190 -
Days Won
1
Everything posted by radial
Really is fantastic! The props look like fine mahogany.
For some reason any black I've tried has tricky drying times. Don't know why.ive only used the old formula Krylon with any success. Duplicolor decanted is great stuff. Duplicolor white primer is very similar to tamiya . I only use Tamiya on my good builds.
Dave, Yeah there wil be gaps to fil especially at the curved lower wing root and my nemesis where the top wing meets the fuse. No recommendation on filler. Just use what you know. Hubert is right about the engine. You might want to pick up a Williams Bros. Gee Bee Z. It comes with 2 engines the P+ W jr. And sr. And two cowls.
Good deal and great progress so far!
Really like that you are pursuing this build and not putting this collectible kit on eBay.i built the Staggerwings unlmtd kit a few years ago which is a repop of the old ITC kit. Popular opinion has it that your Scratchbuilders kit molds are based on the ITC kit with the addition of other parts and amore accurate placement of landing gear. This will be a special build!
Dave, done right the staggerwing would be a unique and award winning model.9 mos. would definitely be the minimum amount of time to build this kit.Hope you do it!
Testors put out a few kits in1/48. Mr. Mulligan,Ryan PT20,Laird mystery ship and Howard Ike. I think all are OOP.
Kevin,I think a dremel polishing wheel is a recipe for disaster. Hard to control even at low RPMS. Try automotive rubbing compound ( not polishing compound)with a wet piece of t shirt. The pic below shows what a badly orange peeled surface can look like after afew sessions of polishing.
Market Research - Your top 'wanted' aircraft in 1/32 please...
radial replied to richdlc's topic in LSP Discussion
Almost any general aviation aircraft especially from the golden age. Oh did you say marketable? Never mind! -
Judging is very subjective as you've found out. Having said that when you first posted your RFI I was very perplexed by the presentation of your excellent model. Why tie down a bare airframe ? What's with the bicycle spokes that look like wood dowel rods ( especially with your high skill set? Just saying as I really do like the aircraft on its own merits. Maybe the judges were confused.
- 60 replies
- 3d printed
- anyuta 3d
- (and 5 more)
Trumpy's P-51B times two - Dominic Gentile and Ralph Hofer
radial replied to Thomas Lund's topic in Works in Progress
Try the decal method for the checkers. Cut a length of white decal trim the width of the checkers and apply to the prepainted red background. Worked for my Cub tail. -
Low risk wash is acrylic tube artists paint mixed with water to a sludge consistency. Wipe excess off with water. Color can be browns ,greys to black. Forgot to add that a gloss coat is needed for all washes.
Exceptional. It really captures the light and delicate look of these early aircraft. I'll never complain about rigging again!
When airbrushing with the compressor pres. Gauge set at say 20PSI the gauge fluctuates between 7-18 PSI while spraying. All my compressors do this. The question is what is actual pressure coming out of the AB during these fluctuations? What is the actual "useable" PSI?
Don't use Boeing. Just label the kit Stearman. We'll know what it is!
Use Scotch tape or similar clear tape. Burnish on decal and slowly lift tape off. Decal will come off in pieces with tape. Only works if model hasn't been clear coated.
Hobbycraft Sea Fury Hawker Company demonstrator G-AKRY
radial replied to airscale's topic in Works in Progress
I get the creasing problem all the time. I only know that it's usually caused by frame movement and thicker material. I also don't think our homemade machines have enough "suck" power! Micromark sells PETG under the trade name Vivak. Comes in.020 and .030". .030 is perfect for 1/32 scale. -
Like your ideas. As an alternative,look at the original prototype V 173. Would be cool in wood finish,wheel pants and 80 hp Continentals.
CA mixed with micro balloons to the consistency of white paste. There is no perfect filler. Always requires multiple applications of Mr. Surfacer 500 and sanding.
I been using wide (44 mm.) Tamiya Tape for masks. If the design is wider than 44mm. The tape is slightly overlapped to make the width needed.
I only use music wire for rigging but flattened .015 because it is more rigid than .010. Hobby town carries .015 here.
Wonderful work on a beautiful inter war AC. Bet the top wing was a challenge to mount!
That is lovely Simon. Looks like a ways to go though!
I always thought it would be possible to kitbash a Beech Starship from some of the larger airliner kits.
Lohner Tl Austro-Hungarian Flying Boat
radial replied to Tnarg's topic in Anything But Injection Moulded!
Photos are up now. A okay!
