (that A-6E and Phantom wow....)
Day 3 So wing halves now glued, brass guns installed temporarily because they look cool, built up the flaps and started fussing with the fuselage. A lot of cleanup needed on the wing joint areas but that will be tomorrow when the glue has dried some...
Thankya - its a start at least! Day 2 Pretty wiped out from work etc. but got a little time in this evening. All of the filler on the wing sink marks was sanded and smoothed out, made up the pylons and made the modifications to the wing so they can be fitted (drill holes, remove a raised ridge from the wing surface.) Also sawed the moulded in wingtip lights out so I can use the optional clear bits. Digging through the aftermarket looks like I have some Bazooka tubes from Eduard - deciding if I will mount these or not - they look pretty good aside from the fact that the front end is not hollow - there is a concave depression instead which seems odd. Maybe I can drill them out...
ICM considering OV-10A in 1/32, vote on their FB page
petrov27 replied to Jan_G's topic in LSP Discussion
lordy for some reason I first read this as "ICM considering an A-10A in 1/32...." I need glasses (better glasses.) -
Great review - looks like another to add to the shelf The HPH La-7 is pretty good: But still I would purchase an injection moulded version if done well in a heartbeat....
So trying to do a "get my mojo back" build here. Simple Goal; get something done on it daily - doesn't have to be much but at least some progress. By all accounts I have heard this is a decent kit with a few challenges but nothing crazy. I will be using some aftermarket, definitely the BarracudaCals decal set for Sleepy Jean III (they look brilliant) and master brass barrels. Probably some of the Eduard color etch set for the pit and last but certainly not least the fantastic landing gear by SOW. Maybe something for the engine - the front could use some work to make it more accurate and detailed IMHO... Day 1 Progress Started with the wings and tail surfaces as I am lacking paint for the cockpit - hopefully that will deliver mid week. As other builds here have noted there are noticeable long sink marks on the wings - I have filled with Mr Surfacer 1200 (more like Mr Surfacer 100 now as that pot is OLD but makes it more useful to fill small issues...) The Master Barrels are "full length" so you must make some modifications to accommodate for that. I Dremel-ed off the lip on each brass barrel at the back end so that these can be inserted through the ports after paint. Engine bits. Left is from this kit, the right borrowed from a Trumpeter kit. The Trumpeter at least has more correct distributers option parts. I know not a lot will be seen after the engine cowlings are on but I would like to at least have the front of it right. Might see if I have some aftermarket engine bits in the stash or order something.... So not a ton done day one but a start!
Great start! Now I want to start this kit too lol....
the narrow strips with nails is what I believe WNW found was accurate? I think there was some argument about that on Facebook or somewhere. They are extremely hard to see on the real thing but there is a photo or two on the WNW website where I think I can make them out. Certainly I cannot see any evidence of wide tape. Just my opinion but for my part I intend to leave as-is on the 1/24 and on my 1/32 build (which has the same detail) I just sanded them down quite a bit. Edit - found a pic in my hoard of references - this is the late prototype I think (V5?) but it is the clearest I have found showing one of the ribs with the strip and fasteners
Wingnut Wings customers' models contributors
petrov27 replied to Christa's topic in General Discussion
Yes I did No that section did not influence purchases, but I was already sold on their products/subjects offered. Maybe? I will say I liked seeing the builds of other modelers and the section may have influenced my builds of kits etc. positively? -
Just amazing - such a great looking build! All the markings done via masks I think?
1/32 Trumpeter A-6A INTRUDER “505 DEVIL LEADER”
petrov27 replied to miketippingmodels's topic in Ready for Inspection
Fantastic build, finish and display - totally rocks
